[PATCH 1/2] Added FAQ page
Fri Apr 2 18:40:06 UTC 2021
On Fri, Apr 2, 2021 at 1:19 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Greetings Sir,
> I have corrected and send patches regarding FAQ page in user manual.I
> was able to build the page on my system and also attached a
> screen-shot of the builded page on browser . I have corrected
> whitespace consistency and reference links according to other
> doc-pages
Random question. Is this information from the Wiki or just an update
of what was already in rtems-docs? If this obsoletes any information
in the wiki, I would like to know so we can remove it.
> . Regarding the issue of cross-link between docs , I had
> sent mail on devel mail list
> https://lists.rtems.org/pipermail/devel/2021-March/065882.html but
> haven't got any response , so few days ago after a little discussion
> on discord vijay sir said to post the patch and someone might point it
> to a better way if it exists.
I don't know if we know the answer to that with Sphinx. If "we" do, then
I am not part of that "we".  Hopefully someone will educate us. :)
Gedare.. is the new patch OK? It must be in another thread because
I don't see it here.
--joel
> On Wed, Mar 24, 2021 at 1:05 AM Gedare Bloom <gedare at rtems.org> wrote:
> > Did you build the docs and verify they look good?
> > On Tue, Mar 23, 2021 at 12:44 PM Ayushman Mishra
> > <ayushvidushi01 at gmail.com> wrote:
> > >  user/bld/index.rst               |   4 +-
> > >  user/overview/index.rst          |   2 +
> > >  user/start/faq.rst               | 255 +++++++++++++++++++++++++++++++
> > >  user/start/index.rst             |   1 +
> > >  user/support/support-project.rst |   2 +
> > >  5 files changed, 263 insertions(+), 1 deletion(-)
> > >  create mode 100644 user/start/faq.rst
> > > diff --git a/user/bld/index.rst b/user/bld/index.rst
> > > index ebedf5a..a8a8a4f 100644
> > > --- a/user/bld/index.rst
> > > +++ b/user/bld/index.rst
> > > @@ -82,7 +82,7 @@ specifies paths to build specification items.  It is
> an advanced option and
> > >  there is normally no need to use it.  It may be used to customize the
> build at
> > >  the level of the build specification.  For more information see the
> > >  `Build System` chapter of the
> > > -`RTEMS Software Engineering <
> https://docs.rtems.org/branches/master/eng/build-system.rst>`_
> > > +`RTEMS Software Engineering <
> https://docs.rtems.org/branches/master/eng/build-system.html>`_
> > >  guide.
> > >  Help
> > > @@ -283,6 +283,8 @@ example configuration file, building of the tests
> is enabled for the
> > >      [sparc/erc32]
> > >      [riscv/griscv]
> > > +.. _Autoconf_migration:
> > this looks like something should be a cleanup separate submission.
> > I think the tags are usually directly translated from the section
> > names with camelcase?
> > _Migration_from_AutoconfAutomake
> > or so? check other docs for consistency/guidance.
> > >  Migration from Autoconf/Automake
> > > diff --git a/user/overview/index.rst b/user/overview/index.rst
> > > index 550724a..0703ede 100644
> > > --- a/user/overview/index.rst
> > > +++ b/user/overview/index.rst
> > > @@ -20,6 +20,8 @@ You are someone looking for a real-time operating
> system.  This document
> > >  - helps you to build an example application on top of RTEMS.
> > > +.. _Features:
> > >  Features
> > > diff --git a/user/start/faq.rst b/user/start/faq.rst
> > > new file mode 100644
> > > index 0000000..da11ca4
> > > --- /dev/null
> > > +++ b/user/start/faq.rst
> > > @@ -0,0 +1,255 @@
> > > +Frequently Asked Questions
> > > +What is RTEMS ?
> > > +RTEMS is an open source real-time executive which provides a high
> performance
> > > +environment for embedded real-time applications including many
> features.
