[PATCH v1] tester: Prevent crash with json output
Tue Oct 6 00:00:13 UTC 2020
Pushed.
On Mon, Oct 5, 2020 at 6:26 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/10/20 9:35 am, Kinsey Moore wrote:
> > *From:* Joel Sherrill <joel at rtems.org>
> > *Sent:* Monday, October 5, 2020 17:03
> > *To:* Chris Johns <chrisj at rtems.org>
> > *Cc:* Kinsey Moore <kinsey.moore at oarcorp.com>; rtems-devel at rtems.org
> > <devel at rtems.org>
> > *Subject:* Re: [PATCH v1] tester: Prevent crash with json output
> > On Mon, Oct 5, 2020 at 4:57 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     On 6/10/20 7:41 am, Kinsey Moore wrote:
> >     > This fixes an issue with json report output that causes a crash
> due to
> >     > the incorrect object member being accessed for test-too-long. This
> also
> >     > changes treatment of fatal errors to match how they are displayed
> in the
> >     > tester log output and changes "fatal error" to "fatal-error" to
> better
> >     > match the naming of all the other failure types.
> >     >  tester/rt/report.py | 2 +-
> >     >  tester/rt/test.py   | 9 ++++++---
> >     >  2 files changed, 7 insertions(+), 4 deletions(-)
> >     OK to push. Thanks.
> > I'm OK to push this but should it also have a  ticket and go to 5?
> > I'm sure that's the question Kinsey wants to hear. :)
> > This was necessary due to a change that didn’t go into 5, so it really
> shouldn’t
> > go into 5, either
> Agreed, 5 does not have the test too long support.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/7e298d37/attachment.html>
