[PATCH 2/2] covoar: Eliminate tabs
Tue Apr 6 20:43:42 UTC 2021
 tester/covoar/CoverageReaderTSIM.cc |  16 +-
 tester/covoar/CoverageWriterTSIM.cc |   4 +-
 tester/covoar/GcovData.cc           | 719 ++++++++++++++++++------------------
 tester/covoar/GcovData.h            |  80 ++--
 tester/covoar/GcovFunctionData.cc   |  43 +--
 tester/covoar/GcovFunctionData.h    | 111 +++---
 tester/covoar/ReportsHtml.cc        |   6 +-
 tester/covoar/SymbolTable.cc        |   6 +-
 tester/covoar/SymbolTable.h         |   4 +-
 tester/covoar/Target_riscv.h        |   8 +-
 10 files changed, 501 insertions(+), 496 deletions(-)
diff --git a/tester/covoar/CoverageReaderTSIM.cc b/tester/covoar/CoverageReaderTSIM.cc
index d8b738e..03bf7a8 100644
--- a/tester/covoar/CoverageReaderTSIM.cc
+++ b/tester/covoar/CoverageReaderTSIM.cc
@@ -64,7 +64,7 @@ namespace Coverage {
       for (i = 0; i < 0x80; i += 4) {
         unsigned int a;
         status = ::fscanf( coverageFile, "%x", &cover );
-	if (status == EOF || status == 0) {
+        if (status == EOF || status == 0) {
           std::cerr << "CoverageReaderTSIM: WARNING! Short line in "
                     << file
                     << " at address 0x"
@@ -73,14 +73,14 @@ namespace Coverage {
                     << std::setfill(' ') << std::dec
                     << std::endl;
           break;
         // Obtain the coverage map containing the address and
         // mark the address as executed.
-	a = baseAddress + i;
-	aCoverageMap = executableInformation->getCoverageMap( a );
+        a = baseAddress + i;
+        aCoverageMap = executableInformation->getCoverageMap( a );
         if ( !aCoverageMap )
           continue;
         if ( cover & 0x01 ) {
@@ -89,12 +89,12 @@ namespace Coverage {
           aCoverageMap->setWasExecuted( a + 2 );
           aCoverageMap->setWasExecuted( a + 3 );
           if ( cover & 0x08 ) {
-	    aCoverageMap->setWasTaken( a );
-	    BranchInfoAvailable = true;
+            aCoverageMap->setWasTaken( a );
+            BranchInfoAvailable = true;
           if ( cover & 0x10 ) {
-	    aCoverageMap->setWasNotTaken( a );
+            aCoverageMap->setWasNotTaken( a );
diff --git a/tester/covoar/CoverageWriterTSIM.cc b/tester/covoar/CoverageWriterTSIM.cc
index a4731a9..62a1f7d 100644
--- a/tester/covoar/CoverageWriterTSIM.cc
+++ b/tester/covoar/CoverageWriterTSIM.cc
@@ -57,7 +57,7 @@ namespace Coverage {
       for ( i = 0; i < 0x80; i += 4 ) {
         cover = ((coverage->wasExecuted( a + i )) ? 1 : 0);
         status = ::fprintf( coverageFile, "%d ", cover );
-	if ( status == EOF || status == 0 ) {
+        if ( status == EOF || status == 0 ) {
           ::fclose( coverageFile );
           std::ostringstream what;
           what << "write to " << file
@@ -67,7 +67,7 @@ namespace Coverage {
                << "failed";
           throw rld::error( what, "CoverageWriterTSIM::writeFile" );
       ::fprintf( coverageFile, "\n" );
diff --git a/tester/covoar/GcovData.cc b/tester/covoar/GcovData.cc
index 2c033e5..5175fb3 100644
--- a/tester/covoar/GcovData.cc
+++ b/tester/covoar/GcovData.cc
@@ -27,7 +27,7 @@ namespace Gcov {
   GcovData::GcovData()
-	  	numberOfFunctions = 0;
+    numberOfFunctions = 0;
   GcovData::~GcovData()
@@ -36,11 +36,11 @@ namespace Gcov {
   bool GcovData::readGcnoFile( const char* const  fileName )
-    int                 status;
-    FILE*               gcovFile;
-    char*		tempString;
-    char*		tempString2;
-    char*		tempString3;
+    int        status;
+    FILE*      gcovFile;
+    char*      tempString;
+    char*      tempString2;
+    char*      tempString3;
     if ( strlen(fileName) >= FILE_NAME_LENGTH ){
       fprintf(
@@ -63,9 +63,9 @@ namespace Gcov {
     else
-      strcpy( tempString, ".gcda");		// construct gcda file name
-      strcpy( tempString2, ".txt");		// construct report file name
-      strcpy( tempString3, ".c");		// construct source file name
+      strcpy( tempString, ".gcda");             // construct gcda file name
+      strcpy( tempString2, ".txt");             // construct report file name
+      strcpy( tempString3, ".c");               // construct source file name
     // Debug message
@@ -74,16 +74,16 @@ namespace Gcov {
     // Open the notes file.
