[PATCH RTEMS v2 0/1] bsp/beagle: Refactored i2c driver and Updated
Christian Mauderer
oss at c-mauderer.de
Sun Apr 18 18:27:26 UTC 2021
Hello Niteesh,
looks good to me. I'll wait two or three days before pushing so that
others can review the libbsd patch too. Please ping me on Wednesday if I
didn't push it by then.
Best regards
Christian
On 18/04/2021 17:19, Niteesh G. S. wrote:
> Hello Christian,
> On Sun, Apr 18, 2021 at 4:54 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
> Hello Niteesh,
> sorry for not taking a look earlier.
> No problem
> The patches seem OK for me. Just a tiny change request:
> I know that I suggested the "rtems,path" for the device tree. When
> testing I noted that we have the rtems-i2c driver in libbsd which is
> more or less just a compatibility layer between libbsd and RTEMS. This
> driver uses "rtems,i2c-path" instead of "rtems,path". Maybe you could
> add one of these two solutions:
> 1. Either change "rtems,path" to "rtems,i2c-path" in your driver.
> 2. Or add "rtems,path" as an additional possible path to
> "libbsd/rtemsbsd/sys/dev/iicbus/rtems-i2c.c". Basically that would just
> mean that in the error case of the current OF_getprop_alloc you just
> try
> the "rtems,path" before failing.
> I really like the short and universal name of "rtems,path" so I would
> prefer the second solution. But I would be OK with the first one too.
> I have sent a patch for your preferred solution.
> Patches that are pending are:
> 1) https://lists.rtems.org/pipermail/devel/2021-April/066458.html
> <https://lists.rtems.org/pipermail/devel/2021-April/066458.html>
> 2) https://lists.rtems.org/pipermail/devel/2021-April/066460.html
> <https://lists.rtems.org/pipermail/devel/2021-April/066460.html>
> 3) https://lists.rtems.org/pipermail/devel/2021-April/066629.html
> <https://lists.rtems.org/pipermail/devel/2021-April/066629.html>
> Thanks,
> Niteesh.
> Best regards
> Christian
> On 18/04/2021 06:20, Niteesh G. S. wrote:
> > ping.
> > On Sun, Apr 11, 2021 at 12:45 AM G S Niteesh Babu
> <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
> > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>> wrote:
> > The following two patches update the Beagle BSP i2c driver to use
> > device tree based initialization and the documentation related to
> > it.
> > G S Niteesh Babu (1):
> > bsps/beagle: Refactored i2c driver
> > bsps/arm/beagle/i2c/bbb-i2c.c | 122
> > bsps/arm/beagle/include/bsp.h | 4 +
> > bsps/arm/beagle/include/bsp/i2c.h | 32 +-------
> > bsps/arm/beagle/start/bspstart.c | 51 +++++++++----
> > 4 files changed, 114 insertions(+), 95 deletions(-)
> > 2.17.1
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
