RTEMS Docs: Adding GSoC Getting Started Instructions
Tue Mar 17 15:14:29 UTC 2020
On Tue, Mar 17, 2020 at 2:12 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> On Tue, Mar 17, 2020 at 2:28 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Mar 16, 2020 at 12:56 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> > I am interested in taking up #3907. I'll mostly be copying and updating the contents from the old wiki site.
>> > I have the following plan in mind. I'll start working on it if you are happy with it.
>> > Add a new gsoc section in the user manual with contents
>> > from https://devel.rtems.org/wiki/GSoC (index.rst)
>> > Under this section, we'll have the following
>> > 1) GSoC getting started instructions (https://devel.rtems.org/wiki/GSoC/GettingStarted)
>> > 2) Mentors list (https://devel.rtems.org/wiki/GSoC/Mentors)
>> > 3) Previous year GSoC information under separate pages.
>> I think it should be separated somewhat. This GSoC stuff is not right
>> to put in the User Manual, except for the Getting Started guide. There
>> is the full "Quick Start"
>> https://docs.rtems.org/branches/master/user/start/index.html#  that
>> may be too complicated for new users, but that area of the user manual
>> is probably where the simplified "GSoC" guide should live.
> I'll start with adding the getting started instructions in the quick start section and later start working on the
> Learning with RTEMS section.
> Regarding the getting started instructions, should we ask the user to refer to the quick start section for
> build instructions or should we repeat them? The old wiki tells to refer the quick start guide for build
> instructions but IMHO having all the instructions in one place will make it easy for the newcomers.
I agree with you that having a simplified build instructions for
newcomers is good. And provide the pointer to the full instructions.
>> That said, I'd be OK with introducing a new "Learning with RTEMS"
>> Manual that covers both SoC, GCI, and maybe can be expanded over time.
>> As a kind of "beginner friendly / student-oriented" guide?
>> > Niteesh
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
