Strong APA scheduler testing
Richi Dubey
richidubey at gmail.com
Wed Sep 16 16:58:41 UTC 2020
Hi,
Sorry for the delay. My university tests were going on.
So, I reran the test only for smptestsuites, and I have attached the log.
The test says that smpfatal09 gives timeout, where when I ran the test with
qemu, I get the following output:
~/quick-start/rtems/5/bin$ ./qemu-system-arm -net none -nographic -M
realview-pbx-a9 -m 256M -kernel
~/quick-start/build/b3-realview/arm-rtems5/c/realview_pbx_a9_qemu/testsuites/smptests/smpfatal09.exe
-smp 4
*** BEGIN OF TEST SMPFATAL 9 ***
*** TEST VERSION: 6.0.0.cba933cb2260afc79c2a94d7c26bce1b58a7dbfd-modified
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib
fbaa096)
*** END OF TEST SMPFATAL 9 ***
*** FATAL ***
fatal source: 0 (INTERNAL_ERROR_CORE)
fatal code: 40 (INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA)
RTEMS version: 6.0.0.cba933cb2260afc79c2a94d7c26bce1b58a7dbfd-modified
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
executing thread is NULL
fbaa096)
*** FATAL ***
and so on ...
Also, I ran the qemu with gdb and I get the same result. Why does
rtems-test feel it is timeout? Is it because of the 200 s limit?
Please let me know.
On Sat, Sep 12, 2020 at 7:47 PM Richi Dubey <richidubey at gmail.com> wrote:
> Understood. I'm on it. I'll try to debug the scheduler related tests first
> i.e SMP tests if there are errors in them.
> On Fri, Sep 11, 2020 at 3:30 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Start at the end and work your way back.
>> The clean version reports:
>> Passed: 636
>> Failed: 1
>> User Input: 6
>> Expected Fail: 1
>> Indeterminate: 0
>> Benchmark: 3
>> Timeout: 3
>> Invalid: 5
>> Wrong Version: 1
>> Wrong Build: 0
>> Wrong Tools: 0
>> Total: 656
>> Your version reports:
>> Passed: 600
>> Failed: 22
>> User Input: 6
>> Expected Fail: 1
>> Indeterminate: 0
>> Benchmark: 3
>> Timeout: 16
>> Invalid: 6
>> Wrong Version: 0
>> Wrong Build: 0
>> Wrong Tools: 0
>> Total: 654
>> You'll want to poke at those failures first and triage them. Fixing
>> one may cascade to other tests, so rerun the testsuite after you try a
>> fix.
>> On Thu, Sep 10, 2020 at 12:59 PM Richi Dubey <richidubey at gmail.com>
>> wrote:
>> > Hi,
>> > Please find attached the log of rtems-test with the "clean" version
>> (Commit: 61ccb9c05d (HEAD, tag: 5.1, origin/5) bsp/xilinx-zynq: Flush
>> TX-Buffer before initializing uar) vs my Strong APA changes (with name
>> log_leon3_sis_strong_apa).
>> > I haven't looked at the log in detail yet, but please let me know if
>> there's anything odd that sparks interest.
>> > Thanks,
>> > Richi.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200916/eb0da048/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200916/eb0da048/attachment-0001.obj>
