[PATCH 3/5] nvdisk.c: Fix Resource leak (CID #1439297)
    Gedare Bloom
    gedare at rtems.org
    Mon Mar 15 22:10:03 UTC 2021
On Mon, Mar 15, 2021 at 2:28 PM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Mar 15, 2021, 3:10 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Mar 12, 2021 at 8:18 AM Ryan Long <ryan.long at oarcorp.com> wrote:
>> > CID 1439297: Resource leak in rtems_nvdisk_initialize().
>> > Closes #4298
>> >  cpukit/libblock/src/nvdisk.c | 8 +++++++-
>> >  1 file changed, 7 insertions(+), 1 deletion(-)
>> > diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
>> > index a7f4167..d742baf 100644
>> > --- a/cpukit/libblock/src/nvdisk.c
>> > +++ b/cpukit/libblock/src/nvdisk.c
>> > @@ -766,8 +766,10 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
>> >      nvd->info_level   = c->info_level;
>> >      nvd->devices = calloc (c->device_count, sizeof (rtems_nvdisk_device_ctl));
>> > -    if (!nvd->devices)
>> > +    if (!nvd->devices) {
>> > +      free(nvd);
>> >        return RTEMS_NO_MEMORY;
>> >      for (device = 0; device < c->device_count; device++)
>> > @@ -790,6 +792,8 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
>> >                               rtems_nvdisk_ioctl, nvd);
>> >      if (sc != RTEMS_SUCCESSFUL)
>> > +      free(nvd->devices);
>> > +      free(nvd);
>> >        rtems_nvdisk_error ("disk create phy failed");
>> >        return sc;
>> > @@ -797,5 +801,7 @@ rtems_nvdisk_initialize (rtems_device_major_number major RTEMS_UNUSED,
>> >      rtems_mutex_init (&nvd->lock, "NV Disk");
>> > +  free(nvd);
>> Does the rtems_blkdev_create() link the nvd? (I think the answer is
>> yes.) Then, this is not correct.
> I think this is my suggestion so what do you think should happen on this case?
Does the block device driver register a callback handler for the
device_data destruction?
>> >    return RTEMS_SUCCESSFUL;
>> > 1.8.3.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
