ttcp only on 6-freebsd-12 and not on master of libbsd
Christian Mauderer oss at c-mauderer.de
Sat Jul 24 18:55:29 UTC 2021
Hello Joel,
I wrote a short script to find different commits based on author and
subject (see attached python-script). It seems that there are quite some
differences (see attached output).
The big blog of HDMI on Beagle patches that is only on master is caused
by me. These have been developed by Vijay while I was a mentor for his
project. Would be a question whether that's a feature that should be on
the stable branch too or not. Some commits will be most likely only on
one branch (for example 816a2f912f where Chris updated rtems_waf).
Best regards
Christian
On 24/07/2021 18:40, Joel Sherrill wrote:
> On Sat, Jul 24, 2021, 11:30 AM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Joel,
>     On 24/07/2021 18:18, Joel Sherrill wrote:
>      > On Sat, Jul 24, 2021, 10:19 AM Christian Mauderer
>     <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
>      > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
>      >     Hello,
>      >     in a discussion with Husni I noted that the patches adding
>     ttcp are
>      >     only
>      >     on the 6-freebsd-12 branch of libbsd. Is there a reason that
>     they are
>      >     not on master too?
>      > Yes but forgetting isn't a good reason. I know I have a recent
>     patch so
>      > apps using C99 or C++03 can compile using libbsd missing also. I
>     will
>      > survey OAR and make sure we catch up.
>     I missed something like that in the past too and I will miss it in the
>     future. And I'm sure that I have some on master that are not on
>     6-freebsd-12. So no problem. Just wanted to check that there is no
>     other
>     reason.
> We probably need to collectively be more diligent about asking that any
> patches go onto 6-freedbsd-12 and master. Some also should go to
> 5-freebsd-12. We are all busy and just forget.
>     By the way: Please tell me if you find patches that I missed ;-)
> I would if we can figure.out how to spot them.
>      > Is there any reason rtemsbsd/ just shouldn't be the same?
>     Most of it most likely is the same. But there are differences. Some of
>     them might shouldn't be there but they are there. Try to checkout
>     master
>     and do a
>          git diff 6-freebsd-12 -- rtemsbsd/
>     I don't think that someone wants to clean that up on an update.
> Is it possible to take the output of that and do a git blame on the
> 6-freebsd-12 branch, grab the hash and author, and generate a master
> list of hashes and who was responsible for review?
> It would make the audit easier.
> Changes to the FreeBSD directory might be harder. I know Kinsey back
> ported some stuff.
> --joel
>     Best regards
>     Christian
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=af06b267c5ce04e8a4a7719cb0c723ee4a27f4b4>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633 <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=7960ab7a43d5a7c6ceccdd67f8e379adfce7a633>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=6cc63cbe657c3ee664727cce1a54acc7e7b5fe9d>>
>     https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb
>     <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb>
>       <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb <https://git.rtems.org/rtems-libbsd/commit/?h=6-freebsd-12&id=8dfea31d729fafab69b5cf1846598f5104b0faeb>>
>      >     Background for the question: I expect that an update to
>     FreeBSD 13 will
>      >     use only what is on the master branch. That's basically what
>     master is
>      >     for: Tracking the development to keep up with new stuff in
>     FreeBSD and
>      >     make it easy to jump to the next FreeBSD release. In other
>     words: I
>      >     think a (possible future) 6-freebsd-13 branch will be based
>     on master
>      >     and not on 6-freebsd-12. Am I wrong with that assumption?
>      >     Again: please correct me if I'm wrong but with that in mind I
>     would say
>      >     that it is a good idea to port to master and 6-freebsd-12 or (for
>      >     experimental stuff) only to master. But not only to 6-freebsd-12.
>      >     Best regards
>      >     Christian
INFO: Head of master: 8f870a3593 (Gedare Bloom: aarch64/nexus: add GEM definitions for Versal)
INFO: Head of 6-freebsd-12: c5e81a2169 (Joel Sherrill: linker_set.h: Add alignof implementation for when not C11 or C++11)
INFO: Common ancestor: 8ae22c48b3 (Christian Mauderer: freebsd/if_cpsw: Port.)
WARNING: Only on master: 8f870a3593 (Gedare Bloom: aarch64/nexus: add GEM definitions for Versal)
WARNING: Only on master: 5251e0c816 (G S Niteesh Babu: iicbus/rtems-i2c.c: Add rtems,path as an additional bus path)
WARNING: Only on master: 9b9a976847 (Vijay Kumar Banerjee: Revert "Import telnetd from RTEMS repository")
WARNING: Only on master: 1b07480ddc (Vijay Kumar Banerjee: Import telnetd from RTEMS repository)
WARNING: Only on master: c66e527ab7 (Vijay Kumar Banerjee: libbsd.py: Build i2c shell command)
WARNING: Only on master: 3cdf289424 (G S Niteesh Babu: arm/ti/ti_pinmux: Remove TI pinmux driver)
WARNING: Only on master: 33bfaee89a (Christian Mauderer: wpa: Fix multiple definition of `hmac_md5`)
WARNING: Only on master: 90a9fd66e0 (Chris Johns: Update the CONTRIBUTING with kernel/user space notes.)
