Questions about waf config system: "grp" and updating configure.ac
Chris Johns
chrisj at rtems.org
Fri Apr 9 07:03:23 UTC 2021
On 9/4/21 4:45 pm, Sebastian Huber wrote:
> On 09/04/2021 08:28, Chris Johns wrote:
>> On 9/4/21 3:02 pm, Sebastian Huber wrote:
>>> I try to not break the old build system, however, I don't add new stuff to it.
>>> From my point of view the old build system should be removed. The major
>>> blocking
>>> point for the removal is that nobody had the time to convert the BSP builder to
>>> use the new build system.
>> It looks like recent changes have broken the autotool build system...
>> https://lists.rtems.org/pipermail/build/2021-April/027232.html
>> Is there any point in it staying if it does not work?
> This failure is due to an out dated tool chain used by the build bot.
> I think only powerpc is broken due to the start/end file changes in GCC.
I thought it failed on a networking .am that has been removed. This is new.
