[PATCH rtems-net-legacy] bsp_drivers: Use os.path for compatibility with non Unix host
Vijay Kumar Banerjee
vijay at rtems.org
Wed Apr 14 05:49:52 UTC 2021
bsp_drivers.py | 26 +++++++++++++-------------
1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/bsp_drivers.py b/bsp_drivers.py
index 3ca10c6..4a07847 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -36,18 +36,18 @@ def bsp_files(bld):
include_dirs = {}
include_files = []
- special_case_dirs = {'atsamv': './bsps/arm/atsam',
- 'lm32_evr': './bsps/lm32',
- 'lpc24xx_ea': './bsps/arm/shared/'}
+ special_case_dirs = {'atsamv': 'bsps/arm/atsam',
+ 'lm32_evr': 'bsps/lm32',
+ 'lpc24xx_ea': 'bsps/arm/shared/'}
special_case_sources = {'leon2':
- ['./bsps/shared/grlib/net/network_interface_add.c',
- './bsps/shared/grlib/net/greth.c'],
+ ['bsps/shared/grlib/net/network_interface_add.c',
+ 'bsps/shared/grlib/net/greth.c'],
'leon3':
'griscv':
- './bsps/shared/grlib/net/greth.c']}
+ 'bsps/shared/grlib/net/greth.c']}
bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
@@ -57,9 +57,9 @@ def bsp_files(bld):
include_dirs[bsp] = []
source_files[bsp] = []
if bsp not in special_case_dirs:
- source_dir = os.walk(os.path.join('./bsps', arch, bsp))
+ source_dir = os.walk(os.path.join('bsps', arch, bsp))
else:
- source_dir = os.walk(special_case_dirs[bsp])
+ source_dir = os.walk(os.path.expanduser(special_case_dirs[bsp]))
for root, dirs, files in source_dir:
for name in files:
ext = os.path.splitext(name)[1]
@@ -69,6 +69,6 @@ def bsp_files(bld):
if root not in include_dirs[bsp]:
include_dirs[bsp].append(root)
if bsp in special_case_sources:
- source_files[bsp].extend(special_case_sources[bsp])
- include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
+ source_files[bsp].extend([os.path.expanduser(f) for f in special_case_sources[bsp]])
+ include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
return (include_dirs, source_files)
2.26.2