WARNING: Only on master: 5f29d17bee (Sebastian Huber: linux/crc32.h: Update due to API changes)
WARNING: Only on master: 48e33f00e4 (Sebastian Huber: linux/genalloc.h: Update due to API changes)
WARNING: Only on master: 56fd3765e9 (Jan Sommer: e1000: Add missing files)
WARNING: Only on master: 35fc309241 (Vijay Kumar Banerjee: wscript: add uninstall command)
WARNING: Only on master: f1eb69a4a3 (Vijay Kumar Banerjee: Update rtems_waf)
WARNING: Only on master: c81707c3e2 (Christian Mauderer: README: Update with information for RTEMS 6)
WARNING: Only on master: b96abfd647 (Vijay Kumar Banerjee: libbsd.py: Install the evdev header files)
WARNING: Only on master: 792d56bd33 (Sebastian Huber: NVME(4): Fix for big endian platforms)
WARNING: Only on master: 9215a81d08 (Jan Sommer: i386: Add to build)
WARNING: Only on master: a5ddb0ea69 (Sebastian Huber: Update to FreeBSD head 2019-09-24)
WARNING: Only on master: 951c4b92cf (Vijay Kumar Banerjee: rtemsbsd: remove dead code fb.c)
WARNING: Only on master: 530f8f5abd (Vijay Kumar Banerjee: am335x display drivers: Port to RTEMS)
WARNING: Only on master: 7adbe5b0bd (Vijay Kumar Banerjee: am335x display drivers: Import from FreeBSD)
WARNING: Only on master: d7c01f4569 (Vijay Kumar Banerjee: fbd: Port to RTEMS)
WARNING: Only on master: fa976bc5aa (Vijay Kumar Banerjee: fbd: Import from FreeBSD)
WARNING: Only on master: 2cf7b6b3e4 (Vijay Kumar Banerjee: TDA19988: Port to RTEMS)
WARNING: Only on master: b7458b0915 (Vijay Kumar Banerjee: TDA19988: Import from FreeBSD)
WARNING: Only on master: 59ce99a357 (Vijay Kumar Banerjee: Pinmux: Port to RTEMS)
WARNING: Only on master: e3bc24e616 (Vijay Kumar Banerjee: Pinmux : Import from FreeBSD)
WARNING: Only on master: b68ca55c96 (Vijay Kumar Banerjee: Add mmap)
WARNING: Only on master: 4ed60d9076 (Vijay Kumar Banerjee: i2c tool : port to RTEMS)
WARNING: Only on master: e8c5db1e87 (Vijay Kumar Banerjee: i2c tool : Import from FreeBSD)
WARNING: Only on master: 7ab9e2ad53 (Vijay Kumar Banerjee: Add rtems i2c adaptation layer)
WARNING: Only on master: 4e1325a338 (Vijay Kumar Banerjee: iicbus: port to RTEMS)
WARNING: Only on master: 627fd1624e (Vijay Kumar Banerjee: iicbus: Import from FreeBSD)
WARNING: Only on master: 9a4ed64d5a (Vijay Kumar Banerjee: CONTRIBUTING: mention pyelftools dependency)
WARNING: Only on master: 589f43d6af (Christian Mauderer: Import FreeBSD license files.)
WARNING: Only on master: e2fc908281 (Christian Mauderer: builder.py: Add case for plain text files.)
WARNING: Only on master: c64a1ebaf9 (Christian Mauderer: Add helper script to find licenses.)
WARNING: Only on master: 3f2b54d971 (Vijay Kumar Banerjee: Remove pcap_version.h)
WARNING: Only on master: 5754194298 (Sebastian Huber: README: Add branch description)
WARNING: Only on master: 5a8ccdabf6 (Sebastian Huber: CONTRIBUTING: Fix format)
WARNING: Only on master: 9391f52d14 (Sebastian Huber: README.md: Add Qemu and networking section)
WARNING: Only on master: 2cfb4f190d (Sebastian Huber: README.md: Fix path)
WARNING: Only on master: 04e8a83c51 (Sebastian Huber: README.md: Rework FreeBSD kernel options)
WARNING: Only on master: ba556909dc (Sebastian Huber: README.md: Remove maintainer information)
WARNING: Only on master: 32a41a1736 (Sebastian Huber: Ignore .waf*)
WARNING: Only on master: f60ac53420 (Sebastian Huber: Update rtems-bsd-kernel-namespace.h)
WARNING: Only on master: 2b2563da95 (Sebastian Huber: Update to FreeBSD head 2018-12-20)
WARNING: Only on 6-freebsd-12: c5e81a2169 (Joel Sherrill: linker_set.h: Add alignof implementation for when not C11 or C++11)
WARNING: Only on 6-freebsd-12: c41318075e (Stephen Clark: nexus: Added SDHCI driver to ZynqMP)
WARNING: Only on 6-freebsd-12: a53aeb5eb9 (Kinsey Moore: rtemsbsd: Present all ZynqMP interfaces by default)
WARNING: Only on 6-freebsd-12: 14576608a9 (Kinsey Moore: freebsd/if_cgem: Fail probe for unterminated MII)
WARNING: Only on 6-freebsd-12: b0c8153d54 (Kinsey Moore: rtemsbsd: Use config.inc to control ZynqMP ethernet)
WARNING: Only on 6-freebsd-12: 8dfea31d72 (Stephen Clark: rtemsbsd: Added a test for the TTCP command.)