     gcovFile = fopen( gcnoFileName, "r" );
     if ( !gcovFile ) {
-    	fprintf( stderr, "Unable to open %s\n", gcnoFileName );
-    	return false;
+      fprintf( stderr, "Unable to open %s\n", gcnoFileName );
+      return false;
     // Read and validate the gcnoPreamble (magic, version, timestamp) from the file
     status = readFilePreamble( &gcnoPreamble, gcovFile, GCNO_MAGIC );
     if ( status <= 0 ){
-    	fprintf( stderr, "Unable to read %s\n", gcnoFileName );
-	fclose( gcovFile );
-    	return false;
+      fprintf( stderr, "Unable to read %s\n", gcnoFileName );
+      fclose( gcovFile );
+      return false;
     //Read all remaining frames from file
@@ -96,383 +96,383 @@ namespace Gcov {
   bool GcovData::writeGcdaFile ()
-	  gcov_preamble 		preamble;
-	  gcov_frame_header		header;
-	  FILE*				gcdaFile;
-	  functions_iterator_t	currentFunction;
-	  arcs_iterator_t		currentArc;
-	  uint32_t			buffer;
-	  uint32_t			countersFound;
-	  uint32_t			countersFoundSum;
-	  uint64_t			countersSum;
-	  uint64_t			countersMax;
-	  uint64_t			llBuffer[4096];		// TODO: Use common buffer
-	  gcov_statistics		objectStats;
-	  gcov_statistics		programStats;
-	  size_t			status;
-	  // Debug message
-	  // fprintf( stderr, "Writing file: %s\n",  gcdaFileName);
-	  // Lets clear counters sumators
-	  countersSum 		= 0;
-	  countersMax 		= 0;
-	  countersFoundSum 	= 0;
-	  // Open the data file.
-	  gcdaFile = fopen( gcdaFileName, "w" );
-	  if ( !gcdaFile ) {
-		  fprintf( stderr, "Unable to create %s\n", gcdaFileName );
-		  return false;
-	  //Form preamble
-	  preamble.magic	= GCDA_MAGIC;
-	  preamble.version	= gcnoPreamble.version;
-	  preamble.timestamp	= gcnoPreamble.timestamp;
-	  //Write preamble
-	  status = fwrite (&preamble , sizeof( preamble ), 1 , gcdaFile );
-	  if ( status != 1 )
-            fprintf( stderr, "Error while writing gcda preamble to a file %s\n", gcdaFileName );
-	  //Write function info and counter counts
-	  for (
-			  currentFunction = functions.begin();
-			  currentFunction != functions.end();
-			  currentFunction++
-		  //Write function announcement frame header (length always equals 2)
-		  header.tag = GCOV_TAG_FUNCTION;
-		  header.length = 2;
-		  status = fwrite (&header, sizeof(header), 1, gcdaFile );
-                    fprintf( stderr, "Error while writing function announcement to a file %s\n", gcdaFileName );
-		  //Write function id
-		  buffer = (*currentFunction)->getId();
-		  status = fwrite (&buffer, sizeof( buffer ), 1, gcdaFile );
-                    fprintf( stderr, "Error while writing function id to a file %s\n", gcdaFileName );
-		  //Write function checksum
-		  buffer = (*currentFunction)->getChecksum();
-                    fprintf( stderr, "Error while writing function checksum to a file %s\n", gcdaFileName );
-		  // Determine how many counters there are
-		  // and store their counts in buffer
-		  countersFound = 0;
-		  (*currentFunction)->getCounters( llBuffer, countersFound, countersSum, countersMax );
-		  countersFoundSum += countersFound;
-		  //Write info about counters
-		  header.tag = GCOV_TAG_COUNTER;
-		  header.length = countersFound * 2;
-		  status = fwrite (&header, sizeof( header ), 1, gcdaFile );
-                    fprintf( stderr, "Error while writing counter header to a file %s\n", gcdaFileName );
-		  status = fwrite (llBuffer, sizeof( uint64_t ), countersFound , gcdaFile );
-	          if ( status != countersFound )
-                    fprintf( stderr, "Error while writing counter data to a file %s\n", gcdaFileName );
-	  // Prepare frame with object file statistics
-	  header.tag = GCOV_TAG_OBJECT_SUMMARY;
-	  header.length = 9;
-	  objectStats.checksum = 0;			// TODO: have no idea hov to calculates it :)
-	  objectStats.counters = countersFoundSum;
-	  objectStats.runs = 1;				// We are lying for now, we have no means of figuring this out
-	  objectStats.sum = countersSum;		// Sum of all counters
-	  objectStats.max = countersMax;		// max value for counter on last run, we have no clue
-	  objectStats.sumMax = countersMax;		// we have no clue
-	  // Write data
-            fprintf( stderr, "Error while writing stats header to a file %s\n", gcdaFileName );
-	  status = fwrite (&objectStats, sizeof( objectStats ), 1, gcdaFile );
-            fprintf( stderr, "Error while writing object stats to a file %s\n", gcdaFileName );
-	  // Prepare frame with program statistics
-	  header.tag = GCOV_TAG_PROGRAM_SUMMARY;
-	  programStats.checksum = 0;			// TODO: have no idea hov to calculate it :)
-	  programStats.counters = countersFoundSum;
-	  programStats.runs = 1;			// We are lying for now, we have no clue
-	  programStats.sum = countersSum;		// Sum of all counters
-	  programStats.max = countersMax;		// max value for counter on last run, we have no clue
-	  programStats.sumMax = countersMax;		// we have no clue
-	  // Write data
-	  status = fwrite (&programStats, sizeof( programStats ), 1, gcdaFile );
-            fprintf( stderr, "Error while writing program stats to a file %s\n", gcdaFileName );
-	  fclose( gcdaFile );
-	  return true;
+    gcov_preamble         preamble;
+    gcov_frame_header     header;
+    FILE*                 gcdaFile;
+    functions_iterator_t  currentFunction;
+    arcs_iterator_t       currentArc;
+    uint32_t              buffer;
+    uint32_t              countersFound;
+    uint32_t              countersFoundSum;
+    uint64_t              countersSum;
+    uint64_t              countersMax;
+    uint64_t              llBuffer[4096];    // TODO: Use common buffer
+    gcov_statistics       objectStats;
+    gcov_statistics       programStats;
+    size_t                status;
+    // Debug message
+    // fprintf( stderr, "Writing file: %s\n",  gcdaFileName);
+    // Lets clear counters sumators
+    countersSum     = 0;
+    countersMax     = 0;
+    countersFoundSum   = 0;
+    // Open the data file.
