Does anybody have the source code of rtems tools
Tue Oct 20 14:05:34 UTC 2020
I'm probably telling you something that you already know but you will
have to contact Edisoft about that. That site is not maintained by or
associated with RTEMS.org.
--joel
On Sun, Oct 18, 2020 at 9:46 PM smallphd at aliyun.com <smallphd at aliyun.com>
wrote:
> The main page is this:
> http://rtemscentre.edisoft.pt/index.php?module=Content&func=display&ceid=13&meid=-1
> My main target tool is "Core File Generation Tool" in "RTEMS Other Support
> Tools".
> The source code is open source, but it needs register and login to
> download code.
> After sending the register email for days, I get nothing reply.
> So does anybody download the tool previous? Would you like to share a copy
> with me ?
> Thank you very much!
> *RTEMS/Support Tools*
> The *RTEMS/Support Tools *developed in the scope of the *RTEMS Centre *
> are:
> *RTEMS Other Support Tools
> <http://rtemscentre.edisoft.pt/index.php?module=Content&func=display&ceid=22>*
>    - Core File Generation Tool:
>    This tool can generate a core file, from the contents of a raw memory
>    dump, which will then be loaded into GDB and show the user where the
>    application crashed.
>    - *Remote Debug Monitor Tool:*
>    This tool is an intrusive debugger (i.e., interrupts the normal code
>    execution in order to execute debug code) that acts like a server while
>    running on the target board and provides the means for software based
>    debugging over a serial line.
>    - *PROM Image Builder Tool:*
>    This is a tool that encapsulates the user application in an image file
>    that is ready to be burned into a boot PROM of an ERC32 or LEON system.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201020/d5137933/attachment.html>