WARNING: Only on 6-freebsd-12: 6cc63cbe65 (Stephen Clark: rtemsbsd: Made TTCP command build for RTEMS)
WARNING: Only on 6-freebsd-12: 7960ab7a43 (Stephen Clark: rtemsbsd:Updated TTCP code with network demo code)
WARNING: Only on 6-freebsd-12: af06b267c5 (Stephen Clark: rtemsbsd: Added original TTCP code)
WARNING: Only on 6-freebsd-12: 4ce914cb90 (Kinsey Moore: rtemsbsd: Make ZynqMP CGEM interfaces selectable)
WARNING: Only on 6-freebsd-12: 023e94fd8b (Kinsey Moore: nexus: Add UKPHY driver to ZynqMP)
WARNING: Only on 6-freebsd-12: 3abebabf1d (Kinsey Moore: linker: Enforce set alignment requirements)
WARNING: Only on 6-freebsd-12: 28129f8ee6 (Kinsey Moore: ck: Update for ILP32)
WARNING: Only on 6-freebsd-12: e256668d6e (Kinsey Moore: nexus: Add ZynqMP SLCR driver)
WARNING: Only on 6-freebsd-12: 1d9f93cbaa (Kinsey Moore: nexus: Switch ZynqMP platforms to CGEM3)
WARNING: Only on 6-freebsd-12: b7a12cc8f9 (Kinsey Moore: if_cgem: Add support for ZynqMP CGEM)
WARNING: Only on 6-freebsd-12: 0c60fe524e (Kinsey Moore: rtembsd: Fix alignment of allocations for 64bit)
WARNING: Only on 6-freebsd-12: 68e79b6d18 (Kinsey Moore: zynq: Add support for SDHCI devices)
WARNING: Only on 6-freebsd-12: dbf72c205d (Jan Sommer: waf: Add path-mappings feature)
WARNING: Only on 6-freebsd-12: 816a2f912f (Chris Johns: rtems_waf: Update to origin/master.)
WARNING: Only on 6-freebsd-12: 46b3858b27 (Sebastian Huber: Update to FreeBSD stable/12 2020-02-10)
WARNING: Only on 6-freebsd-12: 8618727d51 (Sebastian Huber: Add compatiblity for older Newlib variants)
WARNING: Only on 6-freebsd-12: 37323bb819 (Sebastian Huber: Update to FreeBSD stable/12 2019-09-23)
WARNING: Only on 6-freebsd-12: 3411e3d738 (Sebastian Huber: Update to FreeBSD stable/12 2019-08-26)
WARNING: Only on 6-freebsd-12: 5283630d2c (Sebastian Huber: Update to FreeBSD stable/12 2019-07-09)
WARNING: Only on 6-freebsd-12: bbd07d1ac9 (Sebastian Huber: Import missing header file)
WARNING: Only on 6-freebsd-12: 7ece7548c1 (Sebastian Huber: Update to FreeBSD stable/12 2019-06-26)
WARNING: Only on 6-freebsd-12: 705e362ea5 (Sebastian Huber: Update to FreeBSD stable/12 2019-06-05)
WARNING: Only on 6-freebsd-12: 481397ff24 (Sebastian Huber: Update to FreeBSD stable/12 2019-03-27)
WARNING: Only on 6-freebsd-12: eb1d30ad35 (Sebastian Huber: Update to FreeBSD stable/12 2019-03-11)
WARNING: Only on 6-freebsd-12: 556ec29b4e (Sebastian Huber: Update to FreeBSD stable/12 2019-02-11)
WARNING: Only on 6-freebsd-12: 4a8bc9e5fa (Sebastian Huber: Update to FreeBSD stable/12 2019-02-04)
WARNING: Only on 6-freebsd-12: a5b385b26f (Sebastian Huber: Update to FreeBSD stable/12 2019-01-29)
WARNING: Only on 6-freebsd-12: 1354d9bf97 (Sebastian Huber: Update to FreeBSD stable/12 2019-01-21)
WARNING: Only on 6-freebsd-12: aec8db05b2 (Sebastian Huber: Update to FreeBSD stable/12 2019-01-16)
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210724/e899aeea/attachment.py>
