[PATCH 1/2] Added FAQ page
Ayushman Mishra
ayushvidushi01 at gmail.com
Fri Apr 2 18:19:37 UTC 2021
Greetings Sir,
I have corrected and send patches regarding FAQ page in user manual.I
was able to build the page on my system and also attached a
screen-shot of the builded page on browser . I have corrected
whitespace consistency and reference links according to other
doc-pages . Regarding the issue of cross-link between docs , I had
sent mail on devel mail list
https://lists.rtems.org/pipermail/devel/2021-March/065882.html but
haven't got any response , so few days ago after a little discussion
on discord vijay sir said to post the patch and someone might point it
to a better way if it exists.
On Wed, Mar 24, 2021 at 1:05 AM Gedare Bloom <gedare at rtems.org> wrote:
> Did you build the docs and verify they look good?
> On Tue, Mar 23, 2021 at 12:44 PM Ayushman Mishra
> <ayushvidushi01 at gmail.com> wrote:
> > user/bld/index.rst | 4 +-
> > user/overview/index.rst | 2 +
> > user/start/faq.rst | 255 +++++++++++++++++++++++++++++++
> > user/start/index.rst | 1 +
> > user/support/support-project.rst | 2 +
> > 5 files changed, 263 insertions(+), 1 deletion(-)
> > create mode 100644 user/start/faq.rst
> > diff --git a/user/bld/index.rst b/user/bld/index.rst
> > index ebedf5a..a8a8a4f 100644
> > --- a/user/bld/index.rst
> > +++ b/user/bld/index.rst
> > @@ -82,7 +82,7 @@ specifies paths to build specification items. It is an advanced option and
> > there is normally no need to use it. It may be used to customize the build at
> > the level of the build specification. For more information see the
> > `Build System` chapter of the
> > -`RTEMS Software Engineering <https://docs.rtems.org/branches/master/eng/build-system.rst>`_
> > +`RTEMS Software Engineering <https://docs.rtems.org/branches/master/eng/build-system.html>`_
> > guide.
> > Help
> > @@ -283,6 +283,8 @@ example configuration file, building of the tests is enabled for the
> > [sparc/erc32]
> > [riscv/griscv]
> > +.. _Autoconf_migration:
> this looks like something should be a cleanup separate submission.
> I think the tags are usually directly translated from the section
> names with camelcase?
> _Migration_from_AutoconfAutomake
> or so? check other docs for consistency/guidance.
> > Migration from Autoconf/Automake
> > diff --git a/user/overview/index.rst b/user/overview/index.rst
> > index 550724a..0703ede 100644
> > --- a/user/overview/index.rst
> > +++ b/user/overview/index.rst
> > @@ -20,6 +20,8 @@ You are someone looking for a real-time operating system. This document
> > - helps you to build an example application on top of RTEMS.
> > +.. _Features:
> > Features
> > diff --git a/user/start/faq.rst b/user/start/faq.rst
> > new file mode 100644
> > index 0000000..da11ca4
> > --- /dev/null
> > +++ b/user/start/faq.rst
> > @@ -0,0 +1,255 @@
> > +Frequently Asked Questions
> > +What is RTEMS ?
> > +RTEMS is an open source real-time executive which provides a high performance
> > +environment for embedded real-time applications including many features.
> > +The RTEMS Project is the umbrella term used to describe the collection of
> > +individuals, companies, universities, and research institutions that collectively
> > +maintain and enhance the RTEMS software base.
> > +RTEMS is designed to support applications with the most stringent real-time
> > +requirements while being compatible with open standards such as POSIX.
> > +RTEMS includes optional functional features such as TCP/IP and various file
> > +systems while still offering minimum executable sizes under 20 KB in useful
> > +configurations.
> > +:ref:`More Features<Features>`
> > +Where can I get RTEMS ?
> > +:ref:`Downloading RTEMS<QuickStartSources_Released>`
> > +What does RTEMS stand for ?
> > +RTEMS is an an acronym for the Real-Time Executive for Multiprocessor Systems.
> an an
> > +Initially RTEMS stood for the Real-Time Executive for Missile Systems but as it
> > +became clear that the application domains that could use RTEMS extended far
> > +beyond missiles, the "M" changed to mean Military. When maintenance of RTEMS
> > +transferred to OAR, the "M" was changed again to Multiprocessor.
> > +At one point, there were both Ada and C implementations of RTEMS.
> > +Version 3.2.1 was the last RTEMS version to have implementations in both
> > +languages. Supporting the Classic API Ada implementation was painful and fraught
> > +with compiler specific pitfalls. With version 3.5.x, the POSIX API was added as
> > +the means to support the GNU Ada Translator (GNAT). This effectively eliminated
> > +the need for an implementation in Ada as the C implementation could effectively
> > +support both languages.