> > > +The RTEMS Project is the umbrella term used to describe the
> collection of
> > > +individuals, companies, universities, and research institutions that
> collectively
> > > +maintain and enhance the RTEMS software base.
> > > +RTEMS is designed to support applications with the most stringent
> real-time
> > > +requirements while being compatible with open standards such as POSIX.
> > > +RTEMS includes optional functional features such as TCP/IP and
> various file
> > > +systems while still offering minimum executable sizes under 20 KB in
> useful
> > > +configurations.
> > > +:ref:`More Features<Features>`
> > > +Where can I get RTEMS ?
> > > +:ref:`Downloading RTEMS<QuickStartSources_Released>`
> > > +What does RTEMS stand for ?
> > > +RTEMS is an an acronym for the Real-Time Executive for Multiprocessor
> Systems.
> > an an
> > > +Initially RTEMS stood for the Real-Time Executive for Missile Systems
> but as it
> > > +became clear that the application domains that could use RTEMS
> extended far
> > > +beyond missiles, the "M" changed to mean Military. When maintenance
> of RTEMS
> > > +transferred to OAR, the "M" was changed again to Multiprocessor.
> > > +At one point, there were both Ada and C implementations of RTEMS.
> > > +Version 3.2.1 was the last RTEMS version to have implementations in
> both
> > > +languages. Supporting the Classic API Ada implementation was painful
> and fraught
> > > +with compiler specific pitfalls. With version 3.5.x, the POSIX API
> was added as
> > > +the means to support the GNU Ada Translator (GNAT). This effectively
> eliminated
> > > +the need for an implementation in Ada as the C implementation could
> effectively
> > > +support both languages.
> > > +Are there restrictions on the RTEMS License ?
> > > +RTEMS is licensed under a modified version of the GNU General Public
> License (GPL).
> > > +The modification places no restrictions on the applications which use
> RTEMS but
> > > +protects the interests of those who work on RTEMS.
> > This needs to be updated at least to mention 2-clause BSD.
> > RTEMS is licensed under a combination of permissive licenses and
> > a modified version of the GNU General Public License (GPL).
> > > +`License in RTEMS
> > > +<https://docs.rtems.org/branches/master/eng/
> > > +license-requirements.html>`__
> > I think just 1 blank space?
> > > +What standards are supported by RTEMS?
> > > +The original "Classic" RTEMS API is based on the Real-Time Executive
> Interface
> > > +Definition (RTEID) and the Open Real-Time Kernel Interface Definition
> (ORKID).
> > > +RTEMS also includes support for POSIX threads and real-time
> extensions.
> > > +With the addition of file system infrastructure, RTEMS supports
> approximately
> > > +80% of the POSIX 1003.1b-1996 standard. This standard defines the
> programming
> > > +interfaces of standard UNIX. This means that much source code that
> works on
> > > +UNIX, also works on RTEMS.RTEMS includes a port of the FreeBSD TCP/IP
> stack and
> > > +thus supports BSD sockets. It also includes support for numerous
> networking
> > > +clients (DHCP, TFTP, NFS, etc.) and servers (FTPD, HTTPD, etc.).
> > > +What processors is RTEMS available for ?
> > > +:ref:`Architectures in RTEMS<TargetArchitectures>`
> > definitely not 3 blank lines though. check other docs for whitespace
> consistency
> > > +Are there similar commercial products ?
> > > +`Some Real time operating system similar to RTEMS
> https://en.wikipedia.org/wiki/Comparison_of_real-time_operating_systems
> >`__
> > > +How can I obtain RTEMS support ?
> > > +:ref:`Support in RTEMS<Support_project>`
> > > +What RTEMS Training Opportunities are available ?
> > > +`RTEMS Training Opportunities <
> https://www.rtems.org/TrainingOpportunities>`__
> > > +How can I contribute?
> > > +:ref:`Contributions in RTEMS<Contributing>`
> > > +How are floating point numbers handled ?
