ticket #3372 Add tests for inttypes.h methods to RTEMS
Eshan Dhawan eshandhawan51 at gmail.com
Sun Mar 29 09:37:28 UTC 2020
On Sun, Mar 29, 2020 at 2:36 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 28, 2020, 3:46 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> Hello everyone,
>> I went through the currently available tests
>> they lack the test for functions
>> •imaxabs()
>> • imaxdiv()
>> Please tell that If any other function whose test is to be added.
> Test for other functions were already written last year by @Vaibhav Gupta
<vaibhav.varodek at gmail.com>
Only these 2 are left for inttypes.h
I will send a patch for the two methods test I think in a way could be
implemented.
Since they don't have any exceptions so I thought of directly verifying the
result.
I will go through the sources for tests as well.
> If we knew, there would either be tests or tickets. :)
> File a ticket with the appropriate tags to have it show up in the POSIX
> compliance list and add it to your project if you like.
> On a vaguely related note, there is the open POSIX test suite (
> http://posixtest.sourceforge.net/) and glibc's test suite. In theory they
> should be able to run against RTEMS. In practice, I have no idea if or how
> hard it would be to get them to run and to investigate failures to mark
> some as expected. Some test frameworks assume fork and exec. Just throwing
> this out.
>> Thanks
>> -Eshan
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200329/f091ade5/attachment.html>
