[PATCH rtems-libbsd 2/2] builder.py: Only disable tests if they are there
Christian Mauderer
oss at c-mauderer.de
Fri Jun 11 12:19:53 UTC 2021
For checking the dependencies, the tests are removed. But if the tests
are not enabled at all, that triggers a python exception.
builder.py | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/builder.py b/builder.py
index cbe5dc59..a34a1518 100755
--- a/builder.py
+++ b/builder.py
@@ -1062,7 +1062,8 @@ class ModuleManager(object):
def _checkDependencies(self):
enabled_modules = self.getEnabledModules()
- enabled_modules.remove('tests')
+ if 'tests' in enabled_modules:
+ enabled_modules.remove('tests')
for mod in enabled_modules:
if mod not in self.modules:
raise KeyError('enabled module not found: %s' % (mod))
2.32.0
