How to collect test output data using rtems-tester and telnet?
Cláudio Maia clrrm at isep.ipp.pt
Mon Sep 14 12:32:42 UTC 2020
Hello,
I am trying to get the output of "ser2net" (using telnet) inside rtems-tester but without success.
>From what I understood, by reading the documentation, to use telnet within rtems-tester I have to use the "bsp_tty_dev" option
butthere is no example there that shows how to achieve this functionality.
Can someone provide me with an example of how to connect the rtems-tester to a host using telnet?
Regards,
Cláudio Maia
