[PATCH 1/2] Added FAQ page
Ayushman Mishra ayushvidushi01 at gmail.com
Fri Apr 2 18:50:16 UTC 2021
Sir, It was given as an issue https://devel.rtems.org/ticket/3958 (
Review wiki/TBR/Website/FAQ for correct links) for the faq page
https://devel.rtems.org/wiki/TBR/Website/FAQ
On Sat, Apr 3, 2021 at 12:10 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Apr 2, 2021 at 1:19 PM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
>> Greetings Sir,
>> I have corrected and send patches regarding FAQ page in user manual.I
>> was able to build the page on my system and also attached a
>> screen-shot of the builded page on browser . I have corrected
>> whitespace consistency and reference links according to other
>> doc-pages
> Random question. Is this information from the Wiki or just an update
> of what was already in rtems-docs? If this obsoletes any information
> in the wiki, I would like to know so we can remove it.
>> . Regarding the issue of cross-link between docs , I had
>> sent mail on devel mail list
>> https://lists.rtems.org/pipermail/devel/2021-March/065882.html but
>> haven't got any response , so few days ago after a little discussion
>> on discord vijay sir said to post the patch and someone might point it
>> to a better way if it exists.
> I don't know if we know the answer to that with Sphinx. If "we" do, then
> I am not part of that "we".  Hopefully someone will educate us. :)
> Gedare.. is the new patch OK? It must be in another thread because
> I don't see it here.
> --joel
>> On Wed, Mar 24, 2021 at 1:05 AM Gedare Bloom <gedare at rtems.org> wrote:
>> > Did you build the docs and verify they look good?
>> > On Tue, Mar 23, 2021 at 12:44 PM Ayushman Mishra
>> > >  user/bld/index.rst               |   4 +-
>> > >  user/overview/index.rst          |   2 +
>> > >  user/start/faq.rst               | 255 +++++++++++++++++++++++++++++++
>> > >  user/start/index.rst             |   1 +
>> > >  user/support/support-project.rst |   2 +
>> > >  5 files changed, 263 insertions(+), 1 deletion(-)
>> > >  create mode 100644 user/start/faq.rst
>> > > diff --git a/user/bld/index.rst b/user/bld/index.rst
>> > > index ebedf5a..a8a8a4f 100644
>> > > --- a/user/bld/index.rst
>> > > +++ b/user/bld/index.rst
>> > > @@ -82,7 +82,7 @@ specifies paths to build specification items.  It is an advanced option and
>> > >  there is normally no need to use it.  It may be used to customize the build at
>> > >  the level of the build specification.  For more information see the
>> > >  `Build System` chapter of the
>> > > -`RTEMS Software Engineering <https://docs.rtems.org/branches/master/eng/build-system.rst>`_
>> > > +`RTEMS Software Engineering <https://docs.rtems.org/branches/master/eng/build-system.html>`_
>> > >  guide.
>> > >  Help
>> > > @@ -283,6 +283,8 @@ example configuration file, building of the tests is enabled for the
>> > >      [sparc/erc32]
>> > >      [riscv/griscv]
>> > > +.. _Autoconf_migration:
>> > this looks like something should be a cleanup separate submission.
>> > I think the tags are usually directly translated from the section
>> > names with camelcase?
>> > _Migration_from_AutoconfAutomake
>> > or so? check other docs for consistency/guidance.
>> > >  Migration from Autoconf/Automake
>> > > diff --git a/user/overview/index.rst b/user/overview/index.rst
>> > > index 550724a..0703ede 100644
>> > > --- a/user/overview/index.rst
>> > > +++ b/user/overview/index.rst
>> > > @@ -20,6 +20,8 @@ You are someone looking for a real-time operating system.  This document
>> > >  - helps you to build an example application on top of RTEMS.
>> > > +.. _Features:
>> > >  Features
>> > > diff --git a/user/start/faq.rst b/user/start/faq.rst
>> > > new file mode 100644
>> > > index 0000000..da11ca4
>> > > --- /dev/null
>> > > +++ b/user/start/faq.rst
>> > > @@ -0,0 +1,255 @@
>> > > +Frequently Asked Questions
>> > > +What is RTEMS ?