+    gcdaFile = fopen( gcdaFileName, "w" );
+    if ( !gcdaFile ) {
+      fprintf( stderr, "Unable to create %s\n", gcdaFileName );
+      return false;
+    //Form preamble
+    preamble.magic  = GCDA_MAGIC;
+    preamble.version  = gcnoPreamble.version;
+    preamble.timestamp  = gcnoPreamble.timestamp;
+    //Write preamble
+    status = fwrite (&preamble , sizeof( preamble ), 1 , gcdaFile );
+    if ( status != 1 )
+      fprintf( stderr, "Error while writing gcda preamble to a file %s\n", gcdaFileName );
+    //Write function info and counter counts
+    for (
+      currentFunction = functions.begin();
+      currentFunction != functions.end();
+      currentFunction++
+      //Write function announcement frame header (length always equals 2)
+      header.tag = GCOV_TAG_FUNCTION;
+      header.length = 2;
+      status = fwrite (&header, sizeof(header), 1, gcdaFile );
+        fprintf( stderr, "Error while writing function announcement to a file %s\n", gcdaFileName );
+      //Write function id
+      buffer = (*currentFunction)->getId();
+      status = fwrite (&buffer, sizeof( buffer ), 1, gcdaFile );
+        fprintf( stderr, "Error while writing function id to a file %s\n", gcdaFileName );
+      //Write function checksum
+      buffer = (*currentFunction)->getChecksum();
+        fprintf( stderr, "Error while writing function checksum to a file %s\n", gcdaFileName );
+      // Determine how many counters there are
+      // and store their counts in buffer
+      countersFound = 0;
+      (*currentFunction)->getCounters( llBuffer, countersFound, countersSum, countersMax );
+      countersFoundSum += countersFound;
+      //Write info about counters
+      header.tag = GCOV_TAG_COUNTER;
+      header.length = countersFound * 2;
+      status = fwrite (&header, sizeof( header ), 1, gcdaFile );
+        fprintf( stderr, "Error while writing counter header to a file %s\n", gcdaFileName );
+      status = fwrite (llBuffer, sizeof( uint64_t ), countersFound , gcdaFile );
+      if ( status != countersFound )
+        fprintf( stderr, "Error while writing counter data to a file %s\n", gcdaFileName );
+    // Prepare frame with object file statistics
+    header.tag = GCOV_TAG_OBJECT_SUMMARY;
+    header.length = 9;
+    objectStats.checksum = 0;      // TODO: have no idea hov to calculates it :)
+    objectStats.counters = countersFoundSum;
+    objectStats.runs = 1;        // We are lying for now, we have no means of figuring this out
+    objectStats.sum = countersSum;    // Sum of all counters
+    objectStats.max = countersMax;    // max value for counter on last run, we have no clue
+    objectStats.sumMax = countersMax;    // we have no clue
+    // Write data
+      fprintf( stderr, "Error while writing stats header to a file %s\n", gcdaFileName );
+    status = fwrite (&objectStats, sizeof( objectStats ), 1, gcdaFile );
+      fprintf( stderr, "Error while writing object stats to a file %s\n", gcdaFileName );
+    // Prepare frame with program statistics
+    header.tag = GCOV_TAG_PROGRAM_SUMMARY;
+    programStats.checksum = 0;      // TODO: have no idea hov to calculate it :)
+    programStats.counters = countersFoundSum;
+    programStats.runs = 1;      // We are lying for now, we have no clue
+    programStats.sum = countersSum;    // Sum of all counters
+    programStats.max = countersMax;    // max value for counter on last run, we have no clue
+    programStats.sumMax = countersMax;    // we have no clue
+    // Write data
+    status = fwrite (&programStats, sizeof( programStats ), 1, gcdaFile );
+      fprintf( stderr, "Error while writing program stats to a file %s\n", gcdaFileName );
+    fclose( gcdaFile );
+    return true;
   bool GcovData::readFrame(
-	       FILE*         gcovFile
+         FILE*         gcovFile
-	    char 		buffer[512];
-	    uint32_t            intBuffer[4096];
-	    uint32_t            tempBlockId;
-	    blocks_iterator_t	tempBlockIterator;
-	    int                 status;
-	    GcovFunctionData*	newFunction;
-	    status = readFrameHeader( &header, gcovFile);
-	    if ( status <= 0 ){
-                // Not printing error message because this
-		// happenns at the end of each file
-	    	return false;
-	    switch (header.tag){
-			case GCOV_TAG_FUNCTION:
-				numberOfFunctions++;
-				newFunction = new GcovFunctionData;
-				if ( !readFunctionFrame(header, gcovFile, newFunction) ){
-					fprintf( stderr, "Error while reading FUNCTION from gcov file...\n" );
-					return false;
-				functions.push_back(newFunction);
-				break;
-			case GCOV_TAG_BLOCKS:
-				status = fread( &intBuffer, 4, header.length, gcovFile );
-				if ( status != (int) header.length){
-					fprintf(
-						stderr, "Error while reading BLOCKS from gcov file...\n"
-						"Header lenght is %u instead of %u\n",
-						header.length,
-						status
-					return false;
-				for( uint32_t i = 0; i < header.length; i++ )
-					functions.back()->addBlock(i, intBuffer[i], "");
-				break;
-			case GCOV_TAG_ARCS:
-				if (status != (int) header.length){
-					return false;
-				for ( int i = 1; i < (int) header.length; i += 2 )
-					functions.back()->addArc(intBuffer[0], intBuffer[i], intBuffer[i+1]);
-				break;
-			case GCOV_TAG_LINES:
-				status = fread( &intBuffer, 4, 2, gcovFile );
-				if (status != 2 || intBuffer[1] != 0){
-					fprintf(
-						stderr,
-						"Error while reading block id for LINES from gcov file..."
