Running SPARC/LEON3 in TSIM-LEON3 simulator
Đức Anh
dauto98 at gmail.com
Mon Jun 14 14:53:56 UTC 2021
Hi Jiri,
Thanks for the suggestion. It works. However, it looks like it just
simulates the instruction. I am looking for a cycle-accurate simulator and
can provide the performance information on each core. Do you know any?
Best,
Duc Anh
On Fri, 11 Jun 2021 at 22:10, Jiri Gaisler <jiri at gaisler.se> wrote:
> On 6/11/21 12:37 PM, Đức Anh wrote:
> Hi Sebastian,
> Thank you. I didn't notice that.
> I recompile with SMP enabled, and the application doesn't run successfully
> in the TSIM-LEON3 simulator. Below is the error message:
> Initializing and starting from 0x40000000
>> CPU 0 in error mode (tt=0x80, trap instruction)
>> (In trap table for tt=0x02, illegal instruction)
>> 70150 40000020 91d02000 ta 0
>> start + 0x20
> The thing is, the same code will work if I compile with SMP disabled. When
> the SMP is enabled, the simulator will crash like above, even with the
> simple hello world application.
> Have anyone here run into a similar issue? Or do you know any other leon3
> (or sparc) simulator that I can try?
> You can try with sis:
> sparc-rtem6-sis -leon3 -m 4 hello.exe
> Should work without problems. For SMP, you need the '-m 4' switch to
> enable 4 cores ...
> Jiri.
> Best regards,
> Duc Anh
> On Wed, 9 Jun 2021 at 18:46, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 09/06/2021 18:39, Đức Anh wrote:
>> > - Is there a way to enable SMP for SPARC/LEON3 in RTEMS 6?
>> Just set "RTEMS_SMP = True" in your config.ini:
>> https://docs.rtems.org/branches/master/user/bld/index.html#migration-from-autoconf-automake
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing listdevel at rtems.orghttp://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210614/ae935547/attachment.html>