> > > +`Floating point support in RTEMS
> > > +<https://docs.rtems.org/branches/master/c-user/task/
> > > +background.html#floating-point-considerations>`__
> > We don't like to cross-link between docs. I don't remember how this is
> > handled. If you can't figure it out, you'll have to ask in an email
> > how to link between different manuals in the docs.
> > > +How do I make a patch ?
> > This should refer to the Software Engineering Guide.
> > > +The recommended way to create a patch is to branch the git repository
> master
> > > +and use one commit for each logical change. Then you can use
> git-format-patch
> > > +to turn your commits into patches and easily submit them.
> > > +.. code-block:: none
> > > +    git format-patch master
> > > +Creates a separate patch for each commit that has been made between
> the master
> > > +branch and the current branch and writes them in the current
> directory. Use
> > > +the -o flag to redirect the files to a different directory.
> > > +If you are re-submitting a patch that has previously been reviewed,
> you should
> > > +specify a version number for your patch, for example, use
> > > +    git format-patch -v2 ...
> > > +to indicate the second version of a patch, v3 for a third, and so
> forth.
> > > +Patches created using git-format-patch are formatted so they can be
> emailed
> > > +and rely on having git configured with your name and email address,
> for example
> > > +    git config --global user.name "Your Name"
> > > +    git config --global user.email name at domain.com
> > > +Please use a real name, we do not allow pseudonyms or anonymous
> contributions.
> > > +Why is my executable so big?
> > > +There are two primary causes for this. The most common is that you
> are doing an
> > > +ls -l and looking at the actual file size – not the size of the code
> in the
> > > +target image. This file could be in an object format such as ELF or
> COFF and
> > > +contain debug information. If this is the case, it could be an order
> of magnitude
> > > +larger than the required code space. Use the strip command in your
> cross
> > > +toolset to remove debugging information.
> > > +Another alternative is that the executable file is in an ASCII format
> such as
> > > +Motorola Srecords. In this case, there is no debug information in the
> file
> > > +but each byte in the target image requires two bytes to represent. On
> top of
> > > +that, there is some overhead required to specify the addresses where
> the image
> > > +is to be placed in target memory as well as checksum information. In
> this
> > > +case, it is not uncommon to see executable files that are between two
> and three
> > > +times larger than the actual space required in target memory.
> > > +Remember, the debugging information is required to do symbolic
> debugging with gdb.
> > > +Normally gdb obtains its symbolic information from the same file that
> it gets
> > > +the exe- cutable image from. However, gdb does not require that the
> executable
> > > +image and symbolic information be obtained from the same file. So you
> might want
> > > +to create a hello_with_ symbols.exe, copy that file to
> hello_without_symbols.exe,
> > > +and strip hello_without_ symbols.exe. Then gdb would have to be told
> to read
> > > +symbol information from hello_ with_symbols.exe. The gdb command line
> option
> > > +-symbols or command symbol-file may be used to specify the file read
> for
> > > +symbolic information
> > > +What MinGW Tools for Windows are available ?
> > > +Windows users can use MinGW based RTEMS tools. These tools will
> generate the
> > > +same application code for RTEMS as the tools on Linux or Cygwin.
> MinGW tools
> > > +use the native Windows runtime rather than access Windows via the
> POSIX interface
> > > +Cygwin provides. MinGW tools are faster than the Cygwin equivalent
> and are not
> > > +confused by Cygwin mount points. Compiler errors will show a Windows
> path rather
> > > +than a Cygwin path and so do not confuse native Windows editors.
> > > +:ref:`Cygwin in windows<Cygwin>`
> > > +The RTEMS MinGW Tools are not currently packaged in installers. The
> installers
> > > +stopped around RTEMS 4.9 when the MinGW tools started to be built as
> part of
> > > +the binary tool package. This means you need to manually step through
> the
> > > +process. It is not difficult, how-ever it is not an easy installer.
