[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Christian Mauderer
oss at c-mauderer.de
Sun Aug 8 09:30:46 UTC 2021
Hello Husni,
On 08/08/2021 11:15, Ahamed Husni wrote:
> Hi Christian,
> On Sun, Aug 8, 2021 at 1:36 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
> Hello Husni,
> On 07/08/2021 21:56, Ahamed Husni wrote:
> > Hi Christian,
> > Are there any issues I should address in this patch set?
> I think the big open question is the one from Chris:
> https://lists.rtems.org/pipermail/devel/2021-July/068634.html
> <https://lists.rtems.org/pipermail/devel/2021-July/068634.html>
> You mentioned that you filtered the ones for the imported code. That's
> OK for most symbols if they are not relevant for the part where you
> work
> on. But Chris copied a whole block of "extern struct
> usb_temp_device_desc *". It's not clear for me whether you filtered
> some
> of them or whether they haven't been generated.
> The "extern struct usb_temp_device_desc *" block is in the
> usb_template.h header.
> These are not generated structs.
> These usb device descriptor structs are for each usb device currently
> supported by
> freebsd. This patch set only imports the CDC Ethernet device template.
> So we can
> exclude the other structs with #ifndef __rtems__ if necessary. If the
> extra structs should
> be excluded, I can send a patch v3.
> If they are generated: Please keep them. Basically keep everything that
> is in one of the files that you touch, except if you have a good reason
> why the symbol should _not_ be added.
> If they are not generated: Please clearly say that.
> Those externs are not generated. They are in the original freebsd source.
> https://github.com/freebsd/freebsd-src/blob/main/sys/dev/usb/template/usb_template.h#L106
> <https://github.com/freebsd/freebsd-src/blob/main/sys/dev/usb/template/usb_template.h#L106>
What I wanted to say was: If the defines like
#define usb_template_cdce _bsd_usb_template_cdce
are not generated for the other externa that Chris listed, please say
it. I just checked and they are not. So I'm OK with that.
So if I have followed the discussion correctly, there are no further
changes (except for the typo in one file), correct?
The branches usb-cdce and usb-cdce12 are up to date?
Best regards
Christian
> Best regards,
> Husni.
> Best regards
> Christian
> > On Mon, Aug 2, 2021 at 12:09 PM Christian MAUDERER
> > <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>
> <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > Hello Husni,
> > Am 01.08.21 um 19:59 schrieb Ahamed Husni:
> > > Hi Christian,
> > > On Sun, Aug 1, 2021 at 4:57 PM Christian Mauderer
> > <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
> <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>
> <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>> wrote:
> > > Hello Husni,
> > > just tested that and it works fine. With a simple curl
> I can
> > reach
> > > about
> > > 8.5 MByte/s sending to the beagle and 19.5 MByte/s
> receiving
> > from it.
> > > That's 68 Mbps for sending. That's an acceptable speed
> isn't it?
> > At the moment I would be OK with basically any speed. It was
> just some
> > information so that someone who finds the mail knows what he
> can expect.
> > It would be interesting to see how the speeds compare to a
> FreeBSD
> > setup
> > on the Beagle. If there is no bug in our port, it should be about
> > the same.
> > Best regards
> > Christian
> > > Please take a look at the points that Chris Johns
> asked. As
> > soon as
> > > these are addressed, I think the patches could be merged.
> > > I just replied to it now. Sorry for the delay.
> > > Please also make the documentation that you started
> for this more
> > > public
> > > visible. In other words: Send it as patches to the
> list and
> > not only as
> > > a link to some branch!
> > > Noted.
> > > Best regards
> > > Christian
> > > On 28/07/2021 13:56, Husni Faiz wrote:
> > > > This set of patches import the drivers from freebsd and
> > > > configures it for the beagle bsp.
> > > > Github Branch for the commits
> https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>>
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>>>
> > > > Patch for 6-freebsd-12 branch
> https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>>
> <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>>>
> > > > Husni Faiz (5):
> > > > usb_template:Import CDC Ethernet
> > > > usb_template: Configure template driver only for CDC
> > Ethernet
> > > > nexus-devices: Include CDC Ethernet for Beagle
> > > > libbsd.py: add usb template files
> > > > create-kernel-namespace for USB Template driver
> > > > buildset/default.ini |
> 1 +
> > > > buildset/minimal.ini |
> 3 +-
> > > > freebsd/sys/dev/usb/template/usb_template.c | 1493
> > > > freebsd/sys/dev/usb/template/usb_template.h |
> 130 ++
> > > > .../sys/dev/usb/template/usb_template_cdce.c |
> 355 ++++
> > > > freebsd/sys/dev/usb/usb_device.c |
> 8 +-
> > > > libbsd.py |
> 25 +
> > > > rtemsbsd/include/bsp/nexus-devices.h |
> 5 +
> > > > .../machine/rtems-bsd-kernel-namespace.h |
> 5 +
> > > > .../include/machine/rtems-bsd-nexus-bus.h |
> 19 +
> > > > 10 files changed, 2041 insertions(+), 3 deletions(-)
> > > > create mode 100644
> > > > create mode 100644
> > > > create mode 100644
> > freebsd/sys/dev/usb/template/usb_template_cdce.c
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org <mailto:devel at rtems.org>
> <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> > > http://lists.rtems.org/mailman/listinfo/devel
> <http://lists.rtems.org/mailman/listinfo/devel>
> <http://lists.rtems.org/mailman/listinfo/devel>>
> > embedded brains GmbH
> > Herr Christian MAUDERER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: christian.mauderer at embedded-brains.de
> > phone: +49-89-18 94 741 - 18
> > fax: +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen,
> Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> <https://embedded-brains.de/datenschutzerklaerung/>
> <https://embedded-brains.de/datenschutzerklaerung/>>
