[PATCH v2] bsps/arm: Move optfdt* files to shared parent directory
Christian Mauderer oss at c-mauderer.de
Tue Jun 29 18:23:11 UTC 2021
arm/imx7, arm/altcycv_devkit, arm/raspberrypi and arm/beagleboneblack
compile with the patch. I tried libbsd media01 on beagleboneblack and it
works.
Best regards
Christian
On 29/06/2021 18:56, Gedare Bloom wrote:
> I don't have an arm toolchain, if someone can pick this up and test
> compile the affected BSPs, it looks ok to me.
> On Sun, Jun 27, 2021 at 2:46 PM pranav <dangipranav at gmail.com> wrote:
>>   .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
>>   spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
>>   spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
>>   spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
>>   spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
>>   spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
>>   spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
>>   spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
>>   spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
>>   spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
>>   spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
>>   .../arm/{altera-cyclone-v => }/optfdtcpyro.yml   |  0
>>   .../arm/{altera-cyclone-v => }/optfdtmxsz.yml    |  0
>>   .../bsps/arm/{altera-cyclone-v => }/optfdtro.yml |  0
>>   .../arm/{altera-cyclone-v => }/optfdtuboot.yml   |  0
>>   spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
>>   16 files changed, 20 insertions(+), 134 deletions(-)
>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>>   delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>>   delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtcpyro.yml (100%)
>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtmxsz.yml (100%)
>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtro.yml (100%)
>>   rename spec/build/bsps/arm/{altera-cyclone-v => }/optfdtuboot.yml (100%)
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> index da567ddd79..faf7203cd4 100644
>> --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> @@ -73,15 +73,15 @@ links:
>>   - role: build-dependency
>>     uid: optconuart1
>> -  uid: optfdtcpyro
>> +  uid: ../optfdtcpyro
>>     uid: optfdten
>> -  uid: optfdtmxsz
>> +  uid: ../optfdtmxsz
>> -  uid: optfdtro
>> +  uid: ../optfdtro
>> -  uid: optfdtuboot
>> +  uid: ../optfdtuboot
>>     uid: opti2cspeed
>> diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
>> index 1375913fd0..20fafa79a0 100644
>> --- a/spec/build/bsps/arm/beagle/grp.yml
>> +++ b/spec/build/bsps/arm/beagle/grp.yml
>> @@ -22,13 +22,13 @@ links:
>>     uid: optdm3730
>> -  uid: optfdtcpyro
>> -  uid: optfdtmxsz
>> -  uid: optfdtro
>> +  uid: ../optfdtro
>> -  uid: optfdtuboot
>>     uid: ../grp
>> diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> deleted file mode 100644
>> index c26b1ae051..0000000000
>> --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> -actions:
>> -- get-boolean: null
>> -- define-condition: null
>> -build-type: option
>> -copyrights:
>> -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> -default: true
>> -default-by-variant: []
>> -description: |
>> -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
>> -enabled-by: true
>> -links: []
>> -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>> -type: build
>> diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> index 14af766230..0000000000
>> --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> +++ /dev/null
>> @@ -1,16 +0,0 @@
>> -actions:
>> -- get-integer: null
>> -- define: null
>> -build-type: option
>> -copyrights:
>> -default: 262144
>> -description: |
>> -  maximum size of the FDT blob in bytes
>> -enabled-by: true
>> -format: '{}'
>> -links: []
>> -name: BSP_FDT_BLOB_SIZE_MAX
>> -type: build
>> diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
>> index a61bb2924b..0000000000
>> --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -actions:
>> -build-type: option
>> -copyrights:
>> -default: true
>> -description: |
>> -  place the FDT blob into the read-only data area
>> -enabled-by: true
>> -links: []
>> -name: BSP_FDT_BLOB_READ_ONLY
>> -type: build
>> diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> index 5805e912ff..0000000000
>> --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -actions:
>> -build-type: option
>> -copyrights:
>> -default: true
>> -description: |
>> -  copy the U-Boot provided FDT to an internal storage
>> -enabled-by: true
>> -links: []
>> -name: BSP_START_COPY_FDT_FROM_U_BOOT
>> -type: build
>> diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
>> index c65e02db2b..faaca77e63 100644
>> --- a/spec/build/bsps/arm/imx/bspimx.yml
>> +++ b/spec/build/bsps/arm/imx/bspimx.yml
>> @@ -61,13 +61,13 @@ links:
>>     uid: optconirq
>> -  uid: optfdtcpyro
>> -  uid: optfdtmxsz
>> -  uid: optfdtro
>> +  uid: ../optfdtro
>> -  uid: optfdtuboot
>>     uid: optresetvec
>> diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -actions:
>> -build-type: option
>> -copyrights:
>> -default: true
>> -description: |
>> -enabled-by: true
>> -links: []
>> -type: build
>> diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> +++ /dev/null
>> @@ -1,16 +0,0 @@
>> -actions:
>> -- define: null
>> -build-type: option
>> -copyrights:
>> -default: 262144
>> -description: |
>> -enabled-by: true
>> -format: '{}'
>> -links: []
>> -type: build
>> diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
>> --- a/spec/build/bsps/arm/imx/optfdtro.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -actions:
>> -build-type: option
>> -copyrights:
>> -default: true
>> -description: |
>> -enabled-by: true
>> -links: []
>> -type: build
>> diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
>> --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>> +++ /dev/null
>> @@ -1,15 +0,0 @@
>> -actions:
>> -build-type: option
>> -copyrights:
>> -default: true
>> -description: |
>> -enabled-by: true
>> -links: []
>> -type: build
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/arm/optfdtcpyro.yml
>> similarity index 100%
>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>> rename to spec/build/bsps/arm/optfdtcpyro.yml
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/arm/optfdtmxsz.yml
>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>> rename to spec/build/bsps/arm/optfdtmxsz.yml
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/arm/optfdtro.yml
>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>> rename to spec/build/bsps/arm/optfdtro.yml
>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/arm/optfdtuboot.yml
>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>> rename to spec/build/bsps/arm/optfdtuboot.yml
>> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
>> index 7291e8b178..e6b0a1cf75 100644
>> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>> @@ -31,6 +31,14 @@ links:
>>     uid: optrpi2
>>     uid: optspiiomode
>> +- role: build-dependency
>> +  uid: ../optfdtro
>>     uid: ../start
>> 2.27.0
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
