Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
Joel Sherrill
joel at rtems.org
Wed Oct 14 15:27:15 UTC 2020
On Wed, Oct 14, 2020 at 10:20 AM Sebastian Huber <
> On 14/10/2020 17:17, Joel Sherrill wrote:
> > On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 14/10/2020 15:35, Joel Sherrill wrote:
> > > BSP builder has 81 failures. :(
> > It tried to build BSPs which no longer exist.
> > Well that is an easier thing to fix than my concern that it was related
> to
> > giving errors when a BSP does not support a feature. I suppose that will
> > show up when the bsp builder switches to waf.
> > Can you patch ./config/rtems-bsps-tiers.ini to reflect what you removed?
> We should try try to reduce the redundancy in our data sets. Why don't
> we record the tier status in the BSP items?
That's a Chris discussion when the builder is switched to using waf.
Can you just fix this for now? It builds with autoconf and there is a
ticket for it.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201014/fda74f08/attachment.html>