-					return false;
-				tempBlockId = intBuffer[0];
-				header.length -= 2;
-				// Find the right block
-				tempBlockIterator =functions.back()->findBlockById(tempBlockId);
-				header.length -= readString(buffer, gcovFile);
-				functions.back()->setBlockFileName( tempBlockIterator, buffer );
-					fprintf( stderr, "Error while reading LINES from gcov file..." );
-					return false;
-				else
-					for (int i = 0; i < (int) (header.length - 2); i++)
-						functions.back()->addBlockLine( tempBlockIterator, intBuffer[i] );
-				break;
-			default:
-				fprintf( stderr, "\n\nERROR - encountered unknown *.gcno tag : 0x%x\n", header.tag );
-				break;
-	    return true;
+    char                buffer[512];
+    uint32_t            intBuffer[4096];
+    uint32_t            tempBlockId;
+    blocks_iterator_t   tempBlockIterator;
+    int                 status;
+    GcovFunctionData*   newFunction;
+    status = readFrameHeader( &header, gcovFile);
+    if ( status <= 0 ) {
+      // Not printing error message because this
+      // happenns at the end of each file
+      return false;
+    switch (header.tag){
+      case GCOV_TAG_FUNCTION:
+        numberOfFunctions++;
+        newFunction = new GcovFunctionData;
+        if ( !readFunctionFrame(header, gcovFile, newFunction) ){
+          fprintf( stderr, "Error while reading FUNCTION from gcov file...\n" );
+          return false;
+        functions.push_back(newFunction);
+        break;
+      case GCOV_TAG_BLOCKS:
+        status = fread( &intBuffer, 4, header.length, gcovFile );
+        if ( status != (int) header.length){
+          fprintf(
+            stderr, "Error while reading BLOCKS from gcov file...\n"
+            "Header lenght is %u instead of %u\n",
+            header.length,
+            status
+          return false;
+        for( uint32_t i = 0; i < header.length; i++ )
+          functions.back()->addBlock(i, intBuffer[i], "");
+        break;
+      case GCOV_TAG_ARCS:
+        if (status != (int) header.length){
+          return false;
+        for ( int i = 1; i < (int) header.length; i += 2 )
+          functions.back()->addArc(intBuffer[0], intBuffer[i], intBuffer[i+1]);
+        break;
+      case GCOV_TAG_LINES:
+        status = fread( &intBuffer, 4, 2, gcovFile );
+        if (status != 2 || intBuffer[1] != 0){
+          fprintf(
+            stderr,
+            "Error while reading block id for LINES from gcov file..."
+          return false;
+        tempBlockId = intBuffer[0];
+        header.length -= 2;
+        // Find the right block
+        tempBlockIterator =functions.back()->findBlockById(tempBlockId);
+        header.length -= readString(buffer, gcovFile);
+        functions.back()->setBlockFileName( tempBlockIterator, buffer );
+          fprintf( stderr, "Error while reading LINES from gcov file..." );
+          return false;
+        else
+          for (int i = 0; i < (int) (header.length - 2); i++)
+            functions.back()->addBlockLine( tempBlockIterator, intBuffer[i] );
+        break;
+      default:
+        fprintf( stderr, "\n\nERROR - encountered unknown *.gcno tag : 0x%x\n", header.tag );
+        break;
+      return true;
   int GcovData::readString(
-		   char*		 buffer,   //TODO: use global buffer here
-	       FILE*         gcovFile
+    char*     buffer,   //TODO: use global buffer here
+    FILE*     gcovFile
-	    int					status;
-	    int					length;
+    int          status;
+    int          length;
-	    status = fread( &length, sizeof(int), 1, gcovFile );
-	    if (status != 1){
-              fprintf( stderr, "ERROR: Unable to read string length from gcov file\n" );
-	      return -1;
+    status = fread( &length, sizeof(int), 1, gcovFile );
+    if (status != 1){
+      fprintf( stderr, "ERROR: Unable to read string length from gcov file\n" );
+      return -1;
-	    status = fread( buffer, length * 4 , 1, gcovFile );
-	    if (status != 1){
-              fprintf( stderr, "ERROR: Unable to read string from gcov file\n" );
-	      return -1;
+    status = fread( buffer, length * 4 , 1, gcovFile );
+    if (status != 1){
+      fprintf( stderr, "ERROR: Unable to read string from gcov file\n" );
+      return -1;
-	    buffer[length * 4] = '\0';
+    buffer[length * 4] = '\0';
-	    return length +1;
+    return length +1;
   int GcovData::readFrameHeader(
-	       gcov_frame_header* 	header,
-	       FILE*         		gcovFile
+    gcov_frame_header*   header,
+    FILE*             gcovFile
-	    int					status;
-	    int					length;
-	    length = sizeof(gcov_frame_header);
-	    status = fread( header, length, 1, gcovFile );
-	    if (status != 1){
-		//fprintf( stderr, "ERROR: Unable to read frame header from gcov file\n" );
-	    	return -1;
+    int          status;
+    int          length;
+    length = sizeof(gcov_frame_header);
+    status = fread( header, length, 1, gcovFile );
+    if (status != 1){
+      //fprintf( stderr, "ERROR: Unable to read frame header from gcov file\n" );