> > +Are there restrictions on the RTEMS License ?
> > +RTEMS is licensed under a modified version of the GNU General Public License (GPL).
> > +The modification places no restrictions on the applications which use RTEMS but
> > +protects the interests of those who work on RTEMS.
> This needs to be updated at least to mention 2-clause BSD.
> RTEMS is licensed under a combination of permissive licenses and
> > +`License in RTEMS
> > +<https://docs.rtems.org/branches/master/eng/
> > +license-requirements.html>`__
> I think just 1 blank space?
> > +What standards are supported by RTEMS?
> > +The original "Classic" RTEMS API is based on the Real-Time Executive Interface
> > +Definition (RTEID) and the Open Real-Time Kernel Interface Definition (ORKID).
> > +RTEMS also includes support for POSIX threads and real-time extensions.
> > +With the addition of file system infrastructure, RTEMS supports approximately
> > +80% of the POSIX 1003.1b-1996 standard. This standard defines the programming
> > +interfaces of standard UNIX. This means that much source code that works on
> > +UNIX, also works on RTEMS.RTEMS includes a port of the FreeBSD TCP/IP stack and
> > +thus supports BSD sockets. It also includes support for numerous networking
> > +clients (DHCP, TFTP, NFS, etc.) and servers (FTPD, HTTPD, etc.).
> > +What processors is RTEMS available for ?
> > +:ref:`Architectures in RTEMS<TargetArchitectures>`
> definitely not 3 blank lines though. check other docs for whitespace consistency
> > +Are there similar commercial products ?
> > +`Some Real time operating system similar to RTEMS
> > +<https://en.wikipedia.org/wiki/Comparison_of_real-time_operating_systems>`__
> > +How can I obtain RTEMS support ?
> > +:ref:`Support in RTEMS<Support_project>`
> > +What RTEMS Training Opportunities are available ?
> > +`RTEMS Training Opportunities <https://www.rtems.org/TrainingOpportunities>`__
> > +How can I contribute?
> > +:ref:`Contributions in RTEMS<Contributing>`
> > +How are floating point numbers handled ?
> > +`Floating point support in RTEMS
> > +<https://docs.rtems.org/branches/master/c-user/task/
> > +background.html#floating-point-considerations>`__
> We don't like to cross-link between docs. I don't remember how this is
> handled. If you can't figure it out, you'll have to ask in an email
> how to link between different manuals in the docs.
> > +How do I make a patch ?
> This should refer to the Software Engineering Guide.
> > +The recommended way to create a patch is to branch the git repository master
> > +and use one commit for each logical change. Then you can use git-format-patch
> > +to turn your commits into patches and easily submit them.
> > +.. code-block:: none
> > + git format-patch master
> > +Creates a separate patch for each commit that has been made between the master
> > +branch and the current branch and writes them in the current directory. Use
> > +the -o flag to redirect the files to a different directory.
> > +If you are re-submitting a patch that has previously been reviewed, you should
> > +specify a version number for your patch, for example, use
> > + git format-patch -v2 ...
> > +to indicate the second version of a patch, v3 for a third, and so forth.
> > +Patches created using git-format-patch are formatted so they can be emailed
> > +and rely on having git configured with your name and email address, for example
> > + git config --global user.name "Your Name"
> > + git config --global user.email name at domain.com
> > +Please use a real name, we do not allow pseudonyms or anonymous contributions.
> > +Why is my executable so big?
> > +There are two primary causes for this. The most common is that you are doing an
> > +ls -l and looking at the actual file size – not the size of the code in the
> > +target image. This file could be in an object format such as ELF or COFF and
> > +contain debug information. If this is the case, it could be an order of magnitude
> > +larger than the required code space. Use the strip command in your cross
> > +toolset to remove debugging information.
> > +Another alternative is that the executable file is in an ASCII format such as
> > +Motorola Srecords. In this case, there is no debug information in the file
> > +but each byte in the target image requires two bytes to represent. On top of
> > +that, there is some overhead required to specify the addresses where the image
> > +is to be placed in target memory as well as checksum information. In this
> > +case, it is not uncommon to see executable files that are between two and three
> > +times larger than the actual space required in target memory.
> > +Remember, the debugging information is required to do symbolic debugging with gdb.
