Questions about waf config system: "grp" and updating configure.ac
Peter Dufault
dufault at hda.com
Fri Apr 9 11:47:19 UTC 2021
> On Apr 9, 2021, at 03:03 , Chris Johns <chrisj at rtems.org> wrote:
> On 9/4/21 4:45 pm, Sebastian Huber wrote:
>> On 09/04/2021 08:28, Chris Johns wrote:
>>> On 9/4/21 3:02 pm, Sebastian Huber wrote:
>>>> I try to not break the old build system, however, I don't add new stuff to it.
>>>> From my point of view the old build system should be removed. The major
>>>> blocking
>>>> point for the removal is that nobody had the time to convert the BSP builder to
>>>> use the new build system.
>>> It looks like recent changes have broken the autotool build system...
>>> https://lists.rtems.org/pipermail/build/2021-April/027232.html
>>> Is there any point in it staying if it does not work?
I noticed that "mpc55xxevb/configure.ac" still uses "BSP_DEFAULT_BAUD_RATE" while the "waf" build system changed the code and configuration name to the standardized "BSP_CONSOLE_BAUD". I didn't fix it since it's not associated with the powerpc/shared changes, but it is bit-rot.
If the old build system isn't supposed to be kept up-to-date I recommend removing it.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210409/96b3f49c/attachment.bin>