+      return -1;
-	    return length / 4;
+      return length / 4;
   int GcovData::readFilePreamble(
-  	   gcov_preamble* 	    preamble,
-	   FILE*         		gcovFile,
-	   uint32_t				desiredMagic
+     gcov_preamble*       preamble,
+     FILE*             gcovFile,
+     uint32_t        desiredMagic
-	    int					status;
-	    int					length;
-	    length = sizeof( gcov_preamble );
-	    status = fread( preamble, sizeof( gcov_preamble), 1, gcovFile );
-	    if (status <= 0) {
-	      fprintf( stderr, "Error while reading file preamble\n" );
-	      return -1;
-	    if ( preamble->magic != GCNO_MAGIC ) {
-	      fprintf( stderr, "File is not a valid *.gcno output (magic: 0x%4x)\n", preamble->magic );
-	      return -1;
+    int          status;
+    int          length;
+    length = sizeof( gcov_preamble );
+    status = fread( preamble, sizeof( gcov_preamble), 1, gcovFile );
+    if (status <= 0) {
+      fprintf( stderr, "Error while reading file preamble\n" );
+      return -1;
+    if ( preamble->magic != GCNO_MAGIC ) {
+      fprintf( stderr, "File is not a valid *.gcno output (magic: 0x%4x)\n", preamble->magic );
+      return -1;
   bool GcovData::readFunctionFrame(
-	   gcov_frame_header 	header,
-	   FILE*         	gcovFile,
-	   GcovFunctionData*	function
+    gcov_frame_header   header,
+    FILE*           gcovFile,
+    GcovFunctionData*  function
-	  char 		    buffer[512];		//TODO: use common buffers
-	  int               status;
-	  status = fread( &intBuffer, 8, 1, gcovFile );
-	  if (status != 1){
-		fprintf( stderr, "ERROR: Unable to read Function ID & checksum\n" );
-	  	return false;
-	  function->setId( intBuffer[0] );
-	  function->setChecksum( intBuffer[1] );
-	  header.length -= readString( buffer, gcovFile );
-	  function->setFunctionName( buffer );
-	  function->setFileName( buffer );
-	  if (status <= 0){
-		fprintf( stderr, "ERROR: Unable to read Function starting line number\n" );
-	  	return false;
-	  function->setFirstLineNumber( intBuffer[0] );
-	  return true;
+    char         buffer[512];    //TODO: use common buffers
+    int          status;
+    status = fread( &intBuffer, 8, 1, gcovFile );
+    if (status != 1){
+      fprintf( stderr, "ERROR: Unable to read Function ID & checksum\n" );
+      return false;
+    function->setId( intBuffer[0] );
+    function->setChecksum( intBuffer[1] );
+    header.length -= readString( buffer, gcovFile );
+    function->setFunctionName( buffer );
+    function->setFileName( buffer );
+    if (status <= 0){
+    fprintf( stderr, "ERROR: Unable to read Function starting line number\n" );
+      return false;
+    function->setFirstLineNumber( intBuffer[0] );
+    return true;
   bool GcovData::writeReportFile()
-	  uint32_t			i = 1;					//iterator
-	  FILE*				textFile;
-	  // Debug message
-	  // fprintf( stderr, "Writing file: %s\n",  textFileName);
-        textFile = fopen( textFileName, "w" );
-	if ( !textFile ) {
-	  fprintf( stderr, "Unable to create %s\n", textFileName );
-	  return false;
-	printGcnoFileInfo( textFile );
-	for (
-			currentFunction++
-		(*currentFunction)->printFunctionInfo( textFile, i );
-                (*currentFunction)->printCoverageInfo( textFile, i );
-		i++;
-	fclose ( textFile );
-	return true;
+    uint32_t               i = 1;          //iterator
+    FILE*                  textFile;
+    // Debug message
+    // fprintf( stderr, "Writing file: %s\n",  textFileName);
+    textFile = fopen( textFileName, "w" );
+    if ( !textFile ) {
+      fprintf( stderr, "Unable to create %s\n", textFileName );
+      return false;
+    printGcnoFileInfo( textFile );
+    for (
+      currentFunction++
+      (*currentFunction)->printFunctionInfo( textFile, i );
+      (*currentFunction)->printCoverageInfo( textFile, i );
+      i++;
+    fclose ( textFile );
+    return true;
   void GcovData::printGcnoFileInfo( FILE * textFile )
-      fprintf(
-        textFile,
-        "\nFILE:\t\t\t%s\n"
-        "magic:\t\t\t%x\n"
-        "version:\t\t%x\n"
-        "timestamp:\t\t%x\n"
-        "functions found: \t%u\n\n",
-        gcnoFileName,
-        gcnoPreamble.magic,
-        gcnoPreamble.version,
-        gcnoPreamble.timestamp,
-        numberOfFunctions
+    fprintf(
+      textFile,
+      "\nFILE:\t\t\t%s\n"
+      "magic:\t\t\t%x\n"
+      "version:\t\t%x\n"
+      "timestamp:\t\t%x\n"
+      "functions found: \t%u\n\n",
+      gcnoFileName,
+      gcnoPreamble.magic,
+      gcnoPreamble.version,
+      gcnoPreamble.timestamp,
+      numberOfFunctions
   void GcovData::writeGcovFile( )
@@ -480,16 +480,17 @@ namespace Gcov {
     //std::cerr << "Attempting to run gcov for: " << cFileName << std::endl;
     std::ostringstream command;
     command << "( cd " << rld::path::dirname (cFileName)
-	    << " && gcov " << rld::path::basename (cFileName)
-	    << " &>> gcov.log)";
+            << " && gcov " << rld::path::basename (cFileName)
+            << " &>> gcov.log)";