> > +Normally gdb obtains its symbolic information from the same file that it gets
> > +the exe- cutable image from. However, gdb does not require that the executable
> > +image and symbolic information be obtained from the same file. So you might want
> > +to create a hello_with_ symbols.exe, copy that file to hello_without_symbols.exe,
> > +and strip hello_without_ symbols.exe. Then gdb would have to be told to read
> > +symbol information from hello_ with_symbols.exe. The gdb command line option
> > +-symbols or command symbol-file may be used to specify the file read for
> > +symbolic information
> > +What MinGW Tools for Windows are available ?
> > +Windows users can use MinGW based RTEMS tools. These tools will generate the
> > +same application code for RTEMS as the tools on Linux or Cygwin. MinGW tools
> > +use the native Windows runtime rather than access Windows via the POSIX interface
> > +Cygwin provides. MinGW tools are faster than the Cygwin equivalent and are not
> > +confused by Cygwin mount points. Compiler errors will show a Windows path rather
> > +than a Cygwin path and so do not confuse native Windows editors.
> > +:ref:`Cygwin in windows<Cygwin>`
> > +The RTEMS MinGW Tools are not currently packaged in installers. The installers
> > +stopped around RTEMS 4.9 when the MinGW tools started to be built as part of
> > +the binary tool package. This means you need to manually step through the
> > +process. It is not difficult, how-ever it is not an easy installer.
> > +What is Multilib RTEMS ?
> > +The multilib process supports building a set of related libraries for a given
> > +target where the individual libraries in the set use different specific
> > +compiler flags (such as flags for code generation options, pre-processor
> > +defines, etc) for the individual libraries. The reason this is needed can be
> > +seen by examining the M68K GCC compiler. That compiler generates code for a
> > +number of processor variants in the M68K family, for example, it can generate
> > +code for the original 68000, the 68040 or a 528x Coldfire. These processors all
> > +use a closely related instruction set, but processor differences mean code
> > +compiled for one may not run on another. GCC provides a special library called
> > +libgcc.a that holds intrinsic functions needed by the compiler. These
> > +intrinsic functions provide "software instructions" (such as non-basic math
> > +support routines) that the processor may not support. However, which functions
> > +GCC considers to be intrinsic should be able to vary within a processor family.
> > +One processor variant will have hardware floating point and another processor
> > +variant will not, and GCC (and RTEMS) should be able to generate efficient code
> > +for each processor variant. When we wish to have different code for a range of
> > +related yet potentially incompatible processors in a family by providing
> > +multiple related libraries we use the multilib process.
> > +The multilib process extends beyond libgcc.a to libc.a, libm.a, and libstd++.a.
> > +An RTEMS tool set will provide each of these libraries for each of the processor
> > +variants that GCC supports. You can see the multilib information by invoking gcc
> > +with the option '-print-multi-lib'. The output for the M68K tool chain is -
> > + $ m68k-rtems-gcc -print-multi-lib .; m68000;@m68000 m5200;@m5200
> > + m5206e;@m5206e m528x;@m528x m5307;@m5307 m5407;@m5407 mcpu32;@mcpu32
> > + m68040;@m68040 m68060;@m68060 msoft-float;@msoft-float
> > +This output is not easy to read as it is designed for other tools or packages.
> > +RTEMS core under the cpukit source tree does not reference any BSP specific
> > +details. This allows it to be built as a set of multiple libraries named
> > +librtemscpu.a. A configure command line option will build a multilib RTEMS as
> > +shown in Building a CPU Kit.
> > +BSP and CPU model specific portions of RTEMS (libcpu and libbsp) are
> > +built into the separate library librtemsbsp.a.
> > +What is the difference between the workspace and heap ?
> > +The RTEMS Workspace is used to allocate space for objects created by RTEMS
> > +such as tasks, semaphores, message queues, etc.. It is primarily used during
> > +system initialization although task stacks and message buffer areas are also
> > +allocated from here.
> > +What is the difference between autoconf and waf build system ?
> > +Waf is a build automation tool written in Python which is designed to assist
> > +in the automatic compilation and installation of computer software.
> > +:ref:`Converting from Autoconf/Automake to waf build system<Autoconf_migration>`
> > diff --git a/user/start/index.rst b/user/start/index.rst
> > index 17c34e1..e178209 100644
> > --- a/user/start/index.rst
> > +++ b/user/start/index.rst
> > @@ -23,3 +23,4 @@ applications on top of RTEMS.
> > app
> > rsb-packages
> > gsoc
> > + faq
> > diff --git a/user/support/support-project.rst b/user/support/support-project.rst
> > index b782029..9973f5a 100644
> > --- a/user/support/support-project.rst
> > +++ b/user/support/support-project.rst
> > @@ -6,6 +6,8 @@
> > .. index:: support; RTEMS Project
> > +.. _Support_project:
> > RTEMS Project Support
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210402/f6a46354/attachment-0001.png>
