Questions about waf config system: "grp" and updating configure.ac
Chris Johns
chrisj at rtems.org
Fri Apr 9 06:28:08 UTC 2021
On 9/4/21 3:02 pm, Sebastian Huber wrote:
> I try to not break the old build system, however, I don't add new stuff to it.
> From my point of view the old build system should be removed. The major blocking
> point for the removal is that nobody had the time to convert the BSP builder to
> use the new build system.
It looks like recent changes have broken the autotool build system...
https://lists.rtems.org/pipermail/build/2021-April/027232.html
Is there any point in it staying if it does not work?
