Unable to use make command to build "Hello world" Program
Rohan kumar
krohan8870 at gmail.com
Wed Feb 3 14:29:19 UTC 2021
Actually I followed this document
https://docs.rtems.org/branches/master/user/start/bsp-build.html#quickstartbspbuild-manual
to
build bsp manually
as mentioned in the "GSoc getting started" blog.
Also yes when I run "./waf" command "Waf: Leaving directory
`/home/rohan/devlopment/src/rtems/build/sparc/erc32'
" this was the final output as you said.
But I am actually stuck in running Hello world program
https://docs.rtems.org/branches/master/user/start/gsoc.html#prove-you-can-work-on-rtems
this
document says to run "make" command but the folder "/build/b-erc32" is
empty. So I was confused about how to run Hello world.
On Wed, Feb 3, 2021 at 6:36 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Feb 3, 2021, 6:43 AM Rohan kumar <krohan8870 at gmail.com> wrote:
>> Hello all,
>> I am trying to run Hello World program but when run the command "make" to
>> build, the error came "make: *** No targets specified and no makefile
>> found. Stop". Actually there is nothing in the "/build/b-erc32" folder
>> its just empty and
> I'm not sure what you did. The mention of b-erc32 hints at configure and
> autotools but you mention waf. Waf leaves the results in rtems/build and
> you run waf again.
> This seems to be mixing the old and new build infrastructure instructions.
> Is there something that needs more attention in the documentation as we
> move to waf only?
> also there in the step "Test a BSP" I got two failures too.
> These results look pretty good. Minimum probably needs to be addressed
> from a tester perspective and sometimes the DL tests fail as the tools
> update.
>> Passed: 557
>> Failed: 2
>> User Input: 6
>> Expected Fail: 1
>> Indeterminate: 0
>> Benchmark: 3
>> Timeout: 0
>> Test too long: 0
>> Invalid: 0
>> Wrong Version: 0
>> Wrong Build: 0
>> Wrong Tools: 0
>> Total: 569
>> Failures:
>> dl06.exe
>> minimum.exe
>> User Input:
>> capture.exe
>> dl10.exe
>> top.exe
>> fileio.exe
>> termios.exe
>> monitor.exe
>> Expected Fail:
>> psxfenv01.exe
>> Benchmark:
>> linpack.exe
>> dhrystone.exe
>> whetstone.exe
>> Average test time: 0:00:00.283888
>> Testing time : 0:02:41.532720
>> I am currently working on the master branch and trying to build
>> sparc-erc32. Do I have to run the ./waf again I am not sure any direction
>> will be very helpful.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/3c6c33e6/attachment.html>
