[PATCH v7] tests for fenv.h functions
Gedare Bloom
gedare at rtems.org
Sat Mar 21 18:55:22 UTC 2020
PS: This is getting better incrementally, you're doing a good job
getting through your first real patch :) It can be a real challenge
sometimes especially since there are a lot of nit-picky things to
learn with the coding style issues.
On Sat, Mar 21, 2020 at 12:51 PM Gedare Bloom <gedare at rtems.org> wrote:
> I liked it better before, when the test prints nothing if it is
> successful. I think this is the trend we are heading toward in rtems
> tests.
> On Sat, Mar 21, 2020 at 11:46 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> > I ran the code using qemu for risc-v architecture.
> > The value of r = 0 for the function to run without error
> > while the error is raised when the value is not matched with the correct value defined in
> > rtems_test_assert().
> > devel mailing list
> > devel at rtems.org
