[PATCH v7] tests for fenv.h functions
Eshan Dhawan eshandhawan51 at gmail.com
Sat Mar 21 17:46:16 UTC 2020
I ran the code using qemu for risc-v architecture.
The value of r = 0 for the function to run without error
while the error is raised when the value is not matched with the correct
value defined in
rtems_test_assert().
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/bdcea8bc/attachment.html>
