[PATCH rtems-docs] legacy-networking: Add note with build instructions for rtems-net-legacy
Gedare Bloom
gedare at rtems.org
Thu Apr 22 18:18:25 UTC 2021
On Thu, Apr 22, 2021 at 12:08 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> ping. :)
> On Mon, Apr 19, 2021 at 12:12 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > legacy-networking/index.rst | 1 +
> > legacy-networking/quick_start.rst | 29 +++++++++++++++++++++++++++++
> > 2 files changed, 30 insertions(+)
> > create mode 100644 legacy-networking/quick_start.rst
> > diff --git a/legacy-networking/index.rst b/legacy-networking/index.rst
> > index b85119d..acbfd35 100644
> > --- a/legacy-networking/index.rst
> > +++ b/legacy-networking/index.rst
> > @@ -22,6 +22,7 @@ RTEMS Legacy Network User Manual (|version|).
> > :numbered:
> > preface
> > + quick_start
> > network_task_structure
> > networking_driver
> > using_networking_rtems_app
> > diff --git a/legacy-networking/quick_start.rst b/legacy-networking/quick_start.rst
> > new file mode 100644
> > index 0000000..97ea71c
> > --- /dev/null
> > +++ b/legacy-networking/quick_start.rst
> > @@ -0,0 +1,29 @@
> > +.. SPDX-License-Identifier: CC-BY-SA-4.0
> > +Quick Start
> > +This legacy networking is now a standalone repository and needs to be built
> > +separately.
> > +The repository can be found here: https://git.rtems.org/rtems-net-legacy/
> > +The RSB build recipe for legacy networking is:
I guess it should be obvious, but maybe make a clarification like "on
the powerpc beatnik BSP with rtems version 6 for example is:"
> > + .. code-block:: shell
> > + ../source-builder/sb-set-builder \
> > + --prefix=/path/to/rtems/prefix \
> > + 6/rtems-net-legacy \
> > + --host=powerpc-rtems6 \
> > + --with-rtems-bsp=beatnik
> > +Manually building the rtems-net-legacy repo:
> > + git submodule init
> > + git submodule update
> > + ./waf configure --prefix=/path/to/rtems/prefix
> > + ./waf
> > + ./waf install
And maybe indicate that more details can be found in the README.waf?
> > 2.26.2
> devel mailing list
> devel at rtems.org
