[PATCH 1/2] Added FAQ page
Gedare Bloom
gedare at rtems.org
Mon Apr 5 16:26:23 UTC 2021
On Sat, Apr 3, 2021 at 5:15 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3/4/21 6:29 am, Gedare Bloom wrote:
> > On Fri, Apr 2, 2021 at 12:55 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Fri, Apr 2, 2021 at 1:50 PM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
> >>> Sir, It was given as an issue https://devel.rtems.org/ticket/3958 (
> >>> Review wiki/TBR/Website/FAQ for correct links) for the faq page
> >>> https://devel.rtems.org/wiki/TBR/Website/FAQ
> >> Thanks for confirming that. When Gedare acks the patches as being
> >> ok by him, I will see about removing that page and fixing links to it.
> >> --joel
> >>> On Sat, Apr 3, 2021 at 12:10 AM Joel Sherrill <joel at rtems.org> wrote:
> >>>> On Fri, Apr 2, 2021 at 1:19 PM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
> >>>>> Greetings Sir,
> >>>>> I have corrected and send patches regarding FAQ page in user manual.I
> >>>>> was able to build the page on my system and also attached a
> >>>>> screen-shot of the builded page on browser . I have corrected
> >>>>> whitespace consistency and reference links according to other
> >>>>> doc-pages
> >>>> Random question. Is this information from the Wiki or just an update
> >>>> of what was already in rtems-docs? If this obsoletes any information
> >>>> in the wiki, I would like to know so we can remove it.
> >>>>> . Regarding the issue of cross-link between docs , I had
> >>>>> sent mail on devel mail list
> >>>>> https://lists.rtems.org/pipermail/devel/2021-March/065882.html but
> >>>>> haven't got any response , so few days ago after a little discussion
> >>>>> on discord vijay sir said to post the patch and someone might point it
> >>>>> to a better way if it exists.
> >>>> I don't know if we know the answer to that with Sphinx. If "we" do, then
> >>>> I am not part of that "we". Hopefully someone will educate us. :)
> >>>> Gedare.. is the new patch OK? It must be in another thread because
> >>>> I don't see it here.
> >>>> --joel
> > Patch needs a little bit of tweaking. It's close.
> > The problem with the cross-doc links is that they are wrong for a
> > release doc. I don't think we have determined what is the proper
> > solution to follow yet. They also don't populate the section numbers
> > in PDF builds, so all you get is the URL and if you have printed
> > manuals (does anyone do that?) you might not be able to find what you
> > want. There's no good answer to this problem though, so I'm ok with
> > merging the patch after the other issues get addressed, but we're
> > probably adding more effort to the release/post-release procedures
> > until someone sorts out how to do cross-doc links in a useful way.
> Sorry no crosslinking.
This is a serious limitation that has come up several times. We should
open a ticket for this? Sorting out how to support link generation may
be a worthwhile SoC task?
> Chris
