[PATCH rtems v3 3/7] cpu/armv7m: Add table based init for ARMV7M_MPU
Gedare Bloom
gedare at rtems.org
Thu Nov 19 22:19:51 UTC 2020
On Thu, Nov 19, 2020 at 1:19 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> On 19/11/2020 21:14, Gedare Bloom wrote:
> > On Thu, Nov 19, 2020 at 1:13 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Sebastian, Christian:
> >> I saw the req
> > Oops, gmail shortcuts cut me off.
> > I saw the request to change the names, but I think the _ARMV7M_MPU_yyy
> > is correct, because MPU is the capitalized first "word" of the
> > subgroup there. It is consistent with the naming of other
> > _ARMV7M_Xxx_yyy routines.
> But there is for example
> _ARMV7M_NVIC_Is_enabled
> _ARMV7M_NVIC_Set_enable
> _ARMV7M_DWT_Enable_CYCCNT
> ARMV7M_MPU_Access_permissions
> and some others in the same file. So I would lean towards what Sebastian
> suggested. Otherwise the new functions wouldn't fit the scheme of the
> existing ones.
OK, I don't think those are proper, but consistency is good. You can
proceed with the MPU_Xxx
> >> On Thu, Nov 19, 2020 at 3:17 AM Christian Mauderer
> >> <christian.mauderer at embedded-brains.de> wrote:
> >>> Am 19.11.20 um 10:22 schrieb Christian Mauderer:
> >>>> Am 19.11.20 um 10:15 schrieb Sebastian Huber:
> >>>>> On 19/11/2020 09:51, Christian Mauderer wrote:
> >>>>>> + mpu = _ARMV7M_MPU;
> >>>>>> + scb = _ARMV7M_SCB;
> >>>>>> + scb->shcsr &= ~ARMV7M_SCB_SHCSR_MEMFAULTENA;
> >>>>> I think it is not necessary to touch the shcsr. Disabling the MPU
> >>>>> should be enough.
> >>>> OK. I'll try it on the imxrt.
> >>> Seems to be no problem to remove that line. I'll do that before pushing.
> >>>>>> + mpu->ctrl = 0;
> >>>>>> + _ARM_Data_synchronization_barrier();
> >>>>>> + _ARM_Instruction_synchronization_barrier();
> >>> embedded brains GmbH
> >>> Christian MAUDERER
> >>> Dornierstr. 4
> >>> 82178 Puchheim
> >>> Germany
> >>> email: christian.mauderer at embedded-brains.de
> >>> Phone: +49-89-18 94 741 - 18
> >>> Fax: +49-89-18 94 741 - 08
> >>> PGP: Public key available on request.
> >>> Registergericht: Amtsgericht München
> >>> Registernummer: HRB 157899
> >>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> >>> Unsere Datenschutzerklärung finden Sie hier:
> >>> https://embedded-brains.de/datenschutzerklaerung/
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