     //std::cerr << "> " << command << std::endl;
     system( command.str ().c_str () );
   bool GcovData::processCounters(  )
-    bool			status = true;
+    bool                  status = true;
     for (
diff --git a/tester/covoar/GcovData.h b/tester/covoar/GcovData.h
index 3191a45..94f5331 100644
--- a/tester/covoar/GcovData.h
+++ b/tester/covoar/GcovData.h
@@ -14,46 +14,46 @@
 namespace Gcov {
-#define GCDA_MAGIC ((uint32_t) 0x67636461 ) 	/* "gcda" */
-#define GCNO_MAGIC ((uint32_t) 0x67636e6f ) 	/* "gcno" */
+#define GCDA_MAGIC ((uint32_t) 0x67636461 )     /* "gcda" */
+#define GCNO_MAGIC ((uint32_t) 0x67636e6f )     /* "gcno" */
 /* we are using gcc 4.6 release format, coded as "406R" */
 #define GCNO_VERSION ((uint32_t) 0x34303652 )
 /* GCOV tags */
-#define GCOV_TAG_FUNCTION	 		((uint32_t)0x01000000)
-#define GCOV_TAG_BLOCKS		 		((uint32_t)0x01410000)
-#define GCOV_TAG_ARCS		 		((uint32_t)0x01430000)
-#define GCOV_TAG_LINES		 		((uint32_t)0x01450000)
-#define GCOV_TAG_COUNTER 	 		((uint32_t)0x01a10000)
-#define GCOV_TAG_OBJECT_SUMMARY  	((uint32_t)0xa1000000)
-#define GCOV_TAG_PROGRAM_SUMMARY 	((uint32_t)0xa3000000)
+#define GCOV_TAG_FUNCTION               ((uint32_t)0x01000000)
+#define GCOV_TAG_BLOCKS                 ((uint32_t)0x01410000)
+#define GCOV_TAG_ARCS                   ((uint32_t)0x01430000)
+#define GCOV_TAG_LINES                  ((uint32_t)0x01450000)
+#define GCOV_TAG_COUNTER                ((uint32_t)0x01a10000)
+#define GCOV_TAG_OBJECT_SUMMARY         ((uint32_t)0xa1000000)
+#define GCOV_TAG_PROGRAM_SUMMARY        ((uint32_t)0xa3000000)
-typedef std::list<Gcov::GcovFunctionData*> 		functions_t;
-typedef std::list<Gcov::GcovFunctionData*>::iterator	functions_iterator_t;
+typedef std::list<Gcov::GcovFunctionData*>              functions_t;
+typedef std::list<Gcov::GcovFunctionData*>::iterator    functions_iterator_t;
 struct gcov_preamble
-    uint32_t magic;
-    uint32_t version;
-    uint32_t timestamp;
+  uint32_t magic;
+  uint32_t version;
+  uint32_t timestamp;
 struct gcov_frame_header
-    uint32_t tag;
-    uint32_t length;
+  uint32_t tag;
+  uint32_t length;
 struct gcov_statistics
-    uint32_t checksum;		// checksum
-    uint32_t counters;		// number of counters
-    uint32_t runs;		// number of runs
-    uint64_t sum;		// sum of all couter values
-    uint64_t max;		// max value on a single run
-    uint64_t sumMax;		// sum of individual runs max values
+  uint32_t checksum;          // checksum
+  uint32_t counters;          // number of counters
+  uint32_t runs;              // number of runs
+  uint64_t sum;               // sum of all couter values
+  uint64_t max;               // max value on a single run
+  uint64_t sumMax;            // sum of individual runs max values
   /*! @class GcovData
@@ -111,13 +111,13 @@ struct gcov_statistics
   private:
-    uint32_t				numberOfFunctions;
-    gcov_preamble 			gcnoPreamble;
-    char				gcnoFileName[FILE_NAME_LENGTH];
-    char				gcdaFileName[FILE_NAME_LENGTH];
-    char				textFileName[FILE_NAME_LENGTH];
-    char				cFileName[FILE_NAME_LENGTH];
-    functions_t				functions;
+    uint32_t                            numberOfFunctions;
+    gcov_preamble                       gcnoPreamble;
+    char                                gcnoFileName[FILE_NAME_LENGTH];
+    char                                gcdaFileName[FILE_NAME_LENGTH];
+    char                                textFileName[FILE_NAME_LENGTH];
+    char                                cFileName[FILE_NAME_LENGTH];
+    functions_t                         functions;
@@ -128,7 +128,7 @@ struct gcov_statistics
      *  @return true if read was succesfull, false otherwise
     bool readFrame(
-            FILE*	gcovFile
+      FILE*       gcovFile
@@ -140,8 +140,8 @@ struct gcov_statistics
      *  @return Returns length of words read (word = 32bit) or -1 if error ocurred
     int readString(
-            char*	buffer,
-            FILE*	gcovFile
+      char*       buffer,
+      FILE*       gcovFile
@@ -154,8 +154,8 @@ struct gcov_statistics
      *  or -1 if error ocurred
     int readFrameHeader(
-            FILE*		gcovFile
+      FILE*               gcovFile
@@ -169,9 +169,9 @@ struct gcov_statistics
     int readFilePreamble(
-            FILE*         	gcovFile,
-            const uint32_t	desiredMagic
+      FILE*               gcovFile,
+      const uint32_t      desiredMagic
@@ -184,9 +184,9 @@ struct gcov_statistics
      *  @return Returns true if operation was succesfull
     bool readFunctionFrame(
-            FILE*         	gcovFile,
+      FILE*               gcovFile,
diff --git a/tester/covoar/GcovFunctionData.cc b/tester/covoar/GcovFunctionData.cc
index 2e61f88..90b1be0 100644
--- a/tester/covoar/GcovFunctionData.cc
+++ b/tester/covoar/GcovFunctionData.cc
@@ -46,7 +46,7 @@ namespace Gcov {
   bool GcovFunctionData::setFunctionName( const char* fcnName )
-    std::string 	symbolName;
+    std::string   symbolName;
