[PATCH v7] tests for fenv.h functions
Aditya Upadhyay aadit0402 at gmail.com
Sat Mar 21 17:41:23 UTC 2020
On Sat, Mar 21, 2020 at 11:04 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Sat, Mar 21, 2020 at 10:48 PM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>> On Sat, Mar 21, 2020 at 9:32 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > I have added the changes as told by Aditya
>> > I would like to know is any other changes are required to be made to make the patch usable
>> > Thanks
>> > Eshan
>> > > On 21-Mar-2020, at 8:20 PM, Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>> > > testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
>> > > 1 file changed, 71 insertions(+), 18 deletions(-)
>> > > diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>> > > index cdb0fa596e..0ea820c523 100644
>> > > --- a/testsuites/psxtests/psxfenv01/init.c
>> > > +++ b/testsuites/psxtests/psxfenv01/init.c
>> > > @@ -46,11 +46,12 @@
>> > > #include <string.h>
>> > > #include <rtems/test.h>
>> > > #include <tmacros.h>
>> > > +#include <float.h>
>> > > const char rtems_test_name[] ="PSXFENV 01";
>> > > /* forward declarations to avoid warnings */
>> > > -rtems_task Init(rtems_task_argument ignored);
>> > > +rtems_task Init( rtems_task_argument ignored );
>> > > /* Test Function Begins */
>> > > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
>> > >   * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
>> > > -   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
>> > > -   * 'fetestexcept()' functions are supported by the architecture.
>> > > +   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
>> > > +   * fetestexcept() functions are supported by the architecture.
>> > >   * Hence their testcases can be wrapped under #ifdef and #endif.
>> > >  #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>> > >    puts( "fesetenv(FE_DFL_ENV)." );
>> > > -    r = fesetenv(FE_DFL_ENV);
>> > > -    if (r)
>> > > +    r = fesetenv ( FE_DFL_ENV );
>> It should be like r = fesetenv( FE_DFL_ENV).
>> > > +    if ( r ) {
>> > >      printf("fesetenv ==> %d\n", r);
>> After (, one space needed.
>> > > -    rtems_test_assert( r == 0 );
>> > > +    rtems_test_assert ( r == 0 );
>> Same here, Remove this unnecessary space, assert and (.
>> > > -    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>> > > -    puts( "feclearexcept(FE_ALL_EXCEPT)." );
>> > > -    r = feclearexcept(FE_ALL_EXCEPT);
>> > > -    if (r)
>> > > +    /* Test feclearexcept() and fetestexcept() in one go. */
>> > > +    puts( "feclearexcept(FE_ALL_EXCEPT)" );
>> > > +    r = feclearexcept ( FE_ALL_EXCEPT );
>> > > +    if ( r ) {
>> > >      printf("feclearexcept ==> 0x%x\n", r);
>> Same here.
>> > > -    r = fetestexcept( FE_ALL_EXCEPT );
>> > > -    if (r)
>> > > +    r = fetestexcept ( FE_ALL_EXCEPT );
>> > > +    if ( r ) {
>> > >      printf("fetestexcept ==> 0x%x\n", r);
>> > >    /* Test 'FE_DIVBYZERO' */
>> > >    puts( "Divide by zero and confirm fetestexcept()" );
>> > > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
>> > >    b = 1.0;
>> > >    c = b/a;
>> > >    (void) c;
>> > > -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>> > > +    /* Test fegetexceptflag() and fesetexceptflag() */
>> > > +    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > > +    if ( r ) {
>> > > +      printf("fegetexceptflag ==> 0x%x\n", r);
>> > > +    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > > +    if ( r ) {
>> > > +      printf("fesetexceptflag ==> 0x%x\n", r);
>> > > +    /* Test for fegetround() and fesetround()
>> > > +     * They have four main macros to be tested separated by ifdef
>> > > +     * Since not all architectures support them
>> > > +     * The test case gets and sets the rounding directions */
>> > > +#ifdef FE_TONEAREST
>> > > +    rtems_test_assert ( fegetround() == FE_TONEAREST );
>> > > +#endif
>> > > +#ifdef FE_TOWARDZERO
>> > > +  r = fesetround ( FE_TOWARDZERO );
>> > > +  if ( r ) {
>> > > +      printf("fesetround ==> 0x%x\n", r);
>> > > +  rtems_test_assert ( fegetround() == FE_TOWARDZERO );
>> > > +#endif
>> > > +#ifdef FE_DOWNWARD
>> > > +  r = fesetround ( FE_DOWNWARD );
>> > > +  if ( r ) {
>> > > +  rtems_test_assert ( fegetround() == FE_DOWNWARD );
>> > > +#endif
>> > > +#ifdef FE_UPWARD
>> > > +  r = fesetround ( FE_UPWARD );
>> > > +  if ( r ) {
>> > > +  rtems_test_assert ( fegetround() == FE_UPWARD );
>> > > +#endif
>> > > +  r = fesetround ( FE_TONEAREST );
>> > > +  if ( r ) {
>> > > +#endif
>> > > #ifdef FE_DIVBYZERO
>> > > -    r = feraiseexcept(FE_DIVBYZERO);
>> > > +    r = feraiseexcept ( FE_DIVBYZERO ) ;
>> > >    rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>> > > #endif
>> > > 2.17.1
>> I would suggest you go through the existing test-cases within the
>> /rtems5/testsuites/psxtests directory. Use any of the .c files as a
>> reference.
>> Make the change accordingly.
> Ok, I will do that, The test was written earlier I have just added test cases to it.
> So while writing it took reference from the earlier merged file.
>> Are you able to check the values of these variables that you have used
>> in this test?
> can you please elaborate your question, please :)
Did you debug the code using XXX-rtems5-gdb? How did you check the value of "r"?
