[PATCH v3] bsps: Move optfdt* files to shared parent directory
Joel Sherrill
joel at rtems.org
Thu Jul 15 18:00:28 UTC 2021
I was going to do a sweep of all BSPs and then push but had an issue
with the patch. If something happened with the mail Pranav, please just
compress it and send it to me privately as an attachment. If it needs
rebasing, please take care of that.
[joel at devel rtems]$ git am /tmp/x
Applying: bsps: Move optfdt* files to shared parent directory
error: patch failed: spec/build/bsps/arm/beagle/optfdtcpyro.yml:1
error: spec/build/bsps/arm/beagle/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtmxsz.yml:1
error: spec/build/bsps/arm/beagle/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtro.yml:1
error: spec/build/bsps/arm/beagle/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/beagle/optfdtuboot.yml:1
error: spec/build/bsps/arm/beagle/optfdtuboot.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtcpyro.yml:1
error: spec/build/bsps/arm/imx/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtmxsz.yml:1
error: spec/build/bsps/arm/imx/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtro.yml:1
error: spec/build/bsps/arm/imx/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/arm/imx/optfdtuboot.yml:1
error: spec/build/bsps/arm/imx/optfdtuboot.yml: patch does not apply
error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml:1
error: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtro.yml:1
error: spec/build/bsps/powerpc/qoriq/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtcpyro.yml:1
error: spec/build/bsps/riscv/riscv/optfdtcpyro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtmxsz.yml:1
error: spec/build/bsps/riscv/riscv/optfdtmxsz.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtro.yml:1
error: spec/build/bsps/riscv/riscv/optfdtro.yml: patch does not apply
error: patch failed: spec/build/bsps/riscv/riscv/optfdtuboot.yml:1
error: spec/build/bsps/riscv/riscv/optfdtuboot.yml: patch does not apply
Patch failed at 0001 bsps: Move optfdt* files to shared parent directory
hint: Use 'git am --show-current-patch' to see the failed patch
When you have resolved this problem, run "git am --continue".
If you prefer to skip this patch, run "git am --skip" instead.
To restore the original branch and stop patching, run "git am --abort".
On Thu, Jul 15, 2021 at 10:13 AM Gedare Bloom <gedare at rtems.org> wrote:
> This patch looks fine to me if someone can pick it up. It does touch a
> lot of build BSPs though.
> On Fri, Jul 9, 2021 at 12:16 AM Pranav Dangi <dangipranav at gmail.com> wrote:
> > ping. (Apart from moving the files in a shared directory, a part of this patch also gets the RTEMS master branch to work on all the Pi's except 4.)
> > On Fri, 2 Jul 2021, 09:35 Pranav Dangi, <dangipranav at gmail.com> wrote:
> >> yes, I've built all of them
> >> On Thu, Jul 1, 2021 at 10:01 PM Gedare Bloom <gedare at rtems.org> wrote:
> >>> Did you build all affected BSPs?
> >>> On Thu, Jul 1, 2021 at 4:05 AM pranav <dangipranav at gmail.com> wrote:
> >>> > .../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
> >>> > spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
> >>> > spec/build/bsps/arm/beagle/optfdtcpyro.yml | 15 ---------------
> >>> > spec/build/bsps/arm/beagle/optfdtmxsz.yml | 16 ----------------
> >>> > spec/build/bsps/arm/beagle/optfdtro.yml | 15 ---------------
> >>> > spec/build/bsps/arm/beagle/optfdtuboot.yml | 15 ---------------
> >>> > spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
> >>> > spec/build/bsps/arm/imx/optfdtcpyro.yml | 15 ---------------
> >>> > spec/build/bsps/arm/imx/optfdtmxsz.yml | 16 ----------------
> >>> > spec/build/bsps/arm/imx/optfdtro.yml | 15 ---------------
> >>> > spec/build/bsps/arm/imx/optfdtuboot.yml | 15 ---------------
> >>> > spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
> >>> > .../{arm/altera-cyclone-v => }/optfdtcpyro.yml | 0
> >>> > .../{arm/altera-cyclone-v => }/optfdtmxsz.yml | 0
> >>> > .../bsps/{arm/altera-cyclone-v => }/optfdtro.yml | 0
> >>> > .../{arm/altera-cyclone-v => }/optfdtuboot.yml | 0
> >>> > spec/build/bsps/powerpc/qoriq/grp.yml | 4 ++--
> >>> > spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml | 16 ----------------
> >>> > spec/build/bsps/powerpc/qoriq/optfdtro.yml | 15 ---------------
> >>> > spec/build/bsps/riscv/riscv/grp.yml | 8 ++++----
> >>> > spec/build/bsps/riscv/riscv/optfdtcpyro.yml | 15 ---------------
> >>> > spec/build/bsps/riscv/riscv/optfdtmxsz.yml | 16 ----------------
> >>> > spec/build/bsps/riscv/riscv/optfdtro.yml | 15 ---------------
> >>> > spec/build/bsps/riscv/riscv/optfdtuboot.yml | 15 ---------------
> >>> > 24 files changed, 26 insertions(+), 232 deletions(-)
> >>> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
> >>> > delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> > delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> > delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> > delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
> >>> > delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
> >>> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
> >>> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
> >>> > rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
> >>> > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> >>> > delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
> >>> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> >>> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> >>> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
> >>> > delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
> >>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> > index da567ddd79..a9f3f7dabf 100644
> >>> > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
> >>> > @@ -73,15 +73,15 @@ links:
> >>> > - role: build-dependency
> >>> > uid: optconuart1
> >>> > - uid: optfdtcpyro
> >>> > + uid: ../../optfdtcpyro
> >>> > uid: optfdten
> >>> > - uid: optfdtmxsz
