Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Sebastian Huber
Mon Sep 21 05:22:40 UTC 2020
On 21/09/2020 06:59, buildbot at rtems.org wrote:
> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> Full details are available at:
> https://buildbot.rtems.org/#builders/20/builds/261
> Buildbot URL: https://buildbot.rtems.org/
> Worker for this Build: build-1
> Build Reason: <unknown>
> Blamelist: Gedare Bloom <gedare at rtems.org>, Sebastian Huber <sebastian.huber at embedded-brains.de>
> BUILD FAILED: failed make (failure)
I guess some scripts need to be adjusted to use the new build system.
The tools need also an update. I can do this if someone points me to
the scripts.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
