[PATCH rtems-libbsd v2 0/5] Beagle BSP: USB Template Driver for CDC Ethernet
Ahamed Husni
ahamedhusni73 at gmail.com
Sun Aug 8 09:15:35 UTC 2021
Hi Christian,
On Sun, Aug 8, 2021 at 1:36 PM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Husni,
> On 07/08/2021 21:56, Ahamed Husni wrote:
> > Hi Christian,
> > Are there any issues I should address in this patch set?
> I think the big open question is the one from Chris:
> https://lists.rtems.org/pipermail/devel/2021-July/068634.html
> You mentioned that you filtered the ones for the imported code. That's
> OK for most symbols if they are not relevant for the part where you work
> on. But Chris copied a whole block of "extern struct
> usb_temp_device_desc *". It's not clear for me whether you filtered some
> of them or whether they haven't been generated.
The "extern struct usb_temp_device_desc *" block is in the usb_template.h
header.
These are not generated structs.
These usb device descriptor structs are for each usb device currently
supported by
freebsd. This patch set only imports the CDC Ethernet device template. So
we can
exclude the other structs with #ifndef __rtems__ if necessary. If the extra
structs should
be excluded, I can send a patch v3.
If they are generated: Please keep them. Basically keep everything that
> is in one of the files that you touch, except if you have a good reason
> why the symbol should _not_ be added.
> If they are not generated: Please clearly say that.
> Those externs are not generated. They are in the original freebsd source.
https://github.com/freebsd/freebsd-src/blob/main/sys/dev/usb/template/usb_template.h#L106
Best regards,
Husni.
Best regards
> Christian
> > On Mon, Aug 2, 2021 at 12:09 PM Christian MAUDERER
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > Hello Husni,
> > Am 01.08.21 um 19:59 schrieb Ahamed Husni:
> > > Hi Christian,
> > > On Sun, Aug 1, 2021 at 4:57 PM Christian Mauderer
> > <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
> > > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
> > > Hello Husni,
> > > just tested that and it works fine. With a simple curl I can
> > reach
> > > about
> > > 8.5 MByte/s sending to the beagle and 19.5 MByte/s receiving
> > from it.
> > > That's 68 Mbps for sending. That's an acceptable speed isn't it?
> > At the moment I would be OK with basically any speed. It was just
> some
> > information so that someone who finds the mail knows what he can
> expect.
> > It would be interesting to see how the speeds compare to a FreeBSD
> > setup
> > on the Beagle. If there is no bug in our port, it should be about
> > the same.
> > Best regards
> > Christian
> > > Please take a look at the points that Chris Johns asked. As
> > soon as
> > > these are addressed, I think the patches could be merged.
> > > I just replied to it now. Sorry for the delay.
> > > Please also make the documentation that you started for this
> more
> > > public
> > > visible. In other words: Send it as patches to the list and
> > not only as
> > > a link to some branch!
> > > Noted.
> > > Best regards
> > > Christian
> > > On 28/07/2021 13:56, Husni Faiz wrote:
> > > > This set of patches import the drivers from freebsd and
> > > > configures it for the beagle bsp.
> > > > Github Branch for the commits
> > > > https://github.com/drac98/rtems-libbsd/commits/usb-cdce
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce>>
> > > > Patch for 6-freebsd-12 branch
> > > > https://github.com/drac98/rtems-libbsd/commits/usb-cdce12
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>
> > <https://github.com/drac98/rtems-libbsd/commits/usb-cdce12>>
> > > > Husni Faiz (5):
> > > > usb_template:Import CDC Ethernet
> > > > usb_template: Configure template driver only for CDC
> > Ethernet
> > > > nexus-devices: Include CDC Ethernet for Beagle
> > > > libbsd.py: add usb template files
> > > > create-kernel-namespace for USB Template driver
> > > > buildset/default.ini | 1 +
> > > > buildset/minimal.ini | 3 +-
> > > > freebsd/sys/dev/usb/template/usb_template.c | 1493
> > > > freebsd/sys/dev/usb/template/usb_template.h | 130 ++
> > > > .../sys/dev/usb/template/usb_template_cdce.c | 355 ++++
> > > > freebsd/sys/dev/usb/usb_device.c | 8 +-
> > > > libbsd.py | 25 +
> > > > rtemsbsd/include/bsp/nexus-devices.h | 5 +
> > > > .../machine/rtems-bsd-kernel-namespace.h | 5 +
> > > > .../include/machine/rtems-bsd-nexus-bus.h | 19 +
> > > > 10 files changed, 2041 insertions(+), 3 deletions(-)
> > > > create mode 100644
> > > > create mode 100644
> > > > create mode 100644
> > freebsd/sys/dev/usb/template/usb_template_cdce.c
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org <mailto:devel at rtems.org>
> > > http://lists.rtems.org/mailman/listinfo/devel
> > <http://lists.rtems.org/mailman/listinfo/devel>
> > embedded brains GmbH
> > Herr Christian MAUDERER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: christian.mauderer at embedded-brains.de
> > phone: +49-89-18 94 741 - 18
> > fax: +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> > <https://embedded-brains.de/datenschutzerklaerung/>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210808/e8fe6f44/attachment.html>