     symbolName = fcnName;
@@ -120,12 +120,12 @@ namespace Gcov {
     uint64_t &countersMax
-    int			i;
+    int              i;
-    countersSum		= 0;
-    countersMax		= 0;
+    countersSum   = 0;
+    countersMax   = 0;
     // Locate relevant counters and copy their values
     i = 0;
@@ -169,14 +169,15 @@ namespace Gcov {
   void GcovFunctionData::addBlock(
-    const uint32_t		id,
-    const uint32_t		flags,
-    const char *		sourceFileName
+    const uint32_t  id,
+    const uint32_t  flags,
+    const char *    sourceFileName
     gcov_block_info block;
     numberOfBlocks++;
-    block.id 	= id;
+    block.id    = id;
     block.flags = flags;
     block.numberOfLines = 0;
     block.counter = 0;
@@ -233,7 +234,7 @@ namespace Gcov {
     uint32_t  function_number
-    uint32_t	    baseAddress = 0;
+    uint32_t        baseAddress = 0;
     uint32_t        baseSize;
     uint32_t        currentAddress;
     std::list<Coverage::ObjdumpProcessor::objdumpLine_t>::iterator   instruction;
@@ -314,7 +315,7 @@ namespace Gcov {
     if ( !blocks.empty() ) {
       blockIterator = blocks.begin();
-      while (	blockIterator != blocks.end( ) ){
+      while ( blockIterator != blocks.end() ){
         if ( blockIterator->id ==  id)
           break;
         blockIterator++;
@@ -375,7 +376,7 @@ namespace Gcov {
     blocks_iterator_t block
-    std::list<uint32_t>::iterator	line;
+    std::list<uint32_t>::iterator  line;
     fprintf(
       textFile,
@@ -399,10 +400,10 @@ namespace Gcov {
     uint32_t               currentAddress = 0;
-    blocks_iterator_t 	   blockIterator;
-    blocks_iterator_t 	   blockIterator2;
-    arcs_iterator_t 	   arcIterator;
-    arcs_iterator_t 	   arcIterator2;
+    blocks_iterator_t      blockIterator;
+    blocks_iterator_t      blockIterator2;
+    arcs_iterator_t        arcIterator;
+    arcs_iterator_t        arcIterator2;
     std::list<uint64_t>    taken;       // List of taken counts for branches
     std::list<uint64_t>    notTaken;    // List of not taken counts for branches
@@ -525,7 +526,7 @@ namespace Gcov {
         arcIterator->counter = blockIterator->counter;
         blockIterator2 =  blocks.begin();
-        while ( arcIterator->destinationBlock != blockIterator2->id)  	//TODO: ADD FAILSAFE
+        while ( arcIterator->destinationBlock != blockIterator2->id)  //TODO: ADD FAILSAFE
           blockIterator2++;
         blockIterator2->counter += arcIterator->counter;
         return true;
@@ -536,7 +537,7 @@ namespace Gcov {
         //fprintf( stderr, "DEBUG: Found simple arc %3u -> %3u\n", arcIterator->sourceBlock, arcIterator->destinationBlock );
         blockIterator2 =  blocks.begin();;
           blockIterator2++;
@@ -547,7 +548,7 @@ namespace Gcov {
         //fprintf( stderr, "DEBUG: Found fake branching arc %3u -> %3u\n", arcIterator->sourceBlock, arcIterator->destinationBlock );
           blockIterator2++;
@@ -564,7 +565,7 @@ namespace Gcov {
             std::list<uint64_t> * notTaken
diff --git a/tester/covoar/GcovFunctionData.h b/tester/covoar/GcovFunctionData.h
index 959d8ff..812b45c 100644
--- a/tester/covoar/GcovFunctionData.h
+++ b/tester/covoar/GcovFunctionData.h
@@ -14,35 +14,35 @@
 namespace Gcov {
-#define FUNCTION_NAME_LENGTH	        64
-#define FILE_NAME_LENGTH		256
+#define FUNCTION_NAME_LENGTH    64
+#define FILE_NAME_LENGTH        256
-#define ON_TREE_ARC_FLAG		0x1
-#define FAKE_ARC_FLAG			0x2
-#define FALLTHROUGH_ARC_FLAG		0x4
+#define ON_TREE_ARC_FLAG        0x1
+#define FAKE_ARC_FLAG           0x2
+#define FALLTHROUGH_ARC_FLAG    0x4
 struct gcov_arc_info
-    uint32_t	sourceBlock;
-    uint32_t	destinationBlock;
-    uint32_t	flags;
-    uint64_t	counter;
+  uint32_t    sourceBlock;
+  uint32_t    destinationBlock;
+  uint32_t    flags;
+  uint64_t    counter;
 struct gcov_block_info
-    uint32_t 			id;
-    uint32_t			flags;
-    uint32_t			numberOfLines;
-    uint64_t 			counter;
-    char			sourceFileName[FILE_NAME_LENGTH];
-    std::list<uint32_t>		lines;
+  uint32_t                    id;
+  uint32_t                    flags;
+  uint32_t                    numberOfLines;
+  uint64_t                    counter;
+  char                        sourceFileName[FILE_NAME_LENGTH];
+  std::list<uint32_t>         lines;
-typedef std::list<gcov_arc_info>		arcs_t;
-typedef std::list<gcov_arc_info>::iterator	arcs_iterator_t;
-typedef std::list<gcov_block_info>		blocks_t;
-typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
+typedef std::list<gcov_arc_info>                arcs_t;
+typedef std::list<gcov_arc_info>::iterator      arcs_iterator_t;
+typedef std::list<gcov_block_info>              blocks_t;
+typedef std::list<gcov_block_info>::iterator    blocks_iterator_t;
   /*! @class GcovFunctionData
@@ -55,7 +55,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  This method constructs a GcovFunctionData instance.
-	GcovFunctionData();
+        GcovFunctionData();
      *  This method destructs a GcovFunctionData instance.
