Standalone repository for libnetworking stack
Vijay Kumar Banerjee vijay at rtems.org
Wed Feb 10 00:47:53 UTC 2021
On Tue, Feb 9, 2021 at 3:31 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/2/21 10:17 am, Vijay Kumar Banerjee wrote:
> > Hello Christian, Joel, Chris,
> > On Fri, Feb 5, 2021 at 3:41 PM Chris Johns <chrisj at rtems.org> wrote:
> >> On 6/2/21 8:28 am, Joel Sherrill wrote:
> >>> On Fri, Feb 5, 2021 at 2:54 PM Christian Mauderer <oss at c-mauderer.de
> >>> <mailto:oss at c-mauderer.de>> wrote:
> >>>     Hello Vijay,
> >>>     On 05/02/2021 19:41, Vijay Kumar Banerjee wrote:
> >>>     > Hello,
> >>>     > I'm currently working on separating the libnetworking stack into its
> >>>     > standalone repository that can be built separately with waf. The current
> >>>     > status of the project is that I have a working rtems-libnetworking
> >>>     > repository [1] that builds with waf (hasn't been tested with any test
> >>>     > cases yet). And In my fork of RTEMS I have separated the libnetworking
> >>>     > stack [2].
> >> If you have not already done so I suggest you create repos in your personal area
> >> on dispatch.rtems.org and these will appear on the cgit page. It is a simple way
> >> to get exposure to the work.
> > I do have some repos in my area in dispatch.rtems.org but for some
> > reason they don't appear in git.rtems.org page that's why I pushed it
> > in github. Am I possibly missing some step?
> I have fixed the cgit viewing. I am sorry for the delay.
> Your repos are there, valid and available. On dispatch.rtems.org in
> /data/git/users a symlink needs to be set to your physical repo path under
> /data/git. I have done this. The cgit server is configured to scan
> /data/git/user so it does not pick some dormant but present repos.
Thanks! It's now working and here's the rtems-net-legacy repo:
https://git.rtems.org/vijay/rtems-net-legacy.git/
Best regards,
Vijay
> Chris
