[PATCH v7] tests for fenv.h functions
Eshan Dhawan
eshandhawan51 at gmail.com
Sat Mar 21 17:33:55 UTC 2020
On Sat, Mar 21, 2020 at 10:48 PM Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> On Sat, Mar 21, 2020 at 9:32 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > I have added the changes as told by Aditya
> > I would like to know is any other changes are required to be made to
> make the patch usable
> > Thanks
> > Eshan
> > > On 21-Mar-2020, at 8:20 PM, Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
> > > testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
> > > 1 file changed, 71 insertions(+), 18 deletions(-)
> > > diff --git a/testsuites/psxtests/psxfenv01/init.c
> b/testsuites/psxtests/psxfenv01/init.c
> > > index cdb0fa596e..0ea820c523 100644
> > > --- a/testsuites/psxtests/psxfenv01/init.c
> > > +++ b/testsuites/psxtests/psxfenv01/init.c
> > > @@ -46,11 +46,12 @@
> > > #include <string.h>
> > > #include <rtems/test.h>
> > > #include <tmacros.h>
> > > +#include <float.h>
> > > const char rtems_test_name[] ="PSXFENV 01";
> > > /* forward declarations to avoid warnings */
> > > -rtems_task Init(rtems_task_argument ignored);
> > > +rtems_task Init( rtems_task_argument ignored );
> > > /* Test Function Begins */
> > > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
> > > * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
> > > - * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
> > > - * 'fetestexcept()' functions are supported by the architecture.
> > > + * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
> > > + * fetestexcept() functions are supported by the architecture.
> > > * Hence their testcases can be wrapped under #ifdef and #endif.
> > > #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
> > > puts( "fesetenv(FE_DFL_ENV)." );
> > > - r = fesetenv(FE_DFL_ENV);
> > > - if (r)
> > > + r = fesetenv ( FE_DFL_ENV );
> It should be like r = fesetenv( FE_DFL_ENV).
> > > + if ( r ) {
> > > printf("fesetenv ==> %d\n", r);
> After (, one space needed.
> > > - rtems_test_assert( r == 0 );
> > > + rtems_test_assert ( r == 0 );
> Same here, Remove this unnecessary space, assert and (.
> > > - /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
> > > - puts( "feclearexcept(FE_ALL_EXCEPT)." );
> > > - r = feclearexcept(FE_ALL_EXCEPT);
> > > - if (r)
> > > + /* Test feclearexcept() and fetestexcept() in one go. */
> > > + puts( "feclearexcept(FE_ALL_EXCEPT)" );
> > > + r = feclearexcept ( FE_ALL_EXCEPT );
> > > + if ( r ) {
> > > printf("feclearexcept ==> 0x%x\n", r);
> Same here.
> > > - r = fetestexcept( FE_ALL_EXCEPT );
> > > - if (r)
> > > + r = fetestexcept ( FE_ALL_EXCEPT );
> > > + if ( r ) {
> > > printf("fetestexcept ==> 0x%x\n", r);
> > > /* Test 'FE_DIVBYZERO' */
> > > puts( "Divide by zero and confirm fetestexcept()" );
> > > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
> > > b = 1.0;
> > > c = b/a;
> > > (void) c;
> > > - fegetexceptflag(&excepts,FE_ALL_EXCEPT);
> > > + /* Test fegetexceptflag() and fesetexceptflag() */
> > > + r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
> > > + if ( r ) {
> > > + printf("fegetexceptflag ==> 0x%x\n", r);
> > > + r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
> > > + if ( r ) {
> > > + printf("fesetexceptflag ==> 0x%x\n", r);
> > > + /* Test for fegetround() and fesetround()
> > > + * They have four main macros to be tested separated by ifdef
> > > + * Since not all architectures support them
> > > + * The test case gets and sets the rounding directions */
> > > +#ifdef FE_TONEAREST
> > > + rtems_test_assert ( fegetround() == FE_TONEAREST );
> > > +#endif
> > > +#ifdef FE_TOWARDZERO
> > > + r = fesetround ( FE_TOWARDZERO );
> > > + if ( r ) {
> > > + printf("fesetround ==> 0x%x\n", r);
> > > + rtems_test_assert ( fegetround() == FE_TOWARDZERO );
> > > +#endif
> > > +#ifdef FE_DOWNWARD
> > > + r = fesetround ( FE_DOWNWARD );
> > > + if ( r ) {
> > > + rtems_test_assert ( fegetround() == FE_DOWNWARD );
> > > +#endif
> > > +#ifdef FE_UPWARD
> > > + r = fesetround ( FE_UPWARD );
> > > + if ( r ) {
> > > + rtems_test_assert ( fegetround() == FE_UPWARD );
> > > +#endif
> > > + r = fesetround ( FE_TONEAREST );
> > > + if ( r ) {
> > > +#endif
> > > #ifdef FE_DIVBYZERO
> > > - r = feraiseexcept(FE_DIVBYZERO);
> > > + r = feraiseexcept ( FE_DIVBYZERO ) ;
> > > rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
> > > #endif
> > > 2.17.1
> I would suggest you go through the existing test-cases within the
> /rtems5/testsuites/psxtests directory. Use any of the .c files as a
> reference.
> Make the change accordingly.
Ok, I will do that, The test was written earlier I have just added test
cases to it.
So while writing it took reference from the earlier merged file.
> Are you able to check the values of these variables that you have used
> in this test?
can you please elaborate your question, please :)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/5a3d694f/attachment-0001.html>