>> > > +RTEMS is an open source real-time executive which provides a high performance
>> > > +environment for embedded real-time applications including many features.
>> > > +The RTEMS Project is the umbrella term used to describe the collection of
>> > > +individuals, companies, universities, and research institutions that collectively
>> > > +maintain and enhance the RTEMS software base.
>> > > +RTEMS is designed to support applications with the most stringent real-time
>> > > +requirements while being compatible with open standards such as POSIX.
>> > > +RTEMS includes optional functional features such as TCP/IP and various file
>> > > +systems while still offering minimum executable sizes under 20 KB in useful
>> > > +configurations.
>> > > +:ref:`More Features<Features>`
>> > > +Where can I get RTEMS ?
>> > > +:ref:`Downloading RTEMS<QuickStartSources_Released>`
>> > > +What does RTEMS stand for ?
>> > > +RTEMS is an an acronym for the Real-Time Executive for Multiprocessor Systems.
>> > an an
>> > > +Initially RTEMS stood for the Real-Time Executive for Missile Systems but as it
>> > > +became clear that the application domains that could use RTEMS extended far
>> > > +beyond missiles, the "M" changed to mean Military. When maintenance of RTEMS
>> > > +transferred to OAR, the "M" was changed again to Multiprocessor.
>> > > +At one point, there were both Ada and C implementations of RTEMS.
>> > > +Version 3.2.1 was the last RTEMS version to have implementations in both
>> > > +languages. Supporting the Classic API Ada implementation was painful and fraught
>> > > +with compiler specific pitfalls. With version 3.5.x, the POSIX API was added as
>> > > +the means to support the GNU Ada Translator (GNAT). This effectively eliminated
>> > > +the need for an implementation in Ada as the C implementation could effectively
>> > > +support both languages.
>> > > +Are there restrictions on the RTEMS License ?
>> > > +RTEMS is licensed under a modified version of the GNU General Public License (GPL).
>> > > +The modification places no restrictions on the applications which use RTEMS but
>> > > +protects the interests of those who work on RTEMS.
>> > This needs to be updated at least to mention 2-clause BSD.
>> > RTEMS is licensed under a combination of permissive licenses and
>> > > +`License in RTEMS
>> > > +<https://docs.rtems.org/branches/master/eng/
>> > > +license-requirements.html>`__
>> > I think just 1 blank space?
>> > > +What standards are supported by RTEMS?
>> > > +The original "Classic" RTEMS API is based on the Real-Time Executive Interface
>> > > +Definition (RTEID) and the Open Real-Time Kernel Interface Definition (ORKID).
>> > > +RTEMS also includes support for POSIX threads and real-time extensions.
>> > > +With the addition of file system infrastructure, RTEMS supports approximately
>> > > +80% of the POSIX 1003.1b-1996 standard. This standard defines the programming
>> > > +interfaces of standard UNIX. This means that much source code that works on
>> > > +UNIX, also works on RTEMS.RTEMS includes a port of the FreeBSD TCP/IP stack and
>> > > +thus supports BSD sockets. It also includes support for numerous networking
>> > > +clients (DHCP, TFTP, NFS, etc.) and servers (FTPD, HTTPD, etc.).
>> > > +What processors is RTEMS available for ?
>> > > +:ref:`Architectures in RTEMS<TargetArchitectures>`
>> > definitely not 3 blank lines though. check other docs for whitespace consistency
>> > > +Are there similar commercial products ?
>> > > +`Some Real time operating system similar to RTEMS
>> > > +<https://en.wikipedia.org/wiki/Comparison_of_real-time_operating_systems>`__
>> > > +How can I obtain RTEMS support ?
>> > > +:ref:`Support in RTEMS<Support_project>`
>> > > +What RTEMS Training Opportunities are available ?
