ttcp only on 6-freebsd-12 and not on master of libbsd
Joel Sherrill
joel at rtems.org
Sat Jul 24 16:40:50 UTC 2021
On Sat, Jul 24, 2021, 11:30 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Joel,
> On 24/07/2021 18:18, Joel Sherrill wrote:
> > On Sat, Jul 24, 2021, 10:19 AM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> > Hello,
> > in a discussion with Husni I noted that the patches adding ttcp are
> > only
> > on the 6-freebsd-12 branch of libbsd. Is there a reason that they are
> > not on master too?
> > Yes but forgetting isn't a good reason. I know I have a recent patch so
> > apps using C99 or C++03 can compile using libbsd missing also. I will
> > survey OAR and make sure we catch up.
> I missed something like that in the past too and I will miss it in the
> future. And I'm sure that I have some on master that are not on
> 6-freebsd-12. So no problem. Just wanted to check that there is no other
> reason.
We probably need to collectively be more diligent about asking that any
patches go onto 6-freedbsd-12 and master. Some also should go to
5-freebsd-12. We are all busy and just forget.
> By the way: Please tell me if you find patches that I missed ;-)
I would if we can figure.out how to spot them.
> > Is there any reason rtemsbsd/ just shouldn't be the same?
> Most of it most likely is the same. But there are differences. Some of
> them might shouldn't be there but they are there. Try to checkout master
> and do a
> git diff 6-freebsd-12 -- rtemsbsd/
> I don't think that someone wants to clean that up on an update.
Is it possible to take the output of that and do a git blame on the
6-freebsd-12 branch, grab the hash and author, and generate a master list
of hashes and who was responsible for review?
It would make the audit easier.
Changes to the FreeBSD directory might be harder. I know Kinsey back ported
some stuff.
--joel
> Best regards
> Christian
> https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4
> https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633
> https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d
> https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb
> > Background for the question: I expect that an update to FreeBSD 13
> will
> > use only what is on the master branch. That's basically what master
> is
> > for: Tracking the development to keep up with new stuff in FreeBSD
> and
> > make it easy to jump to the next FreeBSD release. In other words: I
> > think a (possible future) 6-freebsd-13 branch will be based on master
> > and not on 6-freebsd-12. Am I wrong with that assumption?
> > Again: please correct me if I'm wrong but with that in mind I would
> say
> > that it is a good idea to port to master and 6-freebsd-12 or (for
> > experimental stuff) only to master. But not only to 6-freebsd-12.
> > Best regards
> > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210724/2ca09c9c/attachment-0001.html>
