Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Thu Sep 3 04:29:10 UTC 2020
On 03/09/2020 01:03, Chris Johns wrote:
> On 3/9/20 2:18 am, Sebastian Huber wrote:
>> On 02/09/2020 18:10,buildbot at rtems.org  wrote:
>>> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD
>>> 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
>>> Full details are available at:
>>>       https://buildbot.rtems.org/#builders/20/builds/229
>>> Buildbot URL:https://buildbot.rtems.org/
>>> Worker for this Build: build-1
>>> Build Reason: <unknown>
>>> Blamelist: Sebastian Huber<sebastian.huber at embedded-brains.de>
>>> BUILD FAILED: make (failure)
>>> Sincerely,
>>>    -The Buildbot
>> This build error is due to a problem which is later fixed in the same patch set.
>> I think buildbot should just report this commit as failing and then continue
>> with the next commit in the patch series.
> Please raise a ticket and assign it to Amar.
It seems buildbot already does this. It just took 10 minutes to send the
next result.