> >>> > + uid: ../../optfdtmxsz
> >>> > - uid: optfdtro
> >>> > + uid: ../../optfdtro
> >>> > - uid: optfdtuboot
> >>> > + uid: ../../optfdtuboot
> >>> > uid: opti2cspeed
> >>> > diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
> >>> > index 1375913fd0..3452c3e5c8 100644
> >>> > --- a/spec/build/bsps/arm/beagle/grp.yml
> >>> > +++ b/spec/build/bsps/arm/beagle/grp.yml
> >>> > @@ -22,13 +22,13 @@ links:
> >>> > uid: optdm3730
> >>> > - uid: optfdtcpyro
> >>> > - uid: optfdtmxsz
> >>> > - uid: optfdtro
> >>> > - uid: optfdtuboot
> >>> > uid: ../grp
> >>> > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> > deleted file mode 100644
> >>> > index c26b1ae051..0000000000
> >>> > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >>> > -actions:
> >>> > -- get-boolean: null
> >>> > -- define-condition: null
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> >>> > -default: true
> >>> > -default-by-variant: []
> >>> > -description: |
> >>> > - copy the FDT blob into the read-only load area via bsp_fdt_copy()
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> > index 14af766230..0000000000
> >>> > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
> >>> > +++ /dev/null
> >>> > @@ -1,16 +0,0 @@
> >>> > -actions:
> >>> > -- get-integer: null
> >>> > -- define: null
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: 262144
> >>> > -description: |
> >>> > - maximum size of the FDT blob in bytes
> >>> > -enabled-by: true
> >>> > -format: '{}'
> >>> > -links: []
> >>> > -name: BSP_FDT_BLOB_SIZE_MAX
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
> >>> > index a61bb2924b..0000000000
> >>> > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > - place the FDT blob into the read-only data area
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -name: BSP_FDT_BLOB_READ_ONLY
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> > index 5805e912ff..0000000000
> >>> > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > - copy the U-Boot provided FDT to an internal storage
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -name: BSP_START_COPY_FDT_FROM_U_BOOT
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
> >>> > index c65e02db2b..14719745f0 100644
> >>> > --- a/spec/build/bsps/arm/imx/bspimx.yml
> >>> > +++ b/spec/build/bsps/arm/imx/bspimx.yml
> >>> > @@ -61,13 +61,13 @@ links:
> >>> > uid: optconirq
> >>> > - uid: optfdtcpyro
> >>> > - uid: optfdtmxsz
> >>> > - uid: optfdtro
> >>> > - uid: optfdtuboot
> >>> > uid: optresetvec
> >>> > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
> >>> > +++ /dev/null
> >>> > @@ -1,16 +0,0 @@
> >>> > -actions:
> >>> > -- define: null
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: 262144
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -format: '{}'
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
> >>> > --- a/spec/build/bsps/arm/imx/optfdtro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> > index 7291e8b178..3c59ad77c1 100644
> >>> > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
> >>> > @@ -31,6 +31,14 @@ links:
> >>> > uid: optrpi2
> >>> > uid: optspiiomode
> >>> > +- role: build-dependency
> >>> > uid: ../start
> >>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
> >>> > similarity index 100%
> >>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
> >>> > rename to spec/build/bsps/optfdtcpyro.yml
> >>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
> >>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
> >>> > rename to spec/build/bsps/optfdtmxsz.yml
> >>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
> >>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
> >>> > rename to spec/build/bsps/optfdtro.yml
> >>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
> >>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
> >>> > rename to spec/build/bsps/optfdtuboot.yml
> >>> > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
> >>> > index 3e295cb599..08533ded6f 100644
> >>> > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
> >>> > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
> >>> > @@ -68,9 +68,9 @@ links:
> >>> > uid: optexcfixdhdlr
> >>> > - uid: optfdtmxsz
> >>> > - uid: optfdtro
> >>> > uid: opthid0
> >>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> >>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
> >>> > +++ /dev/null
> >>> > @@ -1,16 +0,0 @@
> >>> > -actions:
> >>> > -- define: null
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: 262144
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -format: '{}'
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> >>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
> >>> > index 396f8986ec..77583d351e 100644
> >>> > --- a/spec/build/bsps/riscv/riscv/grp.yml
> >>> > +++ b/spec/build/bsps/riscv/riscv/grp.yml
> >>> > @@ -32,13 +32,13 @@ links:
> >>> > uid: optextirqmax
> >>> > - uid: optfdtcpyro
> >>> > - uid: optfdtmxsz
> >>> > - uid: optfdtro
> >>> > - uid: optfdtuboot
> >>> > uid: optfrdme310arty
> >>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> >>> > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> >>> > index 63a42f5a29..0000000000
> >>> > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
> >>> > +++ /dev/null
> >>> > @@ -1,16 +0,0 @@
> >>> > -actions:
> >>> > -- define: null
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: 65536
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -format: '{}'
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
> >>> > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> >>> > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
> >>> > +++ /dev/null
> >>> > @@ -1,15 +0,0 @@
> >>> > -actions:
> >>> > -build-type: option
> >>> > -copyrights:
> >>> > -default: true
> >>> > -description: |
> >>> > -enabled-by: true
> >>> > -links: []
> >>> > -type: build
> >>> > 2.27.0
> >>> > _______________________________________________
> >>> > devel mailing list
> >>> > devel at rtems.org
> >>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
