Announcement: Legacy libnetworking will be removed from RTEMS and will be placed in a separate repository
Thu Mar 4 14:26:37 UTC 2021
On Thu, Mar 4, 2021 at 8:22 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> I have installed the legacy package but the files are not there.
> I guess they were just forgotten in the legacy package.
I'd guess Vijay forgot to install them. Certainly easy enough to do.
Eventually the NFSv2 client will need to be in the legacy stack
package. But until the port of the FreeBSD NFSv4 client is available
in libbsd, the existing NFSv2 client has to be used for both stacks.
I suppose this may end up being the one piece of lingering clean up.
--joel
> Heinz
> > On 4. Mar 2021, at 14:52, Joel Sherrill <joel at rtems.org> wrote:
> > Did you install the legacy package? If you installed it in the same place
> > as the RTEMS 5 BSP, I would expect it to be there. This SHOULD be
> > equivalent to prior split.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210304/c086c9b6/attachment.html>
