Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
Heinz Junkes
junkes at fhi-berlin.mpg.de
Thu Mar 4 14:22:49 UTC 2021
I have installed the legacy package but the files are not there.
I guess they were just forgotten in the legacy package.
Heinz
> On 4. Mar 2021, at 14:52, Joel Sherrill <joel at rtems.org> wrote:
> Did you install the legacy package? If you installed it in the same place
> as the RTEMS 5 BSP, I would expect it to be there. This SHOULD be
> equivalent to prior split.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210304/9118593c/attachment-0001.bin>
