New validation test suites
zack leung zakthertemsdev at gmail.com
Tue Dec 14 01:47:47 UTC 2021
What tasks can I do that can help with ECSS compliance?
Zack
On Mon, 13 Dec 2021 at 21:40, Chris Johns <chrisj at rtems.org> wrote:
> On 14/12/21 1:53 am, Sebastian Huber wrote:
> > Hello,
> > the ESA activity to pre-qualify parts of RTEMS according to ECSS
> requirements is
> > nearly complete. There is a short presentation available here:
> > https://indico.esa.int/event/374/timetable/
> Was the change in memory usage for 4.8 of 23812 bytes to 68896 explained?
> > We finished the specification of the pre-qualified RTEMS feature set. The
> > specification is available in an RTEMS Project repository:
> > https://git.rtems.org/rtems-central/tree/spec
> I had a quick look. Is there a more user friendly view of this data?
> I think the term "specification" is a little bit misleading because the
> data
> files are not easily read by a person. I understand this is the
> specification
> data set however it is not what I am traditionally use to seeing.
> > The validation tests are generated from the specification using the
> > "./spec2modules.py" script and end up in the RTEMS sources of a Git
> submodule. I
> > think the specification and the generation tool is now sufficiently
> stable so
> > that the validation test code can be integrated in the RTEMS master
> branch. The
> > patch set is too big for the mailing list, so you can review it here:
> > https://git.rtems.org/sebh/rtems.git/log/?h=validation
> The link failed.
> > https://github.com/sebhub/rtems/tree/validation
> The header in a test says the regeneration instructions are in the
> engineering
> manual but I could not quickly find them?
> > The patch set is organized so that general support code for the
> validation tests
> > is added first and then there are commits for each pre-qualified Classic
> API
> > Manager or subsystem.
> > I did build all BSPs with the patch set. The validation tests use only
> > statically allocated resources.
> Are the validation tests compatible with rtems-test?
> How many test executables does this add to the testsuite?
> What hardware have the validation tests been run on? Any tier 1 archs?
> Is there anything that interprets the new test output format? It looks
> like lots
> of great info but a little difficult to read.
> > Some low memory targets are not able to link all test suites.
> Are these excluded in the normal way?
> Chris
> devel mailing list
> devel at rtems.org