> > > +What is Multilib RTEMS ?
> > > +The multilib process supports building a set of related libraries for
> a given
> > > +target where the individual libraries in the set use different
> specific
> > > +compiler flags (such as flags for code generation options,
> pre-processor
> > > +defines, etc) for the individual libraries. The reason this is needed
> can be
> > > +seen by examining the M68K GCC compiler. That compiler generates code
> for a
> > > +number of processor variants in the M68K family, for example, it can
> generate
> > > +code for the original 68000, the 68040 or a 528x Coldfire. These
> processors all
> > > +use a closely related instruction set, but processor differences mean
> code
> > > +compiled for one may not run on another. GCC provides a special
> library called
> > > +libgcc.a that holds intrinsic functions needed by the compiler. These
> > > +intrinsic functions provide "software instructions" (such as
> non-basic math
> > > +support routines) that the processor may not support. However, which
> functions
> > > +GCC considers to be intrinsic should be able to vary within a
> processor family.
> > > +One processor variant will have hardware floating point and another
> processor
> > > +variant will not, and GCC (and RTEMS) should be able to generate
> efficient code
> > > +for each processor variant. When we wish to have different code for a
> range of
> > > +related yet potentially incompatible processors in a family by
> providing
> > > +multiple related libraries we use the multilib process.
> > > +The multilib process extends beyond libgcc.a to libc.a, libm.a, and
> libstd++.a.
> > > +An RTEMS tool set will provide each of these libraries for each of
> the processor
> > > +variants that GCC supports. You can see the multilib information by
> invoking gcc
> > > +with the option '-print-multi-lib'. The output for the M68K tool
> chain is -
> > > +    $ m68k-rtems-gcc -print-multi-lib .; m68000;@m68000 m5200;@m5200
> > > +    m5206e;@m5206e m528x;@m528x m5307;@m5307 m5407;@m5407
> mcpu32;@mcpu32
> > > +    m68040;@m68040 m68060;@m68060 msoft-float;@msoft-float
> > > +This output is not easy to read as it is designed for other tools or
> packages.
> > > +RTEMS core under the cpukit source tree does not reference any BSP
> specific
> > > +details. This allows it to be built as a set of multiple libraries
> named
> > > +librtemscpu.a. A configure command line option will build a multilib
> RTEMS as
> > > +shown in Building a CPU Kit.
> > > +BSP and CPU model specific portions of RTEMS (libcpu and libbsp) are
> > > +built into the separate library librtemsbsp.a.
> > > +What is the difference between the workspace and heap ?
> > > +The RTEMS Workspace is used to allocate space for objects created by
> RTEMS
> > > +such as tasks, semaphores, message queues, etc.. It is primarily used
> during
> > > +system initialization although task stacks and message buffer areas
> are also
> > > +allocated from here.
> > > +What is the difference between autoconf and waf build system ?
> > > +Waf is a build automation tool written in Python which is designed to
> assist
> > > +in the automatic compilation and installation of computer software.
> > > +:ref:`Converting from Autoconf/Automake to waf build
> system<Autoconf_migration>`
> > > diff --git a/user/start/index.rst b/user/start/index.rst
> > > index 17c34e1..e178209 100644
> > > --- a/user/start/index.rst
> > > +++ b/user/start/index.rst
> > > @@ -23,3 +23,4 @@ applications on top of RTEMS.
> > >      app
> > >      rsb-packages
> > >      gsoc
> > > +    faq
> > > diff --git a/user/support/support-project.rst
> b/user/support/support-project.rst
> > > index b782029..9973f5a 100644
> > > --- a/user/support/support-project.rst
> > > +++ b/user/support/support-project.rst
> > > @@ -6,6 +6,8 @@
> > >  .. index:: support; RTEMS Project
> > > +.. _Support_project:
> > >  RTEMS Project Support
> > > 2.25.1
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210402/fba5c85d/attachment-0001.html>