>> > > +`RTEMS Training Opportunities <https://www.rtems.org/TrainingOpportunities>`__
>> > > +How can I contribute?
>> > > +:ref:`Contributions in RTEMS<Contributing>`
>> > > +How are floating point numbers handled ?
>> > > +`Floating point support in RTEMS
>> > > +<https://docs.rtems.org/branches/master/c-user/task/
>> > > +background.html#floating-point-considerations>`__
>> > We don't like to cross-link between docs. I don't remember how this is
>> > handled. If you can't figure it out, you'll have to ask in an email
>> > how to link between different manuals in the docs.
>> > > +How do I make a patch ?
>> > This should refer to the Software Engineering Guide.
>> > > +The recommended way to create a patch is to branch the git repository master
>> > > +and use one commit for each logical change. Then you can use git-format-patch
>> > > +to turn your commits into patches and easily submit them.
>> > > +.. code-block:: none
>> > > +    git format-patch master
>> > > +Creates a separate patch for each commit that has been made between the master
>> > > +branch and the current branch and writes them in the current directory. Use
>> > > +the -o flag to redirect the files to a different directory.
>> > > +If you are re-submitting a patch that has previously been reviewed, you should
>> > > +specify a version number for your patch, for example, use
>> > > +    git format-patch -v2 ...
>> > > +to indicate the second version of a patch, v3 for a third, and so forth.
>> > > +Patches created using git-format-patch are formatted so they can be emailed
>> > > +and rely on having git configured with your name and email address, for example
>> > > +    git config --global user.name "Your Name"
>> > > +    git config --global user.email name at domain.com
>> > > +Please use a real name, we do not allow pseudonyms or anonymous contributions.
>> > > +Why is my executable so big?
>> > > +There are two primary causes for this. The most common is that you are doing an
>> > > +ls -l and looking at the actual file size – not the size of the code in the
>> > > +target image. This file could be in an object format such as ELF or COFF and
>> > > +contain debug information. If this is the case, it could be an order of magnitude
>> > > +larger than the required code space. Use the strip command in your cross
>> > > +toolset to remove debugging information.
>> > > +Another alternative is that the executable file is in an ASCII format such as
>> > > +Motorola Srecords. In this case, there is no debug information in the file
>> > > +but each byte in the target image requires two bytes to represent. On top of
>> > > +that, there is some overhead required to specify the addresses where the image
>> > > +is to be placed in target memory as well as checksum information. In this
>> > > +case, it is not uncommon to see executable files that are between two and three
>> > > +times larger than the actual space required in target memory.
>> > > +Remember, the debugging information is required to do symbolic debugging with gdb.
>> > > +Normally gdb obtains its symbolic information from the same file that it gets
>> > > +the exe- cutable image from. However, gdb does not require that the executable
>> > > +image and symbolic information be obtained from the same file. So you might want
>> > > +to create a hello_with_ symbols.exe, copy that file to hello_without_symbols.exe,
>> > > +and strip hello_without_ symbols.exe. Then gdb would have to be told to read
>> > > +symbol information from hello_ with_symbols.exe. The gdb command line option
>> > > +-symbols or command symbol-file may be used to specify the file read for
>> > > +symbolic information
>> > > +What MinGW Tools for Windows are available ?
>> > > +Windows users can use MinGW based RTEMS tools. These tools will generate the
>> > > +same application code for RTEMS as the tools on Linux or Cygwin. MinGW tools
>> > > +use the native Windows runtime rather than access Windows via the POSIX interface
>> > > +Cygwin provides. MinGW tools are faster than the Cygwin equivalent and are not
>> > > +confused by Cygwin mount points. Compiler errors will show a Windows path rather
>> > > +than a Cygwin path and so do not confuse native Windows editors.
>> > > +:ref:`Cygwin in windows<Cygwin>`
>> > > +The RTEMS MinGW Tools are not currently packaged in installers. The installers
>> > > +stopped around RTEMS 4.9 when the MinGW tools started to be built as part of
>> > > +the binary tool package. This means you need to manually step through the
>> > > +process. It is not difficult, how-ever it is not an easy installer.
