[PATCH rtems-net-legacy] nfsclient: Build nfsclient from the top level netlegacy script
Vijay Kumar Banerjee vijay at rtems.org
Tue Apr 6 17:22:53 UTC 2021
On Mon, Apr 5, 2021 at 10:34 AM Gedare Bloom <gedare at rtems.org> wrote:
> ok, push on Wednesday if no one complains
Thanks for the review. I think I found a complaint myself. :)
This patch builds the nfsclient from the netlegacy script, so the
nfsclient/wscript is not needed. I'll send a v2 of the patch with this
cleanup added.
> On Sat, Apr 3, 2021 at 7:06 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >  netlegacy.py      | 18 +++++++++++++++++-
> >  nfsclient/wscript |  1 +
> >  wscript           |  2 +-
> >  3 files changed, 19 insertions(+), 2 deletions(-)
> > diff --git a/netlegacy.py b/netlegacy.py
> > index 89176e6..f470da2 100644
> > --- a/netlegacy.py
> > +++ b/netlegacy.py
> > @@ -55,6 +55,13 @@ def build(bld):
> >                     for s in os.listdir('./pppd') if s[-2:] == '.c']
> >      telnetd_source = [os.path.join('./telnetd', s)
> >                        for s in os.listdir('telnetd') if s[-2:] == '.c']
> > +    nfs_source = []
> > +    for root, dirs, files in os.walk('./nfsclient'):
> > +        for name in files:
> > +            ext = os.path.splitext(name)[1]
> > +            if ext == '.c':
> > +                src_root = os.path.split(root)[1]
> > +                nfs_source.append(os.path.join('./nfsclient', src_root, name))
> >      bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> > @@ -67,6 +74,7 @@ def build(bld):
> >                           './bsps/include'])
> >      arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> >                                              bld.env.RTEMS_ARCH_BSP)
> > +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> >      include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> >                                                       arch_lib_path)))
> > @@ -74,6 +82,8 @@ def build(bld):
> >                                                       'include')))
> >      include_path.append('./bsps/include/libchip')
> > +    bld.read_stlib('rtemsbsp', paths=[lib_path])
> >      if bsp in bsp_dirs:
> >          include_path.extend(bsp_dirs[bsp])
> > @@ -108,8 +118,14 @@ def build(bld):
> >                use='networking',
> >                source=telnetd_source)
> > +    bld.stlib(target='nfs',
> > +              features='c',
> > +              includes=ip,
> > +              use=['rtemsbsp', 'networking'],
> > +              source=nfs_source)
> >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> > +                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> >                                     'include', 'libchip'),
> >                        [os.path.join('./bsps/include/libchip/', f)
> > diff --git a/nfsclient/wscript b/nfsclient/wscript
> > index bc2f994..c0fe420 100644
> > --- a/nfsclient/wscript
> > +++ b/nfsclient/wscript
> > @@ -52,5 +52,6 @@ def build(bld):
> >                features='c',
> >                cflags=['-O2', '-g'],
> >                includes=include_path,
> > +              use=['networking'],
> >                source=source_files)
> >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> > diff --git a/wscript b/wscript
> > index 07f774d..7af317d 100644
> > --- a/wscript
> > +++ b/wscript
> > @@ -33,7 +33,7 @@ import sys
> >  top = '.'
> >  rtems_version = "6"
> > -subdirs = ['nfsclient', 'testsuites']
> > +subdirs = ['testsuites']
> >  try:
> >      import rtems_waf.rtems as rtems
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
