[PATCH] score: Add _Thread_Demand_objects_information()
Gedare Bloom
gedare at rtems.org
Fri Jan 29 17:23:16 UTC 2021
On Fri, Jan 29, 2021 at 10:18 AM <dufault at hda.com> wrote:
> > On Jan 29, 2021, at 10:57 , Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 29/01/2021 15:29, dufault at hda.com wrote:
> >>> On Jan 28, 2021, at 09:13 , Sebastian Huber<
> >>>> What's the rationale for "Demand"? Is that in use other places?
> >>>> It sounds odd to me, as if you're insisting the function provide
> something that it might otherwise decide not to.
> >>> "Get" was already used. This is a "Get" when we know the identifier is
> valid. Do you have a better verb?
> >> Valid_ID_Get? Or is that getting too wordy?
> >> I like "_ValID_" (i.e. use "ValID" in interface names for validated
> IDs) but that must break the rules.
> > What about:
> > _Thread_Get_objects_information() ->
> _Thread_Get_objects_information_by_id(Objects_Id)
> > _Thread_Demand_objects_information() ->
> _Thread_Get_objects_information(Thread_Control *)
> I like that. Since the interface change is internal to RTEMS the change
> in the signature isn't a big deal, and "Get_*_by_id" can be used going
> forward to imply the ID needs validation as opposed to getting it from a
> valid Thread_Control.
+1
> I have to research the RTEMS naming convention. I know it must be
> well-defined and not Random_case.
it follows a pseudo-OOP: _Package_name_Class_name_Method_name
Package is implied as _Supercore in the score.
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> This email is delivered through the public internet using protocols
> subject to interception and tampering.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/d00708e5/attachment-0001.html>