>> > > +What is Multilib RTEMS ?
>> > > +The multilib process supports building a set of related libraries for a given
>> > > +target where the individual libraries in the set use different specific
>> > > +compiler flags (such as flags for code generation options, pre-processor
>> > > +defines, etc) for the individual libraries. The reason this is needed can be
>> > > +seen by examining the M68K GCC compiler. That compiler generates code for a
>> > > +number of processor variants in the M68K family, for example, it can generate
>> > > +code for the original 68000, the 68040 or a 528x Coldfire. These processors all
>> > > +use a closely related instruction set, but processor differences mean code
>> > > +compiled for one may not run on another. GCC provides a special library called
>> > > +libgcc.a that holds intrinsic functions needed by the compiler. These
>> > > +intrinsic functions provide "software instructions" (such as non-basic math
>> > > +support routines) that the processor may not support. However, which functions
>> > > +GCC considers to be intrinsic should be able to vary within a processor family.
>> > > +One processor variant will have hardware floating point and another processor
>> > > +variant will not, and GCC (and RTEMS) should be able to generate efficient code
>> > > +for each processor variant. When we wish to have different code for a range of
>> > > +related yet potentially incompatible processors in a family by providing
>> > > +multiple related libraries we use the multilib process.
>> > > +The multilib process extends beyond libgcc.a to libc.a, libm.a, and libstd++.a.
>> > > +An RTEMS tool set will provide each of these libraries for each of the processor
>> > > +variants that GCC supports. You can see the multilib information by invoking gcc
>> > > +with the option '-print-multi-lib'. The output for the M68K tool chain is -
>> > > +    $ m68k-rtems-gcc -print-multi-lib .; m68000;@m68000 m5200;@m5200
>> > > +    m5206e;@m5206e m528x;@m528x m5307;@m5307 m5407;@m5407 mcpu32;@mcpu32
>> > > +    m68040;@m68040 m68060;@m68060 msoft-float;@msoft-float
>> > > +This output is not easy to read as it is designed for other tools or packages.
>> > > +RTEMS core under the cpukit source tree does not reference any BSP specific
>> > > +details. This allows it to be built as a set of multiple libraries named
>> > > +librtemscpu.a. A configure command line option will build a multilib RTEMS as
>> > > +shown in Building a CPU Kit.
>> > > +BSP and CPU model specific portions of RTEMS (libcpu and libbsp) are
>> > > +built into the separate library librtemsbsp.a.
>> > > +What is the difference between the workspace and heap ?
>> > > +The RTEMS Workspace is used to allocate space for objects created by RTEMS
>> > > +such as tasks, semaphores, message queues, etc.. It is primarily used during
>> > > +system initialization although task stacks and message buffer areas are also
>> > > +allocated from here.
>> > > +What is the difference between autoconf and waf build system ?
>> > > +Waf is a build automation tool written in Python which is designed to assist
>> > > +in the automatic compilation and installation of computer software.
>> > > +:ref:`Converting from Autoconf/Automake to waf build system<Autoconf_migration>`
>> > > diff --git a/user/start/index.rst b/user/start/index.rst
>> > > index 17c34e1..e178209 100644
>> > > --- a/user/start/index.rst
>> > > +++ b/user/start/index.rst
>> > > @@ -23,3 +23,4 @@ applications on top of RTEMS.
>> > >      app
>> > >      rsb-packages
>> > >      gsoc
>> > > +    faq
>> > > diff --git a/user/support/support-project.rst b/user/support/support-project.rst
>> > > index b782029..9973f5a 100644
>> > > --- a/user/support/support-project.rst
>> > > +++ b/user/support/support-project.rst
>> > > @@ -6,6 +6,8 @@
>> > >  .. index:: support; RTEMS Project
>> > > +.. _Support_project:
>> > >  RTEMS Project Support
>> > > 2.25.1
>> > > _______________________________________________
>> > > devel mailing list
>> > > devel at rtems.org
>> > > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
