RSB build issue with rtems-libbsd
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 9 02:44:45 UTC 2021
On Mon, Mar 8, 2021 at 3:14 PM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Mar 8, 2021, 4:02 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 6/3/21 2:24 pm, Vijay Kumar Banerjee wrote:
>> > Hello,
>> > I'm getting the following error when trying to build rtems-libbsd from
>> > RSB. Is there anything that I'm missing?
>> > ../source-builder/sb-set-builder --prefix=$RTEMS6_PREFIX
>> > 6/rtems-libbsd --host=powerpc-rtems6 --with-rtems-bsp=beatnik
>> > RTEMS Source Builder - Set Builder, 6 (102cb1e6450f)
>> > warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
>> > Build Set: 6/rtems-libbsd
>> > config: tools/rtems-libbsd-6.cfg
>> > error: rtems-bsp.cfg:155: invalid %if operator:  -mcpu=7400
>> > -I/home/vijay/development/rtems/6/powerpc-rtems6/beatnik/lib/include
>> This looks like a bug. Please raise a ticket.
>> > Build FAILED
>> > Build Set: Time 0:00:00.046141
>> > Build FAILED
>> > Commenting these checks from rtems-bsp.cfg gets it building.
>> Unfortunately the checks are needed and this is not the answer.
>> I wonder how Jennifer has been building libbsd. She is working on this BSP and
>> libbsd.
This issue is happening with other bsps as well.
This error is also being a blocker to building rtems-net-legacy with
the new patch. I can have a look at it, do you have any hints on what
might be going wrong?
Best regards,
Vijay
> Directly with waf.
> --joel
>> Chris
>> devel mailing list
>> devel at rtems.org
