[PATCH] rtems: Delete rtems_object_id_api_maximum_class()
Sebastian Huber
Mon Nov 23 08:50:05 UTC 2020
On 20/11/2020 19:45, Sebastian Huber wrote:
> On 20/11/2020 18:56, Joel Sherrill wrote:
>> It should be implemented. File a ticket if you don't want to do it now.
>> But don't delete it. It should be there for completeness. I would
>> have thought there was code that iterated over all the APIs and
>> classes and used it. What is being used instead?
> This function was added by
> commit 6c06288f6452da96fa630f1482aeaaba5d217531
> Author: Joel Sherrill <joel.sherrill at OARcorp.com>
> Date: Tue Jan 29 21:52:21 2008 +0000
> 2008-01-29 Joel Sherrill <joel.sherrill at oarcorp.com>
> * itron/src/exd_tsk.c, itron/src/task.c,
> libmisc/capture/capture.c,
> libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
> libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
> libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
> libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
> posix/src/pthreadexit.c, rtems/Makefile.am,
> rtems/preinstall.am,
> rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
> rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
> rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
> rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
> rtems/src/signalmp.c, rtems/src/taskdelete.c,
> rtems/src/taskmp.c,
> rtems/src/timerserver.c, score/Makefile.am,
> score/include/rtems/score/object.h,
> score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
> score/src/objectgetnameasstring.c,
> score/src/threadqextractwithproxy.c: Add new Object Services
> collection. This changed the name of a few previously
> public but
> undocumented services and added a some new services.
> * rtems/include/rtems/rtems/object.h,
> rtems/src/rtemsbuildid.c,
> rtems/src/rtemsbuildname.c,
> rtems/src/rtemsobjectapimaximumclass.c,
> rtems/src/rtemsobjectapiminimumclass.c,
> rtems/src/rtemsobjectgetapiclassname.c,
> rtems/src/rtemsobjectgetapiname.c,
> rtems/src/rtemsobjectgetclassicname.c,
> rtems/src/rtemsobjectgetclassinfo.c,
> rtems/src/rtemsobjectidapimaximum.c,
> rtems/src/rtemsobjectidapiminimum.c,
> rtems/src/rtemsobjectidgetapi.c,
> rtems/src/rtemsobjectidgetclass.c,
> rtems/src/rtemsobjectidgetindex.c,
> rtems/src/rtemsobjectidgetnode.c,
> rtems/src/rtemsobjectsetname.c,
> score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
> score/src/objectgetinfoid.c, score/src/objectsetname.c:
> New files.
> * rtems/src/rtemsidtoname.c: Removed.
> Nobody noticed that this function is missing in the last twelve years.
> What is the differences to:
> * @brief Get Highest Valid Class Value
> * This method returns the highest valid value Class for the
> * specified @a api. Each API supports a different number
> * of object classes.
> * @param[in] api is the API to obtain the maximum class of
> * @retval This method returns the greatet valid value for
> * class number for the specified @a api.
> int rtems_object_api_maximum_class(
> int api
> To me the removed function looks like some fragment left over from
> development.
We have also this patch which changes the similar
rtems_object_id_api_minimum_class() in rtems_object_api_minimum_class():
commit fdc57ca4b6794dc17c7b7d94ae557da21e314d6a
Date: Mon Nov 23 14:53:04 2009 +0000
2009-11-23 Joel Sherrill <joel.sherrill at oarcorp.com>
PR 1460/cpukit
rtems/src/rtemsobjectidgetnode.c: Change return type on methods
accessing portions of RTEMS Ids to int. This allows -1 to
be return
on error.
diff --git a/cpukit/rtems/include/rtems/rtems/object.h
b/cpukit/rtems/include/rtems/rtems/object.h
index d419a3b095..5a6e97189a 100644
--- a/cpukit/rtems/include/rtems/rtems/object.h
+++ b/cpukit/rtems/include/rtems/rtems/object.h
@@ -249,15 +249,32 @@ rtems_status_code rtems_object_set_name(
- * @param[in] api is the API to obtain the maximum class of
+ * @param[in] api is the API to obtain the minimum class of
* @return This method returns the least valid value for
-uint32_t rtems_object_id_api_minimum_class(
- uint32_t api
+int rtems_object_api_minimum_class(
+ int api
We have a rtems_object_api_maximum_class(). Maybe you forgot to remove
the rtems_object_id_api_maximum_class() in this patch?
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
