Odd Behavior on Cygwin
Wed May 6 05:49:48 UTC 2020
On 6/5/20 3:46 am, Joel Sherrill wrote:
> I have a test sweep going on Cygwin and there are a couple of oddities I
> would like some advice on:
> 1. It appears that the same command I used on Linux and FreeBSD is not
> managing to get mail to the build@ list. Any ideas?
What is the detailed error reported in the log or output? What does the
mail server think is happening?
> ../source-builder/sb-set-builder --mail --mail-to=build at rtems.org
> <mailto:build at rtems.org> --mail-from=joel at rtems.org
> <mailto:joel at rtems.org> --keep-going --log=l-aarch64-5.txt
> --prefix=/home/jrs007/rtems-cron-5.0.0-m2005-1/tools/5 5/rtems-aarch64
It is a python only SMTP client and should be portable.
> 2. $HOME in a script being nohup'ed was being replaced with
> c:/msys64/.... and not /home/... . Any idea what this was an indication
> of? When I ran the script directly, the expansion was as expected. I
> can't seem to reproduce this in a small test case. Any suggestions?
Not really, this is the sort of stuff that makes using cygwin hard. Is
your path clean and only using cygwin executables?
> The build sweep is going (slowly as expected) and it is on the second
> tool target. It will take a long time (as in days) to finish.
Thanks
