[PATCH 02/10] score: Remove bogus _ISR_Nest_level setting
Sebastian Huber
Wed Jun 23 06:49:28 UTC 2021
This variable is actually contained in _Per_CPU_Information[] which is already
zero initialized.
Remove superfluous includes.
cpukit/score/src/isr.c | 4 ----
1 file changed, 4 deletions(-)
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 09b1f37faa..28a6b3082e 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -22,9 +22,7 @@
#include <rtems/score/isr.h>
#include <rtems/score/address.h>
-#include <rtems/score/interr.h>
-#include <rtems/score/stackimpl.h>
#include <rtems/config.h>
#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
@@ -42,8 +40,6 @@ void _ISR_Handler_initialization( void )
size_t stack_size;
char *stack_low;
- _ISR_Nest_level = 0;
stack_size = rtems_configuration_get_interrupt_stack_size();
cpu_max = rtems_configuration_get_maximum_processors();
stack_low = _ISR_Stack_area_begin;
2.26.2
