80 or 79 characters limit?
Joel Sherrill
joel at rtems.org
Thu Nov 5 20:14:11 UTC 2020
I tried at one point to figure out how to script the changes when I ran
into them.
But it was easier to fix them by hand. If you have a simple script, it
would be good
to have a home for it. We could grow it then.
Not accepting unicode should be checked for patches and should be in
Coding Conventions.
I think you made a couple of bad mapping choices.
- "(r)" for the registered symbol (circle R)
- "u" for the micro Greek letter in usec and us (which is strange for usec)
Some I have no idea about.
+ aes.c - absolutely no idea
+ rtl22xx/console/uart.c - maybe an x
+ powerpc/include/mpc83xx/mpc83xx.h - maybe an x
I think a patch series doing copyright symbols, (r), and u for micro
as individual changes would eliminate a lot and not be controversial.
That should leave the remaining for a second pass.
One patch per character change is safer to review.
--joel
On Thu, Nov 5, 2020 at 1:34 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Joel,
> On 05/11/2020 20:15, Joel Sherrill wrote:
> > On Thu, Nov 5, 2020, 1:12 PM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> > Hello Joel and Sebastian,
> > On 05/11/2020 16:44, Joel Sherrill wrote:
> > > On Thu, Nov 5, 2020, 9:26 AM Sebastian Huber
> > > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>
> > <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > > Hello,
> > > I review currently the Coding Conventions. Should the 80
> > characters
> > > limit be really a 79 characters limit with the \n as the
> > invisible 80th
> > > character?
> > > Yes.
> > > As old as this makes me feel, I remember printers which did an
> > automatic
> > > linefeed and then the newline one if you hit column 80. So it
> > really is
> > > 79 unfortunately.
> > I don't think printers with an automatic linefeed are a common use
> case
> > for reading the RTEMS source code nowadays. So that maybe isn't the
> best
> > reason for using 79 characters.
> > +1
> > I would suggest to use the same convention that most coding styles
> use
> > which seems to be 80 characters:
> > https://en.wikipedia.org/wiki/Characters_per_line#In_programming
> > At least if there are no more recent examples for tools or editors
> where
> > 79 is a benefit. 80 seems just feels a bit more natural.
> > By the way: If we count '\n': Should we count a tab '\t' as a single
> > character, as 2, as 4 or as 8 ones?
> > We shouldn't have tabs in code we own.
> Good point.
> > What about the few Unicode
> > characters that slipped in over the years?
> > We also shouldn't have unicode characters randomly floating around. They
> > tend to pop up in my experience when people copy from word processors
> > and get fancy quotes. Those cases should be eliminated
> Last time I stumbled across a tool that didn't like unicode characters I
> found about 75 lines in RTEMS with unicode characters. I have been to
> lazy to fix them back then. Mostly because some of them would have
> needed some thought about what there should have been (I assume it has
> been a microsecond in some cases, but still not sure). Attached you can
> find a patch that should replaces most of them without much thought
> about the content. If you think it's useful, I can polish it up a bit.
> Best regards
> Christian
> > Best regards
> > Christian
> > > embedded brains GmbH
> > > Sebastian HUBER
> > > Dornierstr. 4
> > > 82178 Puchheim
> > > Germany
> > > email: sebastian.huber at embedded-brains.de
> > > Phone: +49-89-18 94 741 - 16
> > > Fax: +49-89-18 94 741 - 08
> > > PGP: Public key available on request.
> > > Registergericht: Amtsgericht München
> > > Registernummer: HRB 157899
> > > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen,
> > Thomas Dörfler
> > > Unsere Datenschutzerklärung finden Sie hier:
> > > https://embedded-brains.de/datenschutzerklaerung/
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org <mailto:devel at rtems.org>
> > <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> > > http://lists.rtems.org/mailman/listinfo/devel
> > > devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201105/898d94c0/attachment.html>
