[PATCH v1] tester: Prevent crash with json output
Mon Oct 5 23:26:17 UTC 2020
On 6/10/20 9:35 am, Kinsey Moore wrote:
> *From:* Joel Sherrill <joel at rtems.org>
> *Sent:* Monday, October 5, 2020 17:03
> *To:* Chris Johns <chrisj at rtems.org>
> *Cc:* Kinsey Moore <kinsey.moore at oarcorp.com>; rtems-devel at rtems.org
> <devel at rtems.org>
> *Subject:* Re: [PATCH v1] tester: Prevent crash with json output
> On Mon, Oct 5, 2020 at 4:57 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 6/10/20 7:41 am, Kinsey Moore wrote:
>     > This fixes an issue with json report output that causes a crash due to
>     > the incorrect object member being accessed for test-too-long. This also
>     > changes treatment of fatal errors to match how they are displayed in the
>     > tester log output and changes "fatal error" to "fatal-error" to better
>     > match the naming of all the other failure types.
>     >  tester/rt/report.py | 2 +-
>     >  tester/rt/test.py   | 9 ++++++---
>     >  2 files changed, 7 insertions(+), 4 deletions(-)
>     OK to push. Thanks.
> I'm OK to push this but should it also have a  ticket and go to 5?
> I'm sure that's the question Kinsey wants to hear. :)
> This was necessary due to a change that didn’t go into 5, so it really shouldn’t
> go into 5, either
Agreed, 5 does not have the test too long support.
