[PATCH 4/5] flashdisk.c: Fix Resource leak (CID #1439298)
Ryan Long
ryan.long at oarcorp.com
Fri Mar 12 15:18:45 UTC 2021
CID 1439298: Resource leak in rtems_fdisk_initialize().
Closes #4299
cpukit/libblock/src/flashdisk.c | 42 ++++++++++++++++++++++++++++++-----------
1 file changed, 31 insertions(+), 11 deletions(-)
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index 91f99e0..c4bac82 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -2463,6 +2463,7 @@ rtems_fdisk_initialize (rtems_device_major_number major,
char name[] = RTEMS_FLASHDISK_DEVICE_BASE_NAME "a";
uint32_t device;
+ uint32_t device_to_free;
uint32_t blocks = 0;
int ret;
@@ -2485,18 +2486,27 @@ rtems_fdisk_initialize (rtems_device_major_number major,
* One copy buffer of a page size.
fd->copy_buffer = malloc (c->block_size);
- if (!fd->copy_buffer)
+ if (!fd->copy_buffer) {
+ free(fd);
return RTEMS_NO_MEMORY;
fd->blocks = calloc (blocks, sizeof (rtems_fdisk_block_ctl));
- if (!fd->blocks)
+ if (!fd->blocks) {
+ free(fd->copy_buffer);
+ free(fd);
fd->block_count = blocks;
fd->devices = calloc (c->device_count, sizeof (rtems_fdisk_device_ctl));
- if (!fd->devices)
+ if (!fd->devices) {
+ free (fd->blocks);
+ free (fd->copy_buffer);
+ free (fd);
rtems_mutex_init (&fd->lock, "Flash Disk");
@@ -2505,9 +2515,10 @@ rtems_fdisk_initialize (rtems_device_major_number major,
if (sc != RTEMS_SUCCESSFUL)
rtems_mutex_destroy (&fd->lock);
- free (fd->copy_buffer);
- free (fd->blocks);
free (fd->devices);
+ free (fd);
rtems_fdisk_error ("disk create phy failed");
return sc;
@@ -2524,11 +2535,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
sizeof (rtems_fdisk_segment_ctl));
if (!fd->devices[device].segments)
+ for (device_to_free = device - 1; device_to_free >= 0; device_to_free--)
+ free(fd->devices[device_to_free].segments);
unlink (name);
free (fd->devices);
+ free (fd);
@@ -2559,11 +2573,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
ret = rtems_fdisk_recover_block_mappings (fd);
if (ret)
unlink (name);
free (fd->devices);
+ free (fd);
rtems_fdisk_error ("recovery of disk failed: %s (%d)",
strerror (ret), ret);
return ret;
@@ -2572,11 +2589,14 @@ rtems_fdisk_initialize (rtems_device_major_number major,
ret = rtems_fdisk_compact (fd);
if (ret)
unlink (name);
free (fd->devices);
+ free (fd);
rtems_fdisk_error ("compacting of disk failed: %s (%d)",
return ret;
1.8.3.1
