[PATCH v7] tests for fenv.h functions
Sat Mar 21 18:51:27 UTC 2020
I liked it better before, when the test prints nothing if it is
successful. I think this is the trend we are heading toward in rtems
tests.
On Sat, Mar 21, 2020 at 11:46 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> I ran the code using qemu for risc-v architecture.
> The value of r = 0 for the function to run without error
> while the error is raised when the value is not matched with the correct value defined in
> rtems_test_assert().
> devel mailing list
> devel at rtems.org