@@ -68,7 +68,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] chk stores the checksum value
     void setChecksum(
-            const uint32_t		chk
+      const uint32_t              chk
@@ -77,7 +77,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] idNumber stores the id value
     void setId(
-            const uint32_t		idNumber
+      const uint32_t              idNumber
@@ -86,7 +86,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] lineNo passes number of the line begining the function
     void setFirstLineNumber(
-            const uint32_t		lineNo
+      const uint32_t              lineNo
@@ -98,7 +98,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @return Returns TRUE if the method succeeded and FALSE if it failed.
     bool setFunctionName(
-            const char*			fcnName
+      const char*                 fcnName
@@ -109,7 +109,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
     bool setFileName(
-            const char*			fileName
+      const char*                 fileName
@@ -121,8 +121,8 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
     void setBlockFileName(
-            const blocks_iterator_t		block,
+      const blocks_iterator_t             block,
@@ -153,7 +153,12 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[out] countersSum used to return sum counters values
      *  @param[out] countersMax used to return max counter value
-    void getCounters( uint64_t* counterValues, uint32_t &countersFound, uint64_t &countersSum, uint64_t &countersMax );
+    void getCounters(
+      uint64_t* counterValues,
+      uint32_t &countersFound,
+      uint64_t &countersSum,
+      uint64_t &countersMax
      *  This method adds new arc to arc list
@@ -162,9 +167,9 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] destination passes destination block number
     void addArc(
-            uint32_t	source,
-            uint32_t	destination,
-            uint32_t	flags
+      uint32_t    source,
+      uint32_t    destination,
+      uint32_t    flags
@@ -174,8 +179,8 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] line passes the line number
     void addBlockLine(
@@ -186,7 +191,7 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @return Returns iterator to a matching block or NULL for error.
     blocks_iterator_t findBlockById(
-            const uint32_t		id
+      const uint32_t              id
@@ -197,9 +202,9 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] sourceFileName passes containing file name
     void addBlock(
@@ -219,8 +224,8 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] arc passes iterator identifying arc
     void printArcInfo(
-            FILE * textFile,
+      FILE * textFile,
@@ -229,8 +234,8 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] block passes iterator identifying block
     void printBlockInfo(
-            FILE * textFile,
+      FILE * textFile,
@@ -240,22 +245,22 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
   private:
-    uint32_t		id;
-    uint32_t		firstLineNumber;
-    uint32_t		numberOfBlocks;
-    uint32_t		numberOfArcs;
-    arcs_t		arcs;
-    blocks_t		blocks;
-    char		functionName[FUNCTION_NAME_LENGTH];
+    uint32_t            id;
+    uint32_t            firstLineNumber;
+    uint32_t            numberOfBlocks;
+    uint32_t            numberOfArcs;
+    arcs_t              arcs;
+    blocks_t            blocks;
+    char                functionName[FUNCTION_NAME_LENGTH];
      *  This member contains the unified or merged coverage map
      *  and symbol info for the symbol.
     Coverage::CoverageMapBase*          coverageMap;
-    Coverage::SymbolInformation* 	symbolInfo;
+    Coverage::SymbolInformation*        symbolInfo;
      *  This method creates list of taken/not taken values
@@ -265,8 +270,8 @@ typedef std::list<gcov_block_info>::iterator	blocks_iterator_t;
      *  @param[in] notTaken   used to return not taken counts list
     bool processBranches(
-            std::list<uint64_t> * taken ,
-            std::list<uint64_t> * notTaken
+      std::list<uint64_t> * taken,
+      std::list<uint64_t> * notTaken
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index 7137016..fa1ebf6 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -617,9 +617,9 @@ namespace Coverage {
     for ( unsigned int i=0 ; i < explanation->explanation.size(); i++) {
       fprintf(
-	report,
-	"%s\n",
-	explanation->explanation[i].c_str()
+        report,
+        "%s\n",
+        explanation->explanation[i].c_str()
     CloseFile( report );
diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
index 00062cc..b3a5e58 100644
--- a/tester/covoar/SymbolTable.cc
+++ b/tester/covoar/SymbolTable.cc
@@ -115,9 +115,9 @@ namespace Coverage {
   void SymbolTable::dumpSymbolTable( void )
-    symbolInfo   		symbolTable;
-    symbolInfoIterator_t 	symbolIterator;
-    infoIterator_t		infoIterator;
+    symbolInfo            symbolTable;
+    symbolInfoIterator_t  symbolIterator;
+    infoIterator_t        infoIterator;
     for (infoIterator = info.begin() ; infoIterator != info.end(); infoIterator++)
diff --git a/tester/covoar/SymbolTable.h b/tester/covoar/SymbolTable.h
index 4149868..f2899d3 100644
--- a/tester/covoar/SymbolTable.h
+++ b/tester/covoar/SymbolTable.h
@@ -33,9 +33,7 @@ namespace Coverage {
     } symbolInfo_t;
    typedef std::list< symbolInfo_t > symbolInfo;
-   typedef std::list< symbolInfo_t >::iterator	symbolInfoIterator_t;
+   typedef std::list< symbolInfo_t >::iterator  symbolInfoIterator_t;
      *  This method constructs a SymbolTable instance.
diff --git a/tester/covoar/Target_riscv.h b/tester/covoar/Target_riscv.h
index c1cf7ab..64a63d4 100644
--- a/tester/covoar/Target_riscv.h
+++ b/tester/covoar/Target_riscv.h
@@ -68,7 +68,7 @@ namespace Target {
   bool isNopLine(
     const char* const line,
-	int&              size
+    int&              size
@@ -81,15 +81,15 @@ namespace Target {
   bool isBranch(
     const char* const instruction
- private:
+  private:
   TargetBase *Target_riscv_Constructor(
     std::string        targetName
 #endif
1.8.3.1
