Questions about waf config system: "grp" and updating configure.ac
Sebastian Huber
Fri Apr 9 06:45:41 UTC 2021
On 09/04/2021 08:28, Chris Johns wrote:
> On 9/4/21 3:02 pm, Sebastian Huber wrote:
>> I try to not break the old build system, however, I don't add new stuff to it.
>> From my point of view the old build system should be removed. The major blocking
>> point for the removal is that nobody had the time to convert the BSP builder to
>> use the new build system.
> It looks like recent changes have broken the autotool build system...
> https://lists.rtems.org/pipermail/build/2021-April/027232.html
> Is there any point in it staying if it does not work?
This failure is due to an out dated tool chain used by the build bot.
I think only powerpc is broken due to the start/end file changes in GCC.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
